Introduction: How to Make Any Home Appliance Into a Solar Electric Hybrid
Picture of How to Make Any Home Appliance Into a Solar Electric Hybrid
This project is a simple and cheap way to integrate renewable energy into your home by turning your appliances into solar electric hybrids. Here is how it works. A solar panel (or any other renewable power source) charges a storage battery. A control circuit continuously monitors the battery's voltage. When the battery is fully charged, the circuit automatically turns on a power inverter and switches the appliance from running on grid power to running on the energy stored in the battery. Then when the battery's voltage drops too low, the circuit automatically switches the appliance back to grid power until the battery is recharged.
This design doesn't require any modification to the appliance or your home's electrical system. It can work with any power source that is capable of charging a 12V battery (examples: wind turbines, bike generators, etc.). But most importantly the system is scalable. This design is set up for outputs of up to 75 watts, but by swapping out parts for ones with higher power ratings you can power larger appliances or multiple smaller appliances at the same time. This lets you build a system that fits your energy needs and your budget.
I am still trying to make improvements to the design. So if you have any questions, problems or suggestions please leave a comment. I would really appreciate the feedback.
Step 1: System Overview
Picture of System Overview
Here are the five basic parts of this system:
1. 12V Solar Panel (or other renewable power source)
2. 12V Rechargeable Battery
3. Control Circuit
4. 12V Power Inverter
5. Automatic Switching Circuit
When assembled, the solar panel, battery, and inverter plug into the control circuit. The automatic switching circuit plugs into the inverter and the wall outlet. Then the appliance plugs into the automatic switching circuit.
The solar panel, battery, and inverter may be purchased off-the-shelf from a variety of locations. The last two parts of the system (the control circuit and the automatic switching circuit) will need to be constructed. This is detailed in later steps.
Step 2: Choose a Solar Panel
Picture of Choose a Solar Panel
The solar panel that I used was a 5 watt model from Harbor Freight. But you can use smaller panels or larger panels. The only difference is that the power output determines how quickly the battery will charge and how often the system will be activated. The only guideline to follow is that you don't want a panel that produces more power than you will use in a day. This would result in wasted energy.
Keep in mind that other power sources can be used in place of the solar panel. Wind and bicycle generator could also work well. They just have to be capable of charging a 12 volt battery.
Step 3: Choose a Battery
Picture of Choose a Battery
When selecting a battery you have some trade-offs to consider. Batteries are more efficient and last longer when they are charged and discharged slowly. It is also best to minimize how deeply you discharge the battery. As a result, bigger batteries will give better performance. But larger batteries are more expensive and take up more space. Deep cycle batteries are better at withstanding the regular charging and discharging experienced as part of a solar electrical system. But deep cycle batteries are also more expensive.
I am using a 7Ah battery to power a 13 watt CFL lamp for my finch aviary. This seems to work well. If you are confused about which battery to buy, it might help to consult the battery expert at your local store. They should be able to recommend a battery for your application and budget.
Step 4: Choose a Power Inverter
Picture of Choose a Power Inverter
The power inverter converts the output of your 12V DC battery into 120V AC that can power home electronics. I am using an 80 watt model from Harbor Freight. The most important requirement for your power inverter is that it must be capable of continuously powering the appliance(s) that you want to run. Inverters generally list their maximum power ratings in terms of both continuous and peak watts. Generally you want to stay a bit under the continuous limit to avoid excessive heating.
