3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make (and connect) a soft potentiometer
This instructable will tell you how to make and connect a soft potentiometer to a microcontroller, in particular we will connect it to a Lilypad Arduino. In our case soft potentiometer means a potentiometer made of a textile conductive ribbon.
What you need:
1. soft conductive textile ribbon. The important thing here is that the tape must have some resistance along its leght. So if you apply a multimeter you should be able to measure a value like 3 Kohm per 10 inches of lenght or something similar.  You can make your own tape, or buy it on www.plugandwear.com. You can also buy the complete kit on www.plugandwear.com.
2. One metal necklace toggle clasp (we will use only the ring). Check if it is conductive before using it. We will call this item 'cursor'. A cursor is the sliding part of a potentiometer.
3. A lilypad Arduino, or another type of microcontroller.
Step 1Assembling the soft potentiometer
Cut a 5" (12 cm) piece of resistive tape. If you want your cursor (the toggle clasp) to travel longer, cut a longer piece. Insert one end of the smaller piece of tape it into the larger ring of the toggle clasp and wind it twice around the ring.
Sew very tight, for best conductivity.
Now insert one end of the longer piece of tape into the smaller ring of the toggle clasp. The tape surface must touch the inside of the ring.
Your potentiometer is now ready to be connected to a microcontroller!
6 comments
Sep 19, 2010. 2:05 PMChuckWoodchuck says:
Interesting! It might be a little clearer to those with an electronics background if you referred to at as the "wiper" (the name of the equivalent bit on a "hard" potentiometer) rather than the "cursor".
You also need to take into account the resistance of the conductive tape that you're using in the wiper as it will affect how your pot interacts with what you connect it to. The real circuit diagram of your widget is:
Jun 7, 2010. 11:47 AMkelseymh says:
You've got an empty "Step 1," which you might want to just delete :-) This is very nice. I was a bit confused by what you meant by "cursor." It might help to have a step where you show the pot in use, connected to a multimeter, perhaps? Show the sliding ring (cursor) in different positions, with the meter reading for each position.
Jun 8, 2010. 9:46 AMkelseymh says:
Theory is great! Thanks very much for adding the information; I think it will help people understand bette what's going on. If you are open to more additions, you might consider putting the "theory of operation" stuff in a separate step, either right after the intro, or better, at the very end (so people can skip it easily if they want to).
Jun 8, 2010. 4:39 AMtroykyo says:
Very amazing!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:rmarchesi
Electronic engineer with 25 years experience in textiles. Currently working on interactive fabrics.
