How to Make Any Home Appliance Into a Solar Electric Hybrid
 by DIYHacksAndHowTos
Contest WinnerFeatured
This project is a simple and cheap way to integrate renewable energy into your home by turning your appliances into solar electric hybrids. Here is how it works. A solar panel (or any other renewable power source) charges a storage battery. A control circuit continuously monitors the battery's voltage. When the battery is fully charged, the circuit automatically turns on a power inverter and switches the appliance from running on grid power to running on the energy stored in the battery. Then when the battery's voltage drops too low, the circuit automatically switches the appliance back to grid power until the battery is recharged.
This design doesn't require any modification to the appliance or your home's electrical system. It can work with any power source that is capable of charging a 12V battery (examples: wind turbines, bike generators, etc.). But most importantly the system is scalable. This design is set up for outputs of up to 75 watts, but by swapping out parts for ones with higher power ratings you can power larger appliances or multiple smaller appliances at the same time. This lets you build a system that fits your energy needs and your budget.
I am still trying to make improvements to the design. So if you have any questions, problems or suggestions please leave a comment. I would really appreciate the feedback.
Step 1: System Overview
Here are the five basic parts of this system:
1. 12V Solar Panel (or other renewable power source)
2. 12V Rechargeable Battery
3. Control Circuit
4. 12V Power Inverter
5. Automatic Switching Circuit
When assembled, the solar panel, battery, and inverter plug into the control circuit. The automatic switching circuit plugs into the inverter and the wall outlet. Then the appliance plugs into the automatic switching circuit.
The solar panel, battery, and inverter may be purchased off-the-shelf from a variety of locations. The last two parts of the system (the control circuit and the automatic switching circuit) will need to be constructed. This is detailed in later steps.
1-40 of 42Next »
suganya sekar says: Jan 19, 2013. 6:07 AM
if any possible to connect the solar system into normal home inverter. if it is possible means how it is?
youcantoo says: Nov 18, 2012. 12:23 PM
What is the switch time for the relay?
DIYHacksAndHowTos (author) in reply to youcantooNov 23, 2012. 10:58 PM
The switching time just depends on the relay that you use. I couldn't tell you the exact timing for the relays that I used but in many cases it can cause a noticeable fluctuation in the output. So this kind of design is not suitable for for sensitive electronics. I just used it to power a lamp.
youcantoo says: Nov 18, 2012. 11:56 AM
Don't use car batteries for your project. They were never designed to handle the requirements of a solar or wind powered system. Yes they maybe cheaper to buy. The car battery was designed to handle the initial load of starting your car and then be charged back up. A solar/wind system does not do this. You will find a car battery will last a short period of time under these circumstances. What was cheap to buy the first time then becomes a expensive replacement cost. Consider paying more up front for a deep cycle battery. You can even buy good used deep cycle batteries like forklift or golf cart batteries. They will well out last a car battery and yu will be money ahead.
useful1 says: Jul 25, 2012. 2:06 PM
This seems like a setup I can use. Thank you for posting it with clear instructions.
If I understand it correctly, it seems like an always "on" setup, meaning that when the batteries are topped off, you'll use battery power. Once the battery reaches "low", it switches to the power on the mains from the electrical company.
The relay switches is what controls the path the electricity takes.
Couldn't the problem that "involves regularly cutting power and switching to a second power source that may be out of phase", be solved by adding a UPS backup after the automatic switching circuit and before the light bulb? (as shown in your diagram)
- U
youcantoo in reply to useful1Nov 18, 2012. 11:37 AM
Really if you are using a UPS there would be no need to have the switching circuit as the ups has it already has that sort of circuit built into it.
DIYHacksAndHowTos (author) in reply to useful1Jul 26, 2012. 9:53 AM
Actually a UPS was my original concept for this project. In my original design, I took a UPS, and disabled the internal charging function by adding a diode after the battery. I set up the battery to be charged by a solar panel. Then when the battery was charged the control circuit would just cut off the grid power from the UPS and it would smoothly switch to the battery power. I decided to go with my current design because I was able to make it a little cheaper.
useful1 says: Sep 24, 2012. 6:48 AM
Just wanted to say, I built this system 2 months later and seems to be working great. The only part that I found frustrating was setting the value of the variable resistor on pin 2, to adjust when the control circuit switches off the relay going to the inverter.