Step 5: Control Circuit Materials
Picture of Control Circuit Materials
Control Circuit Materials:
Printed Circuit Board (Radio Shack #276-170)
2 x Diode (Radio Shack #276-1103)
+5V Fixed-Voltage Regulator (Radio Shack #276-1770)
555 timer IC (Radio Shack # 276-1723)
MPS2222A NPN Transistor (Radio Shack #276-2009)
IRF510 MOSFET (Radio Shack # 276-2072)
100µF 15V Capacitor (optional)
2 x 0.1µF 15V Capacitor (optional)
2 x 10K-Ohm 15-Turn Cermet Potentiometer/Trimmer (Radio Shack #271-343)
100-Ohm Resistor (Radio Shack #271-005)
330-Ohm Resistor (Radio Shack #271-012)
1K-Ohm Resistor (Radio Shack #271-004)
12VDC/125VAC 10A SPDT Mini Relay (Radio Shack #275-248)
12VDC Vehicle Power Accessory Outlet (Radio Shack #270-046)
Project Enclosure (6x3x2") (Radio Shack #270-1805)
2 x bolts (1/4" or smaller)
2 x nuts (1/4" or smaller)
2 x 1/4" Fully Insulated Female Quick Disconnects (Radio Shack #64-3133)
2 ft. x 16 guage wire
Jumper Wires
Optional Charge Controller Materials:
Tools:
Soldering iron and solder
Screwdriver
Multimeter
Crimping tool (for quick disconnects)
Drill and Drill Bits
Wire Strippers
Knife
Part Substitutions:
I chose these parts because they are easily accessible (most can be purchased from Radio Shack). However, all of them may be substituted for other parts with similar values. You can generally find them cheaper online. The four 10k 15-turn trimmer potentiometers may be replaced with single turn potentiometers or fixed value resistors. I chose these potentiometers because they are much easier to make fine adjustments when calibrating the circuit. The input diode can be replaced with a schottky diode for better performance. It may also be omitted if your solar panel has a built in blocking diode.
Step 6: Control Circuit Design
Picture of Control Circuit Design
Basic Control Circuit Design
This circuit is a modified version of a charge controller circuit that was designed by Mike Davis (http://www.mdpub.com/555Controller/index.html). In the original circuit, a 555 timer IC was used to disconnect a battery from the solar panel when its voltage gets too high (to prevent it from over charging). In my design, the control circuit connects the battery to an inverter and an output circuit when the battery is fully charged.
Here is a brief description of how the circuit works. A 5V voltage regulator powers the 555 timer IC and sets its internal reference voltages. A pair of potentiometers (variable resistors) are set up as voltage dividers that provide a signal to the timer IC that is proportional to the battery's voltage. These signals determine the operating range of the system. As the battery's voltage rises and falls, so does the output signals of the potentiometers. When the signal at pin 6 rises above 3.3V, the output of the IC goes LOW and activates the relay through a series of transistors. When the signal at pin 2 falls below 1.6V, the output of the IC goes HIGH, which deactivates the relay. By setting the positions of the potentiometers, you determine at what voltages the battery must be to activate and deactivate the output.
Alternate Design with Charge Controller
A charge controller usually isn't required for this setup. If the output of your solar panel is small relative to the storage capacity of your battery and you are powering a device that is frequently turned on, then you generally don't need to be worried about over charging the battery. However, if you wish to use a charge controller, you may attach one between the solar panel and the control circuit. I have also provided an alternate circuit design that includes a charge controller built into the control circuit.
(A larger version of the images can be viewed by clicking on the image once to zoom in. Clicking on the image a second time takes you to the image page where you can select "ORIGINAL" for a much larger version)
Step 7: Preset the Potentiometers
Picture of Preset the Potentiometers
Before assembling the circuit, it is a good idea to preset the potentiometers. This will prevent a lot of troubleshooting later. As indicated in the pictures, the values of the potentiometers should be set to the following:
Potentiometer connected to pin 2: 8600 ohm„ between wiper and the positive rail, and 1400 ohm between wiper and the negative rail.
Potentiometer connected to pin 6: 7200 ohm between wiper and the positive rail, and 2800 ohm between wiper and the negative rail.
Potentiometer connected to pin 2: 8700Ω between wiper and the positive rail, and 1300Ω between wiper and the negative rail.
Potentiometer connected to pin 6: 7500Ω between wiper and the positive rail, and 2500Ω between wiper and the negative rail.
