This project is a simple and cheap way to integrate renewable energy into your home by turning your appliances into solar electric hybrids. Here is how it works. A solar panel (or any other renewable power source) charges a storage battery. A control circuit continuously monitors the battery's voltage. When the battery is fully charged, the circuit automatically turns on a power inverter and switches the appliance from running on grid power to running on the energy stored in the battery. Then when the battery's voltage drops too low, the circuit automatically switches the appliance back to grid power until the battery is recharged.
This design doesn't require any modification to the appliance or your home's electrical system. It can work with any power source that is capable of charging a 12V battery (examples: wind turbines, bike generators, etc.). But most importantly the system is scalable. This design is set up for outputs of up to 75 watts, but by swapping out parts for ones with higher power ratings you can power larger appliances or multiple smaller appliances at the same time. This lets you build a system that fits your energy needs and your budget.
I am still trying to make improvements to the design. So if you have any questions, problems or suggestions please leave a comment. I would really appreciate the feedback.
Step 1: System Overview
1. 12V Solar Panel (or other renewable power source)
2. 12V Rechargeable Battery
3. Control Circuit
4. 12V Power Inverter
5. Automatic Switching Circuit
When assembled, the solar panel, battery, and inverter plug into the control circuit. The automatic switching circuit plugs into the inverter and the wall outlet. Then the appliance plugs into the automatic switching circuit.
The solar panel, battery, and inverter may be purchased off-the-shelf from a variety of locations. The last two parts of the system (the control circuit and the automatic switching circuit) will need to be constructed. This is detailed in later steps.
Step 2: Choose a Solar Panel
Keep in mind that other power sources can be used in place of the solar panel. Wind and bicycle generator could also work well. They just have to be capable of charging a 12 volt battery.
Step 3: Choose a Battery
I am using a 7Ah battery to power a 13 watt CFL lamp for my finch aviary. This seems to work well. If you are confused about which battery to buy, it might help to consult the battery expert at your local store. They should be able to recommend a battery for your application and budget.
Step 4: Choose a Power Inverter
Step 5: Control Circuit Materials
Printed Circuit Board (Radio Shack #276-170)
2 x Diode (Radio Shack #276-1103)
+5V Fixed-Voltage Regulator (Radio Shack #276-1770)
555 timer IC (Radio Shack # 276-1723)
MPS2222A NPN Transistor (Radio Shack #276-2009)
IRF510 MOSFET (Radio Shack # 276-2072)
100µF 15V Capacitor (optional)
2 x 0.1µF 15V Capacitor (optional)
2 x 10K-Ohm 15-Turn Cermet Potentiometer/Trimmer (Radio Shack #271-343)
100-Ohm Resistor (Radio Shack #271-005)
330-Ohm Resistor (Radio Shack #271-012)
1K-Ohm Resistor (Radio Shack #271-004)
12VDC/125VAC 10A SPDT Mini Relay (Radio Shack #275-248)
12VDC Vehicle Power Accessory Outlet (Radio Shack #270-046)
Project Enclosure (6x3x2") (Radio Shack #270-1805)
2 x bolts (1/4" or smaller)
2 x nuts (1/4" or smaller)
2 x 1/4" Fully Insulated Female Quick Disconnects (Radio Shack #64-3133)
2 ft. x 16 guage wire
Jumper Wires
Optional Charge Controller Materials:
Tools:
Soldering iron and solder
Screwdriver
Multimeter
Crimping tool (for quick disconnects)
Drill and Drill Bits
Wire Strippers
Knife
Part Substitutions:
I chose these parts because they are easily accessible (most can be purchased from Radio Shack). However, all of them may be substituted for other parts with similar values. You can generally find them cheaper online. The four 10k 15-turn trimmer potentiometers may be replaced with single turn potentiometers or fixed value resistors. I chose these potentiometers because they are much easier to make fine adjustments when calibrating the circuit. The input diode can be replaced with a schottky diode for better performance. It may also be omitted if your solar panel has a built in blocking diode.
Step 6: Control Circuit Design
This circuit is a modified version of a charge controller circuit that was designed by Mike Davis (http://www.mdpub.com/555Controller/index.html). In the original circuit, a 555 timer IC was used to disconnect a battery from the solar panel when its voltage gets too high (to prevent it from over charging). In my design, the control circuit connects the battery to an inverter and an output circuit when the battery is fully charged.
