How to make an ice ball maker
 by spcutler
Featured
Do you want an ice ball maker like those sold online, but don't have $800+ to spend?  Then make your own!
Don't know what an ice ball maker is, or how it works?  Then check out the last page of this Instructable for a video of it in action.
You'll need access to a machine shop, and specifically a CNC machine.  TechShop provides all the equipment you need for a monthy fee.  I made it at TechShop, and you can too.
Ice ball makers work by melting a large block of ice into the proper shape.  It accomplishes this by having two large blocks of aluminum (aluminum has high heat conductivity and capacity), each with a hemisphere carved into a side, slide together to form a single continuous chamber on the inside.  What's left is a perfect sphere.
Step 1: Materials and Equipment
The basic material is two large blocks of aluminum.  You'll need to pick a size based on the size of the ice ball you want.
You'll need blocks that are in total at least 10 times the volume of your sphere.  This is so the aluminum properly melts away the rest of the block.  My ice ball maker produces 70 mm diameter ice balls, and the aluminum blocks are each 125x125x75 mm.  That's a 13-to-1 ratio, and works pretty well.
You'll also need stainless steel rod.  These serve as the bottom vertical guide shafts.  I used 3/8" SS rod.
Last, you'll need plastic rod of a larger diameter.  This piece slides over the stainless steel rod.  I used 3/4" teflon rod, but teflon turns out to be hard to machine.  I hear that Delrin machines well.
The only extra material is whatever you think will make the final product easy to use.  I added rubber feet and a cabinet knob for lifting the top.
For equipment, you'll need a CNC mill and a lathe, and basic tooling.  The inner hemispheres will be cut with a ball end mill, and you'll want as large a diameter here as possible.  I used a 1" ball end, but smaller diameters will work as well.  You'll also need a tap and die set.
Brian996 says: Jun 19, 2013. 9:24 AM
How long do you have to wait between moulds?
Nuclearpwr says: Jan 31, 2013. 10:27 AM
I am really on a mission to make these really cool ice balls...hope you can help me out here....
I do not have access to any machining equipment and even if I did, I am not a machinist...would you consider making one for me? I would of course pay you for the material, machine time and your time.
Thanks again,
Marko in Mass
Nuclearpwr says: Jan 31, 2013. 10:21 AM
You are my hero. I've been trying to make clear ice balls for a while and your post does it all...clear ice and the ice ball machine...and a whole lot cheaper than the on-line units.
Question : What size piece of clear ice do you need to use in the unit? Does the size of the clear block of ice matter...assuming it is big enough to fill the sphere...and does the shape of the clear block make any difference.
I found a small mini-version of the on-line model and when I use mine, sometime I get flat spots on the ball...and I think it might be because I am using irregular shapes of clear ice...pieces just broken off a larger pc of clear ice.
Thanks again and great instructional video.
Marko
varocketry says: Dec 6, 2012. 4:37 PM
test
ToolboxGuy says: Nov 11, 2012. 10:17 PM
Way cool ! Given that you have a CNC at your disposal, I am surprised that you didn't add any runoff channels/gates, to keep the countertop dry. Since you don't want to corrupt the shape, just make an outer ring around the shape, and an outlet channel.
I would love to make one of these for ice formed whiskey glasses, say four at a time, or perhaps shotglasses in quantity. Shape then freeze until the party. Have to make grips/indents so it doesn't become too slippery.
Perfect for pool parties - and very little to clean up, at least for those of us who drain our glasses.
spcutler (author) in reply to ToolboxGuyNov 12, 2012. 12:06 AM
That's a great idea! I was originally thinking in terms of having a small hole in the bottom that the water could flow through, but that would, as you say, corrupt the shape. And I'll admit, drilling tiny holes in a nearly-finished project always scares me! Your idea with the channels solves both problems. I was already planning on making some more, and I'll be sure to try that out if I do.
