3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make circuits with a Roland CAMM sign cutter
Step 4Fixing your circuit to the base
The 3M 1126 conductive adhesive tape is pressure-set, which means that it sticks once you press it. To make the circuits stick to your base, you need to push the copper all over as much as you can. I keep the masking tape on the circuit to protect it while rubbing all over it with the flat side of a pair of scissors or a ruler.
Then you will want to remove the protective masking tape, which you can do by peeling it off at as sharp an angle as possible, as not to rip up any of the traces. If the copper is lifting as you peel off the masking tape, push the masking tape back down and try to rub over the lifting area some more.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:nadya
I dropped out of art school to study artificial intelligence, but I still like making things a lot!