Here is a brief description of how the circuit works. A 5V voltage regulator powers the 555 timer IC and sets its internal reference voltages. A pair of potentiometers (variable resistors) are set up as voltage dividers that provide a signal to the timer IC that is proportional to the battery's voltage. These signals determine the operating range of the system. As the battery's voltage rises and falls, so does the output signals of the potentiometers. When the signal at pin 6 rises above 3.3V, the output of the IC goes LOW and activates the relay through a series of transistors. When the signal at pin 2 falls below 1.6V, the output of the IC goes HIGH, which deactivates the relay. By setting the positions of the potentiometers, you determine at what voltages the battery must be to activate and deactivate the output.
Alternate Design with Charge Controller
A charge controller usually isn't required for this setup. If the output of your solar panel is small relative to the storage capacity of your battery and you are powering a device that is frequently turned on, then you generally don't need to be worried about over charging the battery. However, if you wish to use a charge controller, you may attach one between the solar panel and the control circuit. I have also provided an alternate circuit design that includes a charge controller built into the control circuit.
(A larger version of the images can be viewed by clicking on the image once to zoom in. Clicking on the image a second time takes you to the image page where you can select "ORIGINAL" for a much larger version)
Step 7: Preset the Potentiometers
Basic Control Circuit Design
Potentiometer connected to pin 2: 8600⦠between wiper and the positive rail, and 1400⦠between wiper and the negative rail.
Potentiometer connected to pin 6: 7200⦠between wiper and the positive rail, and 2800⦠between wiper and the negative rail.
Potentiometer connected to pin 2: 8700⦠between wiper and the positive rail, and 1300⦠between wiper and the negative rail.
Potentiometer connected to pin 6: 7500⦠between wiper and the positive rail, and 2500⦠between wiper and the negative rail.
These will not be the final calibrated values. These are just convenient starting locations to get you in the ball park. The final settings will depend on the specific battery that you are using and its recommended operating range. When making the final adjustments, it is helpful to use a power supply with an adjustable voltage regulator such as a LM317T (Radio Shack #276-1778). See the following step for an example. If you don't have access to an adjustable power supply it will take a bit of time tweaking the values and checking it with a multimeter while the system is in operation.
Step 8: Control Circuit Assembly
If you are using the same boards that I am, you can just copy my layout. The PCB is a bit longer than it needs to be for this circuit. To trim off the excess, use a sharp knife to deeply score a line across the board through one column of holes and break it off along the line.
Step 9: Automatic Switching Circuit Materials
Project Enclosure (3x2x1") (Radio Shack #270-1801)
125VAC/10A DPDT Plug-In Relay (Radio Shack #275-217)
8 x 1/4" Fully Insulated Female Quick Disconnects (Radio Shack #64-3133)
1 full extension cord with male and female ends
1 power cord with male end only (preferably a different color than the extension cord)
Tools:
Wire Strippers
Crimping Tool (for quick disconnects)
Knife or Dremel (for cutting housing)
Step 10: Automatic Switching Circuit Design
When the device is inactive, your appliance will be connected to the wall outlet and powered by the grid as it normally would be. The only difference is that it is going through the relay. But when the device is activated, the inverter turns on and sends power to the normally open contacts and the coil. This switches the relay. The appliance is disconnected from the wall outlet and connected to the inverter. This is how the switching circuit will automatically switch to your renewable power source whenever it is available.
Step 11: Automatic Switching Circuit Assembly
Cut a 3 inch section off the end of the inverter power cord. This will be the jumper between the coil contacts and the normally open contacts on the relay. Strip 1/2 inch of insulation from the ends of all the wires. Twist together the exposed ends of the inverter cord and the 3 inch section that you just made and crimp them into a single pair of quick disconnects as shown in the picture. Then crimp quick disconnects onto all the remaining wire ends. Connect the output line (female end of the extension cord) to the common terminals. Connect the grid input line (male end of the extension cord) to the normally closed terminals. Lastly, connect the first set of quick disconnects on the inverter input line to the coil terminals and connect the second pair quick disconnects to the normally open terminals.
Step 12: Project Housing Modifications
The cables from my solar panel have clamps on the end. So I decided to use bolts as the attachment points on the control circuit housing. For this, I found a pair of bolts and nuts that fit the clamps. Then I drilled holes in the side of the housing that were a little smaller than the bolts and screwed the bolts into the holes. The nuts were threaded onto the bolt inside the housing. This will make the attachment point for the wires inside the housing.