One thing to watch out for when refreezing--because there is still a film of water on the surface, you will tend to get marks corresponding to the container you put them in. So it looks a bit imperfect, though after 30 seconds in the glass the marks will melt away.
jayhitek says: Nov 1, 2012. 12:26 PM
Can you post the G Code?
eyong2 says: Oct 30, 2012. 4:34 AM
Hi im from malaysia and Im trying to make an ice ball maker using your steps shown above. May i get more information from you like from "Step 3 Machining the Hemispheres", what sort of sizes of the end mill and ball end mill should i use for the cnc with the DFX file u attached?
Regards
Edmund
spcutler (author) in reply to eyong2Oct 31, 2012. 12:11 AM
My opinion is that it doesn't matter too much, but the larger the better. I used a 3/4" end mill for the roughing and a 1" ball end mill for the final pass. These days, I would use a real roughing mill instead of a standard end mill since there is so much material to remove.
jayhitek says: Oct 22, 2012. 1:03 PM
I will buy one from you.
One. says: Oct 16, 2012. 7:08 PM
I'm not gonna lie, that thing is pretty darn cool. It makes some freaky noises while it's in action, haha
EpicCraftMan says: Sep 19, 2012. 12:32 PM
Well its awsome
EpicCraftMan says: Sep 19, 2012. 12:30 PM
what would happen if you tryed to use strofoam or somthing like that?
captain Jack says: Sep 17, 2012. 8:41 PM
clever!
superpositron says: Sep 14, 2012. 2:30 PM
Hi,
Great stuff. You wrote that aluminum has high heat conductivity and capacity. I was considering milling this in Steel. Do you think steel is just wrong for this?
Many thanks.
spcutler (author) in reply to superpositronSep 14, 2012. 3:25 PM
I would avoid steel for a few reasons. The two big ones are, as you said, heat capacity and conductivity. Per gram, steel has about half the heat capacity as aluminum, so the unit would need to weigh at least twice as much to work as well (it could be a little smaller, though). It also has only a fifth of the heat conduction, so it would work very slowly.
The other big problem, as you might expect, is corrosion. Even without anodization, aluminum doesn't corrode in any significant way in the presence of water. Steel will of course rust if you have no protection on it.
Steel is also harder to work with, and isn't necessarily cheaper when you take the heat capacity into account.
You could use stainless of course, but that's far more expensive, even harder to machine, and only fixes the corrosion problem.
The only other material that I would really consider is copper, and that would be a situation where cost isn't the dominant factor. It's impossible to beat aluminum in bang-for-the-buck terms.
illusionistpro says: Sep 11, 2012. 5:33 PM
Is there a reason you specify a 10:1 ratio of metal to ice?
spcutler (author) in reply to illusionistproSep 11, 2012. 6:36 PM
Warning: geek out alert.
The short answer is that you need enough thermal mass to melt through all the ice, and 10:1 is about the right amount.
Long answer:
To melt ice, you need to get through what's called the latent heat of fusion. For ice/water, this is 334 joules/gram. The density of ice is 0.917 g/cm^3, so this comes to 306 J/cm^3
This heat comes from the aluminum (in the short term). Aluminum has a heat capacity of 0.9 J/K-g, so at a density of 2.7 g/cm^3 we have 2.43 J/K-cm^3. Room temperature is 25 C, and we can only go down to 0 C before it stops being able to melt ice. Therefore, the aluminum can supply 61 J/cm^3 of heat energy to melt the ice.
306 J/cm^3/61 J/cm^3 is just about a 5:1 ratio. But that's a bare minimum: the ice ball maker works very slowly when it gets close to 0 C, and the ice will start at a temperature <0 C (depending on how cold the freezer is), and there are some extra holes and such that take away some capacity. So in practice we need a little extra leeway, and 10:1 makes for a nice round number.
firesirt says: Jun 23, 2012. 9:14 PM
this is awesome. I think I might try something like this, only casting the aluminum rather than cutting it.
spcutler (author) in reply to firesirtJun 24, 2012. 12:11 AM
Good luck, and let me know how it turns out! My first thought is that the surface wouldn't be smooth enough. But on the other hand, the surface of the ice ball melts fairly quickly and would probably leave a nice surface in short order. So it might actually work really well. Have fun!
