First open Notepad and write this
@echo off
:A
Cls
echo MESSENGER
set /p n=User:
set /p m=Message:
net send %n% %m%
Pause
Goto A
and then save as "Messenger.bat" and close the Notepad
Remove these ads by
Signing UpStep 1
whit this.
Messenger
User:
after "User" write the ip of the computer you want to contact and then press enter.
By the way, it's no problem as long as you give credit to where credit is due. :)
Want to learn to?
open up a cmd-window and mess around with it. I learned it like that too.
Now I make games in batch^^.
([WIN]+[R], a run-window appears, write "cmd" and press enter).
echo Messenger
echo When typing the computer name, type
echo in /server:computer replacing
echo computer with the IP adress of the computer.
:START
set /p c=Enter computer name here:
:A
set /p m=Enter message here:
msg * %c% %m%
GoTo A
This allows you to create a messenger on Windows 7 and after entering the ip address of the computer for the first you can simply send messages after that, without needing to re-enter the ip address
change the net send command to msg
is useless because it only allows to chat by LAN (local network)
and i beleave most people is not connected to others by lan and you have to tell username eachtime you want to say something.. will be better if u say user once and to have a option to change username whenever u want.