These will not be the final calibrated values. These are just convenient starting locations to get you in the ball park. The final settings will depend on the specific battery that you are using and its recommended operating range. When making the final adjustments, it is helpful to use a power supply with an adjustable voltage regulator such as a LM317T (Radio Shack #276-1778). See the following step for an example. If you don't have access to an adjustable power supply it will take a bit of time tweaking the values and checking it with a multimeter while the system is in operation.
Step 8: Control Circuit Assembly
Picture of Control Circuit Assembly
Always prototype circuits on a breadboard before soldering them onto a printed circuit board. In my breadboard prototype, I included an adjustable voltage regulator so that I could quickly simulate the charging and discharging cycles. This makes it convenient to work out the final adjustments to the potentiometers.
If you are using the same boards that I am, you can just copy my layout. The PCB is a bit longer than it needs to be for this circuit. To trim off the excess, use a sharp knife to deeply score a line across the board through one column of holes and break it off along the line.
Step 9: Automatic Switching Circuit Materials
Picture of Automatic Switching Circuit Materials
Automatic Switching Circuit Materials:
Project Enclosure (3x2x1") (Radio Shack #270-1801)
125VAC/10A DPDT Plug-In Relay (Radio Shack #275-217)
8 x 1/4" Fully Insulated Female Quick Disconnects (Radio Shack #64-3133)
1 full extension cord with male and female ends
1 power cord with male end only (preferably a different color than the extension cord)
Tools:
Wire Strippers
Crimping Tool (for quick disconnects)
Knife or Dremel (for cutting housing)
Step 10: Automatic Switching Circuit Design
Picture of Automatic Switching Circuit Design
This circuit has only one major part: a double pole double throw relay. It is wired in such a way that it will automatically switch the output whenever the inverter is powered on. To achieve this, the input line from the wall outlet is connected to the normally closed contacts and the output line going to the appliance is connected to the common contacts. Then the input line from the inverter is connected to both the coil and the normally open contacts.
When the device is inactive, your appliance will be connected to the wall outlet and powered by the grid as it normally would be. The only difference is that it is going through the relay. But when the device is activated, the inverter turns on and sends power to the normally open contacts and the coil. This switches the relay. The appliance is disconnected from the wall outlet and connected to the inverter. This is how the switching circuit will automatically switch to your renewable power source whenever it is available.
Step 11: Automatic Switching Circuit Assembly
Picture of Automatic Switching Circuit Assembly
Begin by cutting the extension cord into two pieces. The female end will be the output line where the appliance is plugged in.The male end will be the grid input line that is plugged into the wall outlet. The second power cord will be the input line that is plugged into the inverter. You may wish to select a power cord for the inverter line that is a different color than the other cords. This helps prevent mixing up the lines. You may also want to label them.
Cut a 3 inch section off the end of the inverter power cord. This will be the jumper between the coil contacts and the normally open contacts on the relay. Strip 1/2 inch of insulation from the ends of all the wires. Twist together the exposed ends of the inverter cord and the 3 inch section that you just made and crimp them into a single pair of quick disconnects as shown in the picture. Then crimp quick disconnects onto all the remaining wire ends. Connect the output line (female end of the extension cord) to the common terminals. Connect the grid input line (male end of the extension cord) to the normally closed terminals. Lastly, connect the first set of quick disconnects on the inverter input line to the coil terminals and connect the second pair quick disconnects to the normally open terminals.
Step 12: Project Housing Modifications
Picture of Project Housing Modifications
Solar Panel Attachment Point
The cables from my solar panel have clamps on the end. So I decided to use bolts as the attachment points on the control circuit housing. For this, I found a pair of bolts and nuts that fit the clamps. Then I drilled holes in the side of the housing that were a little smaller than the bolts and screwed the bolts into the holes. The nuts were threaded onto the bolt inside the housing. This will make the attachment point for the wires inside the housing.
Holes for Wires
Because so many quick disconnects are used on wires that go into the project enclosures, it would be inconvenient to feed the wires into the enclosures through drilled holes. Instead, I found it easier to just cut small slits in the side of the enclosure where the two halves come together. Do this for all the wires that go through the walls of the enclosures.
