How to make an hourglass from two lightbulbs
In my first Instructable wilI show you how I made a fancy hourglass.
Lightbulbs are becoming cheaper because they are been replaced by cold light lamps and LED´s .
So ,if you you have two fused lightbulbs ,reuse them into.. an hourglass!!!!
Step 1The materials
What you will need:
- Two lightbulbs of the same type
- Sand, preferably from the sea shore.
- A screw
- Some wood
- An empty can or any piece of thin metal,alluminun works great.
- Some paint for the base.
- Hidrochloric acid (you can avoid this if your sand is clean)
16 comments
Dec 13, 2009. 12:48 PMCaodiie says:
Is there anything else we can use instead of the diamond tool? Because I don't have it at home and I doubt my school has it... I'm making it for a school project.
Thank you a lot for posting this tutorial, totally awesome. :D
Jan 30, 2010. 4:24 PMCaodiie says:
Alright, I'll see what my school have and I'll try your tips! :)
Thanks a lot!
Sep 7, 2008. 6:06 PMFather Christmas says:
I want to thank you so much for making this instructable. it served as a perfect inspiration for my hourglass. you can see it is massively different, but yours gave me so many ideas about how to do it along with the incentive to start it. so thank you.
Mar 5, 2009. 3:51 PMclemsonguy1125 says:
how did you make the thing between the two lightbulbs that make the small stream of sand
Mar 5, 2009. 4:48 PMFather Christmas says:
I basically stole the idea from this instructable, but instead i superglued a small sheet of aluminum from a can (with the small hole) between two washers. I then used superglue to secure it to one of the bulbs, filled the others, used duct tape hold it together, and tested.
Sep 7, 2008. 6:08 PMFather Christmas says:
btw, mine last for about 20 minutes, before needing flipped
Jan 19, 2008. 2:54 AMpousao says:
It is a great idea, I wonder how to "keep it open" so we can tune the amount of time with the sand.
Sep 6, 2008. 8:38 AMFather Christmas says:
i solved that problem while making mine. what i did was use two regular bulbs (sixty watts, dollars store for 25 cents) then i hollowed it out while leaving the metal part attached. i used two small washers with a piece of aluminum between them. then i superglued it to one of the bulbs. put sand in the other one and then use the almighty duct tape to temporarily hold them together. then stopwatch, untape, add/remove sand. repeat as necessary.
Mar 8, 2008. 6:40 PMbutters8754 says:
wow, this seems to be a eco friendly idea as well as an item that looks cool, and would be fun to build. butters8754
Feb 23, 2008. 3:02 PMspylock says:
I often dont rate these projects,but this one is worthy.
Jan 18, 2008. 5:36 PMGorillazMiko says:
Great idea, I will try. Most likely. If I have the time. AWESOME JOB!
Jan 18, 2008. 3:06 PMLinuxH4x0r says:
Nice! I got to make myself one.
Jan 18, 2008. 10:59 AMPatrik says:
Nice idea! The treatment with hydrochloric acid isn't really necessary. That essentially removes the calcium carbonate sand particles (originating from weathered coral or shell fragments), leaving just the quartz-based sand particles. You may be better off passing the sand through a sieve to get uniformely fine particles, then treating it with bleach or peroxide for color (and to disinfect). The lead base is a cute trick - I wouldn't have thought of pouring lead directly into a hollowed out wooden base. (Then again, it's been a while since I've poured lead - which may be why I still seem to have most of my neurons...) Does anyone have a better idea for the neck between the two bulbs?
Jan 18, 2008. 2:36 AMCarpetGnome says:
Awesome! I can't wait to try this. Thanks for posting.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:XLY