r_harris2 says: Apr 12, 2012. 5:02 PM
Very interesting project. You know, this could be done on a lathe, even a manual one. You could either make a custom cutter, or build a radius-cutting attachment. Then mount the block on the lathe faceplate (or 4-jaw if you have a big enough one). I think a block of this size could just barely be mounted on a mini-lathe's faceplate.
blastin06 says: Jan 19, 2012. 10:10 AM
I think this is an awesome project and I commend you on all the work and learning you did. With that being said, for future possibly since you have to use a CNC anyways why not use a CNC lathe and turn multiple steps into two or three. Using a three jaw chuck you could use a round stock, shave the sides, face off the front and also cut the sphere shape. This all could be done in one step and most likely with out the use of a CAM package. Leaving the guides to be drilled on a knee mill.
spcutler (author) in reply to blastin06Jan 19, 2012. 1:20 PM
Unfortunately, I don't have access to a CNC lathe. TechShop has several CNC machines, but a lathe is not one of them--they just have manual lathes (with DRO displays).
If I make another I may try out using round stock. It's actually pretty hard to make a perfectly square block, even on a good mill!
Thanks for the support!
imatoymaker in reply to spcutlerJan 19, 2012. 11:33 PM
My compliments on an excellently designed and well made part... but actually making a "perfectly square block" is rather easy. I have been a machinist for 30 years and can do it on even the most humble mill. Good setup and one little trick is all you need. As long as your vise is flat to the table travel in the x & y axis, it's solid jaw parallel x axis, and the spindle & solid jaw are perpendicular to the table it can be done in 7 steps with 3/4 ball with a flat on it and a parallel. I have won many drinks proving it. Maybe I should do an instructable on it if there is any interest. Or maybe just for the fun of it. Just not sure this is the right forum to post on.
Ogredude in reply to imatoymakerApr 8, 2012. 10:08 AM
I'd *LOVE* to see an instructable on this! The only mill I have access to at my friend's house is definitely a very humble mill.
spcutler (author) in reply to imatoymakerJan 20, 2012. 12:14 AM
I would love to see an instructable on it, and think it would be quite popular with folks like me who like to do machining as a hobby but don't have the decades of experience to pick up tricks like what you described.
I managed to do the first 4 sides without much trouble but the final 2 sides were more difficult. I ended up fiddling around with an L-block (is there some better name for that?) to get a side perpendicular to both axes, but I'm sure there's a better way.
mikejs says: Feb 6, 2012. 12:05 PM
New goal: get a 3D scan of my head, and then mill that into some aluminum. Perfect ice faces, every time. Thank you!
skrubol says: Jan 26, 2012. 9:36 AM
Why is squareness of the material important? To me, the whole operation of milling the face flat, cutting the hemisphere and boring the alignment holes should be able to be performed without re-mounting the workpiece. As long as you can hold the piece down securely without interfering with any of the cuts, the shape of the piece shouldn't matter.
spcutler (author) in reply to skrubolJan 27, 2012. 2:38 AM
You are almost certainly correct, and I mostly blame my inexperience.
One small problem is that the CNC machine is only available in 4-hour increments. Although with an optimized process I probably could have finished a full block in that time, with me learning as I went it took much longer than that. Given this, and the fact that I needed the blocks to be square in the end anyway, I decided to make that the first step in the process.
If I do it again, I'll probably look into doing the squaring, planing, hemisphere boring, and drilling all in one pass.
skrubol in reply to spcutlerJan 27, 2012. 6:05 AM
Well that makes sense.. Making something square is challenging for a novice machinist, so it's a worthwhile thing to try to do even if it's not necessary.
big-jamie says: Jan 24, 2012. 3:31 AM
that is absolutely gorgeous, the mould and the finished ice ball. i really wish i had access to a cnc machine =(
rimar2000 says: Jan 18, 2012. 7:11 PM
Beautiful ice ball!