DC Power Outlet Hole
Drill or cut a 1 3/32" hole in the side of the housing for the control circuit. Since this is an odd size, you will probably have to drill a 1" hole and widen the hole with a file or knife. Insert the DC power outlet into the hole. If it doesn't fit tightly, you can secure it in place with glue.
Step 13: Optional Testing With a DC Power Supply
Picture of Optional Testing With a DC Power Supply
Since a system that is solar powered is most active in the middle of the day (when many people are at work), it can be inconvenient to do initial testing and observation of the system at work. To get around this, you may wish to use a DC power supply in place of the solar panel for initial testing. The simplest and cheapest way to do this is to use an DC power adapter. Find one that has a operating voltage of about 12V. The open circuit voltage (no load) will usually be a good bit higher. The exact type doesn't matter. You probably have a suitable DC power adapter lying around your house somewhere. You may wish to add a capacitor between the positive and negative terminals if the power supply doesn't have a steady output. Connect the positive wire from the power supply to the positive terminal of the control circuit and the negative wire to the negative terminal of the control circuit. This will charge the battery and fuction just as the panel would, but isn't dependent on sunlight. This can make it more convenient to montior performance and trouble shoot the initial setup.
Step 14: Finished Assembly
Picture of Finished Assembly
Be sure to test all parts of the system individually before assembling them together.
Attach the clamps from the solar panel onto the bolts on the control circuit housing. Then attach the input wires on the control circuit board to the bolts on the inside the housing and tighten the nuts to hold them in place. Attach the battery lines on the control circuit to the corresponding battery terminals. Be careful not to mix up the positive and negative wires! You probabably want to label them or color code them. Attach the output lines on the control circuit to the DC power outlet. Be sure to attach the positive wire to the center pin and the negative wire to the outer barrel. Once everything is in place, close up the housing and screw it together.
Attach the inverter by plugging it into the DC power outlet. Put the Automatic switching circuit into its housing and close it up. Then plug the inverter power cord into the inverter. Plug the appliance into the output line. If the battery was fully charged, the appliance. should be powered. Lastly, plug the wall outlet power cord into a wall outlet.
Carefully observe all the parts of the system to make sure that nothing is making any weird sounds, smells, or is catching on fire. If not, you have a functioning solar electric hybrid adapter.
Step 15: Final Notes and Future Design Improvements
Picture of Final Notes and Future Design Improvements
Final Notes and Warnings
The operation of this device involves regularly cutting power and switching to a second power source that may be out of phase. As a result, the output may momentarily fluctuate. This is especially true if your switching circuit uses a relay with a low activation voltage. In this case, the relay might switch before the inverter is running at full power. This momentary fluctuation is no problem for simple appliances like a lamp or fan, but may potentially cause problems for sensitive electronics. So choose your appliances carefully. I am not responsible if you fry your computer.
The biggest problem with this design is that the device activates as soon as the battery is fully charged. This does not necessarily coincide with when the appliance is turned on. Even if no appliance is on, the relays and the inverter will still consume power. This can waste electricity if you are powering a device that is not regularly on during the day.
In a future design, I will combine the various parts of this project into a single unit that has a sensor to determine when the appliance is turned on. Only once the appliance is turned on will the control circuit activate the relays and the inverter. This will help ensure that less power is wasted.
I would also like to add something to the circuit to smooth the output of the system to avoid the power fluctuations mentioned above. This might be something as simple as adding a time delay on the switching circuit.
If you have any suggestions for improvements please leave a comment and let me know.
angryopium (author)2017-09-08
So, thinking on a bigger scale, if I want to plug more things than just a lamp (e.g. through a multiple plugs adapter) I'd need an automatic switching circuit for each of the "appliances" connected right?
And this would work with a conventional MPPT and a (quite) big inverter as well?
Well this design is really best suited to smaller scale applications. If you scale it bigger, it really is more practical to use a grid tie inverter and just pump electricity back out into the grid to get a discount on your electric bill.