Every time, I kept trying to test the value of pin 2 while the inverter was on, the relay would click and I could not get an accurate reading of the voltage while the system was under load. It was pretty frustrating. The only way to set the low end, was to use up the battery power until it reaches somewhere near 11V and turn the dial down until it clicked off.
But even then, I still don't know what the voltage reading is coming into pin 2.
DIYHacksAndHowTos (author) in reply to useful1Sep 28, 2012. 1:21 PM
Thanks. I'm glad to hear that someone else was able to get it to work.
orenyny says: Sep 28, 2012. 10:50 AM
Great project thank you! My question is if it is possible to do a hybrid that will keep the battery charged (from those 12V sources you mentioned), but if they run out (no wind and no sun) it will top of the battery from the grid.
In addition, it will be tied to the grid so if the battery is full and the solar pannel is generating electricity, it will feed into the grid, and finally, when the grid is down, use the battery (emergency).
Thanks!
DIYHacksAndHowTos (author) in reply to orenynySep 24, 2012. 6:31 AM
There are a couple of devices that are similar to your description. I grid-tie inverter would let you go directly from the solar panel to the grid without needing a battery. On the other hand, an Uninteruptible power supply would let you keep the battery charged with the grid and then use it if the grid goes out.
TakashiMoto says: Sep 9, 2012. 3:42 PM
I'm not terribly good with schematics, could you post a pic of the underside of the control circuit board please?
I'm also having a hard time with figuring out the orientation of the relay on the breadboard, thanks so much!
DIYHacksAndHowTos (author) in reply to TakashiMotoJan 7, 2013. 10:33 AM
I will try to get another picture added. But in the mean time, you can get a good idea from the breadboard layout on step 8. All circuit parts were purchased from RadioShack (see step 5). So you can just align them the same way that they are in the picture. I hope this helps.
TakashiMoto in reply to TakashiMotoSep 9, 2012. 4:27 PM
Is this the same relay? pinout and all?
http://www.mouser.com/ProductDetail/TE-Connectivity/OUDH-SS-112D000/?qs=%2fha2pyFadui2QAjXzdmwdlJkRYZqifB3R%252baei18HFruUr665Gub%252bLA%3d%3d
I sourced one a bit different but i have to move things around.
tygger281 says: Jul 26, 2012. 8:18 AM
VERY NICELY done! I do have a comment / question: We decided to use the complete kit because it came with "compatible" lights that just plugged into one of the adapters on the inverter that came in the kit.
We put one on the back porch and the front porch, and bought a cute, very small Kitchen cabinet. We painted the cabinets to match the house and BOOM, we are off and running!
The cabinet was PERFECT because it had two shelves - one for the inverter, and one for the battery. We were using the existing lights - two came with each kit. We hung one set on the back porch, and one on the front porch. So, the battery started charging, and within hours, had lights on the front and back porch!
Our first set of lights blew out most likely about two months later. We went BACK through the instructions, and could find nothing. We tested the solar panel by charging another small battery. It was charging fine. We found something to plug in one of the other ports on the inverter, no issue. So, I went to the store to find bulbs to fit in there; there is nothing else to fit in there that is the correct voltage. ANYWHERE.
So, called HF - and they said, yes, we can send you new replacement bulbs at no charge AND it would take six weeks to get them. What was I going to say but ok. So, new bulbs come, we plug them in - they last two weeks and *poof* they die again. I called again; they said it would take four months this time. They had stopped using those bulbs and that inverter in the kit.
At one point shortly after this, the inverter did die. So we called for a new inverter. Got one after 3.5 months (of course, still waiting on the light bulbs). We hooked up the new inverter. Tested the other parts of it, it seemed to be fine. New bulbs finally came - they worked for less than a day. We gave up on getting more bulbs.
The front porch bulbs lasted nearly a year. Then they died. We never tried to get them replaced. In the meantime, we moved the back panel to our chicken coop, and use a small water pump for emptying out the excess water barrel, if needed, or reuse the water in the yard.
We still use the front porch panel as a trickle charge battery charger for the horse trailer and scooter batteries. But we are not using the inverter.
Is this why you are not buying the kits? Have you ever had similar problems with your inverters? Thanks!!!
luvasu in reply to tygger281Jul 26, 2012. 10:54 AM
My experience says that an inverter needs space for cooling (air), never inside a cabinet, unless there are 2 fans (in an out blow, computer type). Above this, if the label says a wattage, never connect more than the 80% of this number of watts.