A doubt: the holes in the photo of step 5 seems out of phase. It is to say that joining the hemispheres, the holes don't match. Does you changed them?
spcutler (author) in reply to rimar2000Jan 18, 2012. 8:12 PM
Thanks! The holes are actually in perfect alignment, probably less than 0.0005" error. Getting this right was one of the most important steps so I drilled the holes for each half without removing anything from the vice. If the the holes look out of alignment, it is probably a matter of the photo's perspective.
koebwil in reply to spcutlerJan 19, 2012. 3:37 PM
To be fair you did tap the holes which gives you some intrinsic misalignment. If you do another I would suggest using a press fit. Also you mentioned using an edge finder, if you want better accuracy you can swing the block in with a dial indicator, this is commonly done in mold making. Lastly a spot drill will give you much better results than a center drill, center drills are typically just for lathes and due to their shape don't do well in CNC mills, granted your aren't drilling a lot of holes, but you break one of those suckers and it'll ruin your day. I was wondering if you drilled the holes in a separate op or if you were able to get them into your program, I know the tormach doesn't have too much z travel, but even just spotting them in the same setup can give you much better accuracy.
spcutler (author) in reply to koebwilJan 23, 2012. 3:09 PM
I forgot to get to your last question:
Although I didn't incorporate the hole drilling into the program, I was able to use the Tormach for both the hole drilling and tapping. I did this separately from the hemisphere cutting, but that is not a big deal--the hemispheres could be a couple thous off and no one would notice. But each pair of holes did need to be the correct distance apart and so I did those in one step.
If I do make another, I'll see if I can incorporate the drilling into the program. I was using peck drilling since the holes were so deep and there was a lot of volume to remove, and it became quite tedious (and error-prone) after a while.
You're right that there isn't a huge amount of Z travel on the Tormach, but it was sufficient for my purposes, even with my 2" height gauge.
spcutler (author) in reply to koebwilJan 20, 2012. 12:18 AM
True, the tapped holes seems to have some intrinsic amount of wobble. I didn't realize this going in because of my inexperience, but it seems you're right that a press fit would work better.
Thanks for the advice on the spotting drill. It seems that there is some debate as to whether center drills are appropriate for this application or not, but in any case spotting drills are a good choice here.
rimar2000 in reply to spcutlerJan 20, 2012. 4:39 AM
Pardon, I am an old fool man.
I saw the pieces simply rotating around a vertical axis, the holes do not match, but I realized now that as they are perfectly symmetrical, you also have to rotate them horizontally.
codongolev says: Jan 23, 2012. 12:50 PM
where did you get the perfectly clear ice?
spcutler (author) in reply to codongolevJan 23, 2012. 2:54 PM
See my other instructable here for a tutorial:
http://www.instructables.com/id/How-to-make-crystal-clear-blocks-of-ice/
I've since made a "quad" unit that can freeze 4 blocks at once, each the correct size for use with the ice ball maker.
didgitalpunk says: Jan 19, 2012. 3:08 PM
would it not work better if it was copper?
just wondering cause it has a better heat conductivity than aluminum
spcutler (author) in reply to didgitalpunkJan 20, 2012. 12:22 AM
Copper would definitely beat aluminum in the heat conduction department, and be beautiful to boot--the main trouble is that it's so expensive! I also can't find it in the sizes I'd need; 5" square or round bar. I'm sure it exists but not at the places I've looked at so far.
I did make a nice copper cylinder on the lathe as part of a mini element collection. It's the prettiest element of the ones I have to far, and nice and dense too--although tungsten beats it there!
Skymeat in reply to spcutlerJan 22, 2012. 6:16 PM
I think you might have nailed it on the aluminum...Copper is a pain in the ass to keep clean. Tarnished Aluminum just looks a bit dull..
didgitalpunk in reply to SkymeatJan 23, 2012. 1:03 PM
true enough XD copper is so anoying to keep clean but you can plate it with zinc and it won't oxide anymore and the heat transfer won't be much affected by the microscopic coat of zinc.
at least i think so.
didgitalpunk in reply to spcutlerJan 20, 2012. 11:30 AM
Tungsten conducts heat better than copper?
That I did not know!