DavidJ411 (author)2017-01-30
I have a yeti 150...it wont run appliances with multible speed or heat settings ...can i can i bypass those controls and run them on it. ??
Maybe. I am not really familiar with that system.
bigleybakes (author)2016-03-26
Would it be possible to run a pump and grow light for Aquaponics using a system like this and if so, what kind of power would I need to do this? (looking at doing this for our son's science fair project) Thank you. So far you are the only one I can find to has shown how to make single appliances solar run.
You can run any kind of low power appliance with this system. However, if you are just powering a pump and grow light, then I would recommend using a 12 volt system instead of a 120 volt system. You lose a lot of efficiency in the inverter and they sell 12V pumps and LED lights. Also if you use a DC system you can use transistors to switch the power instead of relays which will also increase the efficiency. You could also have the option of powering the pump directly with the solar panel.
If your son can send me the details of the project that he wants to do, I could give you some more specific answers. My email address is DIYHacksAndHowTos@gmail.com
nukepredator (author)2015-09-26
how much time will it take to charge a 18 Ah, 12 volt battery using a 4 W solar panel?
Well a 12 volt 4W solar panel will produce about 3 amps. So it would take at least 6 hours to make 18 amp-hours. But it will typically take longer than that because the charging process is always a little slowed down. Also you probably won't have full direct sun all day.
nichalos82 (author)2015-08-29
Great instructable but I would like to add some tips/ considerations.
Since you are making an investment in just a little Solar, I would recommend considering some efficiencies to minimize energy waste. That being said, the inverter.... DO NOT GET at Harbor Freight, I think anywhere else, will be more efficient then Harbor Freight (My Solar Professor and I have had this discussion before). If there wasn't a budget constraints you would want to purchase a pure sine wave inverter but we have life to deal with and life is a money hungry individual!
Solar panels....go on eBay and purchase Solar CELLS, and get the tabbing and bus and solder them in series (tab back to front or positive to negative respectively), if in the future you want to add more Solar, it may be more cost effective to wire yourself (you would have to do the math though because there is the task of encasing).
Charge controllers.... the harbor freight version(if that was even mentioned in the instructable) is a waste of money! you're better off going on eBay and ordering them for $7-15 being shipped from Hong Kong.
Perhaps the key thing to remember in any Solar system big or small, is the 2nd law of thermodynamics "Every energy has inefficiencies" that being said, don't undersize your system. As energy is captured and transmitted through the various components it loses strength at each component so it best to account for those losses by capturing more at the beginning I.e. the Solar collector. A good starting point will be researching all the components within the system, efficiencies. once you determine that, then I would recommend stepping up the minimum input after the inefficiencies are accounted for in the minimum and I would recommend increasing your energy storage for cloudy days. I wouldn't recommend going with a 12V system as you are achieving nothing if you are using it at the same time you are gaining it so I would recommend considering a 17-18V system and a good rule of thumb is to have about a 50% discharge rate.
Just a few thoughts for consideration. In no way am I being the devil's advocate of this instructable as I believe it's very good, I'm just merely adding a few considerations in addition to what was being outlined!
cgrishnackh (author)2015-05-28
Thank you
ross.m.campbell (author)2015-04-04
I have a hot tub that runs a circulation pump continuously. I have a 500w wind turbine and 120w solar panel. matching batteries and charge controller.
Do you think the switching circuit would be effective as I'd love to run the tub on solar/wind energy for the majority of time.
cheers,
Ross
It could be. But you wouldn't be able to use the solar panel and the turbine at the same time. Just make sure that all the components are rated high enough for the load that they will be subjected to.
To be honest, I am not sure how my system would interact with that charger. When the charger is on it will momentarily change the voltage of the battery and might mess with the switching sensor.
well hcc connects to the battery and then battery connects to the inverter, so your switching circuit would connect to the inverter.
