3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make artificial fishing bait for little to no $
Step 11Placing the master bait, vent tubes, and injector hole
Next get the bait you are going to clone and rub it down with the Vaseline as well. Place it into the putty until it is sunk halfway into the putty. Usually the baits already have seams where they were poured in the factory, so that makes a convenient half-mark. We also need to make a vent so that the plastic will make it all the way through the bait, and we will have no bubbles or dents when the lure is done. This is solved by placing a small stick, I used a stir stick, into the putty, sinking it halfway and touching one end of it to one end of the worm and the other end of the stick to the outside of the tray. Rub this down with Vaseline as well. We also need a hole to inject the plastic into. I used the cap from window chalk. It is roughly funnel shaped, and is big enough to allow the end of the heating element to go inside. Take this and again, rub it down with Vaseline, and press it halfway into putty on the opposite side of the lure as the stick. Make sure it is touching the end of the lure. Now take the marbles or beads and press them halfway into the putty to use as reference points when the two halves of the mold are put together. All we do now is wait for the putty to harden. This will take around 30 minutes. Go watch some TV, eat a sandwhich, whatever.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:unexplained_3