Anyway nice instructables man!
nickmh in reply to didgitalpunkJan 22, 2012. 11:50 PM
It doesn't, he meant it's much denser than copper. Tungsten is nearly twice as dense as lead.
didgitalpunk in reply to nickmhJan 23, 2012. 10:32 AM
hoo yeah i misread there ^^ thx!
codongolev says: Jan 17, 2012. 11:26 AM
this would make an awesome or awful weapon in a snowball fight depending on how you look at it.
William930 in reply to codongolevJan 19, 2012. 10:35 PM
you mean weather its flying toward you or away from you?
codongolev in reply to William930Jan 23, 2012. 12:49 PM
yeah. I mean, I know there's "that kid" in every snowball fight that packs ice in the center then swears he didn't know it was there, but having an arsenal of pure ice balls would take it to a whole different level.
Junkbots says: Jan 23, 2012. 9:30 AM
Any chance that you'd take this upscale for resale? The commercial ice ball makers sell for ~$1000, and yours seems to be fairly similar (albeit made with aluminum). Once the process is down it seems fairly trivial to make a lot of these, given that the material costs aren't that high. I'd love to get my hands on one of these, but $1000 is a bit steep, and I don't have a metal working shop close by.
carnyboy says: Jan 19, 2012. 4:20 PM
How is this cheaper than just buying an 800 dollar mold? I mean how many people have access to a CNC machine? Nifty project that you accomplished but I don't really feel this is acessible or practical for the average home builder.
1 cent alternative: Fill balloon with water, freeze in bowl to retain a relatively spherical shape, remove balloon and form into a sphere by melting the outer layer and moulding with your hands in a bowl or bucket of water.
Gordon Gekko in reply to carnyboyJan 21, 2012. 2:52 PM
Not every instructable has to be accessible to every builder. I think it's a pretty nifty project and for those of us with CNC capability, you could probably get this done for $100-150.
Plus these ice balls are primarily used for high end liquor, and I don't really want to use "balloon" ice in my scotch.
Junkbots in reply to Gordon GekkoJan 23, 2012. 6:42 AM
Not only would balloon ice not be perfectly spherical, you can't make it crystal clear. It'll be foggy as heck, which in my opinion, does not look as good as crystal clear ice. The only realistic way to make perfectly clear ice spheres is this melting method as there's no practical way to freeze water into a perfect sphere and keep it clear.
Check out spcutler's other instructable on how to make clear ice, although you can use a regular cooler in a pinch.
spcutler (author) in reply to carnyboyJan 19, 2012. 4:43 PM
Everyone who lives near a TechShop has access to this equipment! For a membership fee they provide all kinds of CNC equipment and more. Even if you include the membership and class fees, this device cost less than $300. However, that number is an overestimate because I was able to use TechShop for other projects, and I only had to take the CNC class once.
I have tried the molding technique but the results are inferior. The only way I've found to create clear ice is the way I described in my other instructable (linked on the last page). There is no way to use that method for an ice ball; the best you can do is a cylinder. And you'll never get close to a perfect sphere with your hands.
I won't claim that this device is practical for most people, but for anyone interested in CNC machining, I'll say that this is a fun project to start with and gives quite good looking results.
Junkbots in reply to spcutlerJan 20, 2012. 8:03 AM
How much was the block of aluminum you used?
spcutler (author) in reply to JunkbotsJan 20, 2012. 3:29 PM
I purchased the metal from onlinemetals.com, and at the time I paid $33 for each half, including the cutting costs. This was after a 10% discount for having a $100 order.
There are cheaper sources than OnlineMetals, but they are convenient, have an excellent selection, and haven't let me down yet.
Lynn Livingston says: Jan 21, 2012. 6:31 AM
I would like to look at the CAD files but I can't open them. I am using AutoCAD 2008, and the program reports either file has no contents. Any ideas?