Following this rules my 80W inverter works for 4 years... and counting.
luvasu in reply to luvasuJul 26, 2012. 11:11 AM
I've different solar panels (7) up to 105W, feeding several 7Ah and 12Ah batteries, up to 186Ah, using a 10 Amp control charger (near to the limit 9.7 Amps)
On use (nightime) 4 inverters (120+120+80+80 W), sometimes at the same time, but not often.
Only mi first 7Ah battery has been replaced after 8 years duty, because not recharging above 4 VDC. (Similar to the one showed in a picture above).
My battery replacement is mandatory after 10 years duty (that one was a surprise).
DIYHacksAndHowTos (author) in reply to tygger281Jul 26, 2012. 10:00 AM
None of my components were part of a commercial kits. I just assembled it from off the shelf parts. I haven't been running my system very long but I haven't had much problems with my lamp setup.
tygger281 in reply to tygger281Jul 26, 2012. 8:22 AM
Oh, you are showing the kit in the final photo. Please let me know if you had similar issues.
chuckyd says: Jul 26, 2012. 3:58 PM
Instead of using a converter, it would seem more efficient to use appliances that work off the same voltage as the battery/collector. There are several 12V appliances made for campers and motor homes.
webgiant in reply to chuckydJul 27, 2012. 10:39 AM
While 12V appliances exist for campers and motor homes, the reduced voltage means they usually have less efficiency and greatly increased cost. A 12V DC household refrigerator will run you several hundred dollars and have insulation so thick the interior will be considerably smaller than an AC refrigerator of the same general size. There are much cheaper 12V DC refrigerators, but they tend to be of the "improved ice chest" variety rather than an actual refrigerator.
An inverter allows you to use a wide range of Energy-Star appliances which are much cheaper than DC appliances, and get more use, and storage, out of your appliances.
chuckyd in reply to webgiantJul 27, 2012. 11:58 AM
Big deal. Just work on putting as much effort into DC appliances as has been put in AC appliances. If power is run through an inverter for an "efficient" appliance, is it still considered effecient from the other side of the inverter?
With the cost of inverters and the power lost in the process, it seems that eliminating the inverter would be more efficient.
Ultra Computers says: Jul 29, 2012. 2:04 PM
Those panels look like thin film silicon panels, which tend to be the cheapest type of solar panel, but only run about 7 to 8 percent efficient. Currently the most efficient panels available to consumers (at 20 percent efficient) is the Sunpower E20 at 327 watts, at about 17 square feet of panel (including the gaps between cells and the frame. These panels run between $700 and $800 per panel (by the way, it is a mono crystalline silicon panel, which tend to by more expensive and more efficient).
Just thought I would add a little useful info
cheers
Ultra Computers
londobali in reply to Ultra ComputersJul 30, 2012. 10:50 PM
The question is: are those 20%-efficient cheaper than 3x the price of the 7%-efficient ones?
If it's more than 3 x as expensive, then might as well get three cheaper ones (if space allows)..
it will be cheaper and gives the same output.. or, in other words, it's more cost-efficient...
cheers.. :)
ereus says: Jul 26, 2012. 11:39 AM
It should be borne in mind that AGM batteries are not suitable for inhabited environments due to any release of gas.
webgiant in reply to ereusJul 27, 2012. 10:40 AM
So get a sealed AGM battery. Problem solved.
gargoyle169 says: Jul 26, 2012. 11:42 PM
Not trying to pee in anyones Wheaties but the system displayed herein is a Harbor Freight special. Not really in the spirit of Instructables.com. The entire package comes in a NON Recycled cardboard box with instructions!!!
"We have a "be nice" comment policy. Please be positive and constructive with your comments or risk being banned from our site. "
So I'll be nice and ask a constructive question, What is the cost per watt of this system, and what is the power density of the amorphous array? Then there is the matter of the 85 dollar AGM pile that Da Freight is peddling with this thing,, what is the reccomended c/20 rate versus dollar/watt ratio?
These are the real economics of DIY alternative energy.
DIYHacksAndHowTos (author) in reply to gargoyle169Jul 27, 2012. 5:24 AM
While the solar panel and the inverter that I used where purchsed from Harbor Frieght, no part of this project came from a kit. I think the confusion came from the picture in the final step. I just wanted to use a picture of a solar panel and system that was larger than my current setup to illustrate the idea of future delopments and improvements. But unfortunately the picture that I selected was that of a solar kit from Harbor Frieght. This was a poor choice on my part and I am sorry for the confusion. I have changed the picture to fix this.