Think I'll give it a go, making sure relays, etc are uprated high enough to take the pumps max setting. Sould be fun :) It will either work or not, so we'll see.
cheers for your help
Good luck. Let me know how it goes.
RoseH1 (author)2015-03-04
This seems like a fun little project. I always like to try and find new ways to save on my utility bill. This just might do the trick. Do you know how well these panels work on these house-hold items?
http://www.solarrfp.com/index.php/solarbasics
It all depends on the wattage rating of the panel and the wattage rating of the appliance. Any panel can work on any appliance. But the bigger the solar panel is the better.
KAILASHD (author)2015-02-22
i brought solar panl size(mm)50 w X 100h ,and try it for charging my mobile but its shows high woltage and chargerr error ..any solution for it
Cell phones typically need 5 volts to charge and most solar panels are going to output more than that. Use a 5V voltage regulator such as a LM7805
http://www.radioshack.com/-5v-fixed-voltage-regulator-7805/2761770.html#q=7805&start=1
hassang2 (author)2015-01-18
Great project and thank you for share it! I want to build this system as a UPS system. My question is that what happen when the grid
is down and the battery isn't fully sharged?!
If the battery voltage is below the set voltage, it will connect the appliance to the AC outlet whether or not the AC outlet has power.
AnuR4 (author)2015-01-05
jcastaneda5 (author)2014-12-14
Awesome instrucable Brother!
SaraF2 (author)2014-11-25
How can I integrate a wind turbine with this system ?
Just use the wind turbine to charge the battery. You may need a charge controller that is specific to the wind turbine. But this system is designed to work between the battery and the appliance. It doesn't matter how the battery is charged.
neil.freidberg (author)2014-09-05
So any suggestions for size when i am trying to do this for a desktop computer?
I honestly don't recommend doing this for sensitive electronics like computers. The power fluctuates when it switches modes. That doesn't matter for a lamp but it could cause problems for a computer.
I don't see a problem with using it on computers. Most power supplies in computers are switch mode supplies that are used precisely for conditions such as ever changing voltages and unreliable power sources. One concern I do have is that a modified or full sine wave inverter should be used. The standard square wave can do some damage to regulator components designed for AC full sign wave frequency use.
SparkySolar (author)2014-10-18
wicked nice
wicked nice
nukepredator (author)2014-07-11
hey ive done this project but i do not get stable output from the inverter. The relay in the switching circuit just goes on and off all the time. The battery gives constant 12V but the inverter dosent. What should I do?
When the inverter turns on and starts power from the batter, the battery's voltage will drop. And then the inverter is disconnected, the voltage will go up a little. So if your two voltage points that are set by the resistors are too close together, it may go back and forth very rapidly. So first, try making a bigger difference between the two settings. The high voltage should be somewhere around 14 volts. The low point should be about 11.5. This effect also is more dramatic the smaller your battery is. So a larger battery may help.
nukepredator (author)2014-07-04
how can we test if this circuit is working or not on the bread board?
The easiest way to do it is to make different battery packs with different voltages. 8 AAs make 12 volts. 10 AAs make 15 volts. This lets you try out different voltages to test when the system switches on and off.
Thank you for the help but again i am having some trouble. Now i am trying to set the potentiometer but if i set the value to 8600 ohms between wiper and positive terminal, i get 440 ohms automatically between negative and wiper. How do i get 1400 ohms on the negative side?
The exact values are not really important. What really matters is the ratios. If you adjust it so that they ratios are the same as the ones listed it should work. Or you could simplify things and just used fixed value resistors with the appropriate ratios. You won't find exact values so just get close.
nukepredator (author)2014-07-02
Sorry to ask such a silly question but what is "8600â" and the other values in that potentiometer section u described. I mean is that ohms or something?
And how do we set two values in one potentiometer, like between positive rail and wiper and negative rail and wiper?