Thanks.
spcutler (author) in reply to Lynn LivingstonJan 22, 2012. 12:07 PM
My apologies--I believe these are for AutoCAD 2011, and I'd suppose they aren't backwards compatible. Next time I'm at TechShop I'll try to export the models in a common format.
illuminatis says: Jan 20, 2012. 4:21 PM
Needs an insert to make pac-man shaped ice, other than that , very cool.
darthrecneps says: Jan 20, 2012. 8:44 AM
i need one, but i can't seem to think of a reason why....
microfarm says: Jan 19, 2012. 8:42 AM
The video is exceptional! As an artist (potter, silk painter, silver), I am just wondering, what do you do with the ice balls? I love the way the aluminum thingie looks and I think it would make a good cookie jar! N
spcutler (author) in reply to microfarmJan 19, 2012. 1:10 PM
The main purpose is for drinks like scotch and whisky. A large ball is perfect for cooling the drink without diluting it too much. But just as important, the ice looks really nice sitting in a glass!
meg02003 in reply to spcutlerJan 19, 2012. 2:37 PM
I am sure this is not of too much concern considering and would be hard to show has any effect but aluminum aint the best for the body. Maybe a SS insert into the aluminum block. This way the aluminum is not all up in ya Ice. Like I said not a big concern for some folks but for me I would want my ice nice an hippie approved.
scooke2112 says: Jan 19, 2012. 1:27 PM
Slainte! :)
Londonbrig0 says: Jan 19, 2012. 12:28 PM
So cool! How much does the top half of the mold weigh? Looks like the video is in real time, and it does the job pretty quickly.
spcutler (author) in reply to Londonbrig0Jan 19, 2012. 1:22 PM
Whoops--I had a little error in my math! Each half actually weighs 3 kilograms, or 6.5 pounds.
spcutler (author) in reply to Londonbrig0Jan 19, 2012. 1:17 PM
The top weighs about 1.1 kilograms, or 2.4 pounds, and the bottom weighs the same. And yes, the video is in realtime. It would go a little faster if I ran cool water over it, but it's fast enough for me.
joeuhlik says: Jan 19, 2012. 10:31 AM
What temperature do you heat the aluminum up to before making an ice ball? Nice work.
spcutler (author) in reply to joeuhlikJan 19, 2012. 1:18 PM
Room temperature is fine, but after making one ball it gets pretty frosty, so if I need more than one I run it under cool water.
bgepp1 says: Jan 19, 2012. 8:56 AM
this looks very very cool but also very expensive - how much did this project cost all together if I may ask?
spcutler (author) in reply to bgepp1Jan 19, 2012. 1:13 PM
Excluding the TechShop membership fees and my time, the cost was probably around $80: $60 for the metal and $20 for the rods/misc components. So quite a bit cheaper than the ones sold commercially!
Of course, it took me probably a couple dozen hours total, so there's that. But I don't count that since I was learning the whole way and really enjoy it as a hobby.
ShamWerks says: Jan 19, 2012. 8:33 AM
I love it, congratulations!
By the way, CNC is not the only way to make the hemispheres ; a radius turner tool or ball turner tool) and a lathe can achieve the same goal.
spcutler (author) in reply to ShamWerksJan 19, 2012. 1:09 PM
I'll have to look into that. I am a computer programmer by trade so the CNC stuff comes fairly naturally. But non-CNC machining carries its own satisfaction and I love learning new techniques.
HollyHarken says: Jan 19, 2012. 8:15 AM
Facinating!!! The Techshop information is wonderful. I didn't even know such a place existed. Thank you so much for providing that information. I wanted to make the wonderful cutting board using the ible that wholman wrote. Now I know where I can go to do it.
spcutler (author) in reply to HollyHarkenJan 19, 2012. 1:08 PM
Yes, TechShop is an awesome place. In fact, part of the reason I posted the link is because TechShop gives free classes to anyone that posts an instructable of something they made there.
Full disclosure: I am actually an investor at TechShop. I really believe in what they do, because I've always loved working on projects like this, but have always been limited in equipment.