Holes for Wires
Because so many quick disconnects are used on wires that go into the project enclosures, it would be inconvenient to feed the wires into the enclosures through drilled holes. Instead, I found it easier to just cut small slits in the side of the enclosure where the two halves come together. Do this for all the wires that go through the walls of the enclosures.
DC Power Outlet Hole
Drill or cut a 1 3/32" hole in the side of the housing for the control circuit. Since this is an odd size, you will probably have to drill a 1" hole and widen the hole with a file or knife. Insert the DC power outlet into the hole. If it doesn't fit tightly, you can secure it in place with glue.
Step 13: Optional Testing With a DC Power Supply
Step 14: Finished Assembly
Attach the clamps from the solar panel onto the bolts on the control circuit housing. Then attach the input wires on the control circuit board to the bolts on the inside the housing and tighten the nuts to hold them in place. Attach the battery lines on the control circuit to the corresponding battery terminals. Be careful not to mix up the positive and negative wires! You probabably want to label them or color code them. Attach the output lines on the control circuit to the DC power outlet. Be sure to attach the positive wire to the center pin and the negative wire to the outer barrel. Once everything is in place, close up the housing and screw it together.
Attach the inverter by plugging it into the DC power outlet. Put the Automatic switching circuit into its housing and close it up. Then plug the inverter power cord into the inverter. Plug the appliance into the output line. If the battery was fully charged, the appliance. should be powered. Lastly, plug the wall outlet power cord into a wall outlet.
Carefully observe all the parts of the system to make sure that nothing is making any weird sounds, smells, or is catching on fire. If not, you have a functioning solar electric hybrid adapter.
Step 15: Final Notes and Future Design Improvements
The operation of this device involves regularly cutting power and switching to a second power source that may be out of phase. As a result, the output may momentarily fluctuate. This is especially true if your switching circuit uses a relay with a low activation voltage. In this case, the relay might switch before the inverter is running at full power. This momentary fluctuation is no problem for simple appliances like a lamp or fan, but may potentially cause problems for sensitive electronics. So choose your appliances carefully. I am not responsible if you fry your computer.
The biggest problem with this design is that the device activates as soon as the battery is fully charged. This does not necessarily coincide with when the appliance is turned on. Even if no appliance is on, the relays and the inverter will still consume power. This can waste electricity if you are powering a device that is not regularly on during the day.
In a future design, I will combine the various parts of this project into a single unit that has a sensor to determine when the appliance is turned on. Only once the appliance is turned on will the control circuit activate the relays and the inverter. This will help ensure that less power is wasted.
I would also like to add something to the circuit to smooth the output of the system to avoid the power fluctuations mentioned above. This might be something as simple as adding a time delay on the switching circuit.
If you have any suggestions for improvements please leave a comment and let me know.
Visit Our Store »
Go Pro Today »
If I understand it correctly, it seems like an always "on" setup, meaning that when the batteries are topped off, you'll use battery power. Once the battery reaches "low", it switches to the power on the mains from the electrical company.
The relay switches is what controls the path the electricity takes.
Couldn't the problem that "involves regularly cutting power and switching to a second power source that may be out of phase", be solved by adding a UPS backup after the automatic switching circuit and before the light bulb? (as shown in your diagram)
- U
Every time, I kept trying to test the value of pin 2 while the inverter was on, the relay would click and I could not get an accurate reading of the voltage while the system was under load. It was pretty frustrating. The only way to set the low end, was to use up the battery power until it reaches somewhere near 11V and turn the dial down until it clicked off.
But even then, I still don't know what the voltage reading is coming into pin 2.
In addition, it will be tied to the grid so if the battery is full and the solar pannel is generating electricity, it will feed into the grid, and finally, when the grid is down, use the battery (emergency).
Thanks!
I'm also having a hard time with figuring out the orientation of the relay on the breadboard, thanks so much!
http://www.mouser.com/ProductDetail/TE-Connectivity/OUDH-SS-112D000/?qs=%2fha2pyFadui2QAjXzdmwdlJkRYZqifB3R%252baei18HFruUr665Gub%252bLA%3d%3d
I sourced one a bit different but i have to move things around.
We put one on the back porch and the front porch, and bought a cute, very small Kitchen cabinet. We painted the cabinets to match the house and BOOM, we are off and running!
The cabinet was PERFECT because it had two shelves - one for the inverter, and one for the battery. We were using the existing lights - two came with each kit. We hung one set on the back porch, and one on the front porch. So, the battery started charging, and within hours, had lights on the front and back porch!