In regards to your question, I used a 5 watt panel, 75 watt inverter and a 7 Ahr battery and was able to build the system for about $150 using parts from RadioShack. If you order the parts online you should be able build this setup for under $100. As my design lets you select the components that fit your needs, the performance is entirely dependent on the panel battery and inverter that you select.
The Green Gentleman in reply to DIYHacksAndHowTosJul 27, 2012. 6:27 AM
A very nice, classy response to a not-so-nice comment. That's not easy to do. A well made instructable, and a well-moderated comment section. Good job!
dmarsh55 says: Jul 26, 2012. 3:18 PM
CHALLENGE: apply this technology to a more heavy duty appliance. I have a 29 cf Kenmore Energy Star refrigerator/freezer, the label says 115V. We get semi-frequent power outages here, and of course our utility company is going up on our rates. Show us how to rig a set-up for this.
DIYHacksAndHowTos (author) in reply to dmarsh55Jul 27, 2012. 5:06 AM
There is no reason that this kind of system couldn't power a refrigerator. It is just a matter of making sure that all the components are rated high enough to handle the needed load. But for that kind of application you would have better luck getting an Uninteruptable power supply rated for your refrigerator's power, and many increasing the battery size.
mgcasella in reply to dmarsh55Jul 27, 2012. 12:03 AM
Great idea! Another great challenge would be to build a hybrid system that powers the large AIR CONDITIONING unit for the house I live in!
In Kansas we've been having temperatures of 100 to 105 degrees each day this summer and our utilities bill has gone through the roof. Even if this potential rig cost $400-$500 I would still end up saving money over the course of the summer.
Nove-Noga says: Jul 27, 2012. 3:47 AM
I spent four years working in a Las Vegas lighting shop. It was our job to help keep this the brightest city on the planet. Our rule of thumb for low voltage and transformer applications: Never exceed 80% of the rated output.
pedromadeira says: Jul 26, 2012. 8:59 AM
Already my apologies for the English, but I have a question, I'm using a 300W Inverter (not pure sine) then when I start it (power on), right from the beginning, it's seeking more than 5A at the starting pike.
So, then made ​​in the design, does not allow a current output over 2A, at the output of the regulator (It's the 1 design, before the all relay switch, that commute the DC and the AC).
Could anyone help me get around this?
Thank you and best regards to all!
DIYHacksAndHowTos (author) in reply to pedromadeiraJul 26, 2012. 10:03 AM
You may need a different regulator or a different inverter. Sorry that I can't be more help. Good luck.
pedromadeira says: Jul 26, 2012. 9:02 AM
jolshefsky says: Jul 26, 2012. 7:18 AM
I like that it's all DIY. I've been a go-to person for answering questions about solar setups for camping for a little while and I recommend people get a charge controller with a load switch. That accomplishes most of what you have in your control circuits (but good for you for DIY and explaining how it all works!)
My only minor quibble is about the power inverter. All the cheap inverters are "modified sine" which is a +180V/0V/-180V/0V wave that delivers the same amount of electrical power. It works fine for CFL's and most switching power supplies that just make the line voltage DC then work from there, or for resistive loads like incandescent bulbs and heaters (or, even direct line-powered LED light strings). But for transformers (e.g. plug-in brick transformers, and many many appliances) and AC induction motors (e.g. fans, pumps), the modified sine is completely inadequate and leads to lots of waste heat and potential damage to the appliance.
I have been recommending that people instead spend the extra money and get a "pure sine" inverter (I have a 300W Samlex brand that works very well). They are a lot more expensive per-watt, but especially for a small starter system, you really can't realistically use more than 75 watts or so for any appreciable time (that 7AH battery would be dead in in an hour at 75 watts, and realistically should only be run for about 30 minutes or so; a 500W coffee maker would kill it before one pot is done). The pure sine inverter will work fine with all appliances including things that people are likely to use like chargers for phones, iPods, or batteries, laptop power supplies, monitors, TV's, and audio amplifiers.
mikeasaurus says: Jul 23, 2012. 8:44 PM
Great build, this is something I want to try sometime.
kd1s says: Jul 23, 2012. 9:32 AM
Nice job on an ATX! Vendors like APC will charge a pretty penny for these.
brjasper says: Jul 22, 2012. 2:48 PM
Neat little project. I'd posted before I read everything through, but I'd still suggest a small grid-tie inverter that would feed power back into the mains for the whole house. You can get some small ones fairly cheap as inverters go.
1-40 of 42Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
