How to Make an Upcycled Scarf Skirt
Introduction: How to Make an Upcycled Scarf Skirt
Here's a step-by-step on how to make an inexpensive scarf skirt (like those head scarves your mammie or grammie used to wear when she was in the convertible...think Thelma and Louise) and a pair of old jeans (or any kind of pants!).
If you like this, please vote for me on the 2013 Fashion Contest!
Step 1: What You Need
Scarves - I prefer the longer, rectangular ones, but you can just as well do the large square ones. I used 4 and cut them in the middle. I picked these up for $1 each at the Goodwill.
Pair of old pants or shorts
Sewing machine (you can do it by hand but it would take a while)
Straight edge, chalk and cutter (optional)
Step 2: Layout, Pin and Sew
Layout the scarves in the order you want and pin them right sides together.  I did two sets of four scarves to make it easier to manage, then sewed them all together to make my scarf circle.
Make sure you put a lot of pins in the silk scarves, as they slip a lot when sewing.
Step 3: Straight Edge Cut and Gathering the Skirt
Use your straight edge to cut the scarf skirt evenly over the top before gathering the skirt.
Gather the top on the skirt, either by hand or machine.
Step 4: Cut Your Pants!
Using your straight edge, cut your pants using the pockets in the back and the bottom of the zipper in the front for a guide.
Step 5: Pin, Pin, Pin and Sew
Since I wanted the raw edge of the jeans to show on the outside, I pinned and pinned and pinned the scarf skirt to the inside of the cut pants.  Since the scarves are already hemmed, there was no need to hem the bottom.
Next, sew the skirt to the cut pants.  I found it to be more secure to do a double stitch - my first stitch was straight, then I used a decorative stitch for my second stitch.
Step 6: Try It on and Wear It Out!
Just don't wear black socks with it. :)
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    Cool! I like the idea! Wonder what would happen with ties..?
    If you want to do something like this with men's ties.
    1. You will serve yourself by opening up the seam down the back of the tie, remove the shaping/stiffing. Square off the ends by first laying your ties out. Placing the first tie flat after pressing and lay the next one going in the opposing direction (ties are all cut on the "bias".) I used to make throw pillows this way.
    Stitch them down the long side until you have enough to go around the person at about the hip line. Mark a straight line across the top and bottom, and trim away the excess. Hem one end of your created fabric and stitch the other onto the Blue Jeans or Shorts.
    OPTIONAL: You can get an interesting effect if you place two going one way and the third one between a set of two (2). Then when you hem you could square and do straight or have pointed ends on the bottom, or 2 pointed and the narrow one hemmed straight across would give you another effect. This will make the bottom fuller than across the hips where you attach to the Blue Jeans or Shorts. Personally I like this ffect that
    I would look for ties at yard sales rather than thrift shops to do this. Usually cheaper.
    Be selective of type of material..... silk and some kind of blend. Don't mix linen, or wool with silk. Polyester/Silk best choice for washable. The tag on ties usually tells fiber content. Rayon I personally won't mess with.
    Thank you! My next project is a tie skirt. I have seen several tutorials on here with them. Some people use them as is while some seam rip them, unfold them and iron them. To me, that would defeat the purpose. I just know that ties are 1.00 a piece and I would have needed more than the 4 handkerchiefs (at .50 each). Money-wise it was cheaper with the handkerchiefs. ;)
    Very cool! I have some silk scraps I think I might try this with!! :)
    it was a grab-bag, 'swap' type thing and there isn't enough of any one piece to do much with...until now!