Our first set of lights blew out most likely about two months later. We went BACK through the instructions, and could find nothing. We tested the solar panel by charging another small battery. It was charging fine. We found something to plug in one of the other ports on the inverter, no issue. So, I went to the store to find bulbs to fit in there; there is nothing else to fit in there that is the correct voltage. ANYWHERE.
So, called HF - and they said, yes, we can send you new replacement bulbs at no charge AND it would take six weeks to get them. What was I going to say but ok. So, new bulbs come, we plug them in - they last two weeks and *poof* they die again. I called again; they said it would take four months this time. They had stopped using those bulbs and that inverter in the kit.
At one point shortly after this, the inverter did die. So we called for a new inverter. Got one after 3.5 months (of course, still waiting on the light bulbs). We hooked up the new inverter. Tested the other parts of it, it seemed to be fine. New bulbs finally came - they worked for less than a day. We gave up on getting more bulbs.
The front porch bulbs lasted nearly a year. Then they died. We never tried to get them replaced. In the meantime, we moved the back panel to our chicken coop, and use a small water pump for emptying out the excess water barrel, if needed, or reuse the water in the yard.
We still use the front porch panel as a trickle charge battery charger for the horse trailer and scooter batteries. But we are not using the inverter.
Is this why you are not buying the kits? Have you ever had similar problems with your inverters? Thanks!!!
Following this rules my 80W inverter works for 4 years... and counting.
On use (nightime) 4 inverters (120+120+80+80 W), sometimes at the same time, but not often.
Only mi first 7Ah battery has been replaced after 8 years duty, because not recharging above 4 VDC. (Similar to the one showed in a picture above).
My battery replacement is mandatory after 10 years duty (that one was a surprise).
An inverter allows you to use a wide range of Energy-Star appliances which are much cheaper than DC appliances, and get more use, and storage, out of your appliances.
With the cost of inverters and the power lost in the process, it seems that eliminating the inverter would be more efficient.
Just thought I would add a little useful info
cheers
Ultra Computers
If it's more than 3 x as expensive, then might as well get three cheaper ones (if space allows)..
it will be cheaper and gives the same output.. or, in other words, it's more cost-efficient...
cheers.. :)
"We have a "be nice" comment policy. Please be positive and constructive with your comments or risk being banned from our site. "
So I'll be nice and ask a constructive question, What is the cost per watt of this system, and what is the power density of the amorphous array? Then there is the matter of the 85 dollar AGM pile that Da Freight is peddling with this thing,, what is the reccomended c/20 rate versus dollar/watt ratio?
These are the real economics of DIY alternative energy.
In regards to your question, I used a 5 watt panel, 75 watt inverter and a 7 Ahr battery and was able to build the system for about $150 using parts from RadioShack. If you order the parts online you should be able build this setup for under $100. As my design lets you select the components that fit your needs, the performance is entirely dependent on the panel battery and inverter that you select.
In Kansas we've been having temperatures of 100 to 105 degrees each day this summer and our utilities bill has gone through the roof. Even if this potential rig cost $400-$500 I would still end up saving money over the course of the summer.
So, then made ââin the design, does not allow a current output over 2A, at the output of the regulator (It's the 1 design, before the all relay switch, that commute the DC and the AC).
Could anyone help me get around this?
Thank you and best regards to all!
My only minor quibble is about the power inverter. All the cheap inverters are "modified sine" which is a +180V/0V/-180V/0V wave that delivers the same amount of electrical power. It works fine for CFL's and most switching power supplies that just make the line voltage DC then work from there, or for resistive loads like incandescent bulbs and heaters (or, even direct line-powered LED light strings). But for transformers (e.g. plug-in brick transformers, and many many appliances) and AC induction motors (e.g. fans, pumps), the modified sine is completely inadequate and leads to lots of waste heat and potential damage to the appliance.
I have been recommending that people instead spend the extra money and get a "pure sine" inverter (I have a 300W Samlex brand that works very well). They are a lot more expensive per-watt, but especially for a small starter system, you really can't realistically use more than 75 watts or so for any appreciable time (that 7AH battery would be dead in in an hour at 75 watts, and realistically should only be run for about 30 minutes or so; a 500W coffee maker would kill it before one pot is done). The pure sine inverter will work fine with all appliances including things that people are likely to use like chargers for phones, iPods, or batteries, laptop power supplies, monitors, TV's, and audio amplifiers.