ColumbusGEEK says: Jan 19, 2012. 6:18 AM
Was the video at the end done in time lapse or full speed?
and finally, what does one do with such a large ice ball after this is all done? Looked a bit too big for my whiskey glass. :)
askjerry in reply to ColumbusGEEKJan 19, 2012. 7:47 AM
Get a larger whiskey glass.... grin.
spcutler (author) in reply to askjerryJan 19, 2012. 1:05 PM
Exactly! I ended up buying some stemless wine glasses. They are just the right size for the ice balls, and the curved inside allows the ball to roll around nicely inside.
osbock says: Jan 19, 2012. 6:36 AM
beautiful! Do you heat the blocks before you put the ice in? It looks like it goes pretty fast.
spcutler (author) in reply to osbockJan 19, 2012. 1:03 PM
Yep, the whole melting process takes only about a minute an a half. The blocks start at room temperature, but end up pretty chilly, so if I need to make more than one ice ball I have to run cool water over it to bring it back to room temp.
Ugifer says: Jan 19, 2012. 1:03 PM
That's amazing!
Is it really that fast - less than 2 mins to form a ball - or did you speed up the vid? If you did, it's a very smooth edit!
Great idea, beautiful execution and stunning ice balls! What's not to like?
rfakhre says: Jan 19, 2012. 11:23 AM
i still don't understand what the ice ball is for.
tastewar says: Jan 19, 2012. 10:21 AM
I'd honestly never heard of an ice ball maker before, but if they're anything like what you've done here, it's no wonder they would cost upwards of $800!!
ocaptain says: Jan 19, 2012. 8:55 AM
For those of us without a TechShop nearby and REALLY want one of these, anyone willing to make a few and put on eBay or do a direct sale?
agis68 says: Jan 19, 2012. 8:33 AM
Great Job...!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
bennelson says: Jan 19, 2012. 6:49 AM
Hmm, what to do with an ice ball? How about this? http://www.youtube.com/watch?v=hFafcjA_p7E
benq says: Jan 18, 2012. 1:06 PM
COOL
ironsmiter says: Jan 18, 2012. 1:27 AM
Wonder how well that'd fire from an ice cannon (http://sonium.blogspot.com/2009/08/dry-ice-canon-fun.html)? :-)
Any attempts at using non-aluminium metals? Brass should be good too.
Curious because the ice seems pretty melty when you take it out.
A mold with a slightly lower thermal conductivity SHOULD work just as well for forming, but slower.
My thinking is that way, more of the melting would be done by pressure, rather than the heat wicking of the alu block.
And, this one is purely aestetic, but a freshly milled block of metal, on high end metal working tools(cnc mill, right?) and you put a mass-produced drawer pull on top?
Love the finish you got on the inside. Finish cut with a ball mill? or is there a super secrete method that We'll have to discover for ourselves?
spcutler (author) in reply to ironsmiterJan 18, 2012. 12:58 PM
Thanks for the input!
I haven't experimented with other metals. Aluminum is cheap and easy to work with, plus I'm really very new to machining so I tried to stick with what I know. I'd love to see someone try something different!
A slower melt might actually be really beneficial. I found that if I use ice straight out of the freezer, I sometimes get cracks due to the thermal shock. This isn't a big deal for cloudy ice, but for the clear ice I use it partially ruins the effect. My solution was to put the ice in the fridge for a bit to warm it, but a metal with higher thermal conductivity would probably work also!
The ice isn't really melty, though; it just looks that way because of the film of water on the surface. It's actually super-smooth.
I can't deny that I cheesed out with the drawer pull :-). If I come up with something better, I'll update the pics. I need more practice on the lathe...
There's no secret for the inside--it's just a large diameter ball end mill. It worked better than I was expecting! Lots of passes, though; it took a few hours for each side. I used a Tormach PCNC1100. I've thought about polishing it further, but it's really not necessary; the ice balls come out perfectly.
l8nite says: Jan 17, 2012. 9:27 PM
thats wild
codongolev says: Jan 17, 2012. 11:18 AM
I think it would be cool (no pun intended) if you added a rack and pinion gear to one of the guide rods, then made that spin a fan on the top that was positioned over heatsink-style fins. that way, the thing would absorb a bit of heat every time you used it, and it would still be electricity free.
that's extremely complicated and unnecessary, though. but what can I say, I'm studying to be an engineer.
great build.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