Plz do answer. I am having a hard time getting this :P
Yes. That was supposed to be ohms. The text editor messed up the symbol. Use a multimeter to measure the resistance between the pins and adjust them until they match up with these values.
yolande13 (author)2014-06-22
I would like to know what type of house hold appliances can i use in the house? We will be moving to a house that solely working with solar panels? Will i be able to do washing with a top loader,or even do ironing? Please help this is all new things to me. I was use to electricity.
The system that I describe in this project isn't really suitable for powering a whole house. But with any solar system, you need to balance the power ratings of the appliances to the power rating of the inverter, the battery and the solar panel.
mugshotremoval (author)2014-06-02
This is awesome. I an going to try this form my laptop!
ShadowPatriot90 (author)2014-05-17
I think this is a brilliant idea, I woud just like to know if its possible to "over charge" a battery? I'm just trying to think of what could go wrong. Because if this goes as well as I'm hoping it will, I plan to make this into a small house system where all of my electronics run solely on solar power.
If you set the charge controller circuit properly, then it shouldn't over charge the battery. The main advantage of this system is that it can work on a small scale, if you intent to power your whole house, then it would be more efficient to use a professional system that is designed to power a whole house.
Conquest102 (author)2014-01-27
This is going to be my first follow thru instruct able. NO experience doing circuit boards but this project is PERFECT for my needs. I am have a problem with the control circuit list.The optional items what are they needed for and what happens if not used? How about a picture of the backside of the board? So I can see the traces please.
The optional parts are for a charge controller circuit that prevents the battery from being over charged. But this isn't necessary if you regularly turn on the appliance. Sorry, I don't have the original board anymore. I gave it to a friend. So I can't get any new pictures of it. You will just have to follow the circuit diagram.
boardsmm (author)2014-01-10
This is BRILLIANT! Any guidence on the improvements you suggest?
THANK YOU!
tygger281 (author)2012-07-26
VERY NICELY done! I do have a comment / question: We decided to use the complete kit because it came with "compatible" lights that just plugged into one of the adapters on the inverter that came in the kit.
We put one on the back porch and the front porch, and bought a cute, very small Kitchen cabinet. We painted the cabinets to match the house and BOOM, we are off and running!
The cabinet was PERFECT because it had two shelves - one for the inverter, and one for the battery. We were using the existing lights - two came with each kit. We hung one set on the back porch, and one on the front porch. So, the battery started charging, and within hours, had lights on the front and back porch!
Our first set of lights blew out most likely about two months later. We went BACK through the instructions, and could find nothing. We tested the solar panel by charging another small battery. It was charging fine. We found something to plug in one of the other ports on the inverter, no issue. So, I went to the store to find bulbs to fit in there; there is nothing else to fit in there that is the correct voltage. ANYWHERE.
So, called HF - and they said, yes, we can send you new replacement bulbs at no charge AND it would take six weeks to get them. What was I going to say but ok. So, new bulbs come, we plug them in - they last two weeks and *poof* they die again. I called again; they said it would take four months this time. They had stopped using those bulbs and that inverter in the kit.
At one point shortly after this, the inverter did die. So we called for a new inverter. Got one after 3.5 months (of course, still waiting on the light bulbs). We hooked up the new inverter. Tested the other parts of it, it seemed to be fine. New bulbs finally came - they worked for less than a day. We gave up on getting more bulbs.
The front porch bulbs lasted nearly a year. Then they died. We never tried to get them replaced. In the meantime, we moved the back panel to our chicken coop, and use a small water pump for emptying out the excess water barrel, if needed, or reuse the water in the yard.
We still use the front porch panel as a trickle charge battery charger for the horse trailer and scooter batteries. But we are not using the inverter.
Is this why you are not buying the kits? Have you ever had similar problems with your inverters? Thanks!!!
About This Instructable
230,373views
581favorites
License:
Bio: My name is Jason Poel Smith I am a Community Manager here at Instructables. In my free time, I am an Inventor, Maker, Hacker, Tinker ... More »
More by DIY Hacks and How Tos:36 Things to Cook in a Coffee MakerHow to Make a Festivus PoleAdd Wings to an Infant's Halloween Costume
Add instructable to:
