3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make clay
Step 7Play with it!
Play with it!
Done!
You now made the clay that is cheap to make compared to the expensive store-bought clay!
Now you can hand it over to your little kids to play with. And after they have done playing with it, store the clay in an air-tight containers to retain its moisture so it can be used again!
Or...
Make models out of clay and let it dry out in air (never bake this type of clay, it will ruin it) and then paint it!
Or...
Make pottery out of that clay, carve it with your carving tools or something like that, then air-dry it, and paint it!
I hope you enjoyed this instructable!
If you have any questions, or need help, or found an error, or anything, make a comment! I like comments!
15 comments
Dec 7, 2011. 1:04 AMamahmudy says:
would it get little cracked after the drying process?
Jan 30, 2009. 7:26 AMcanadian nh says:
hi, Cream of tartar or oil of tarta, isn't available can we use another kind of oil? and can we do from this clay flowers or dolls? Thanks
Nov 21, 2011. 3:46 PMLefrançois says:
levure+bicarbonate de soude
Apr 5, 2010. 3:07 PMfriedhand says:
Hey you said that we needed cream of tartar, but when you are showing how to make it ,it doesn't include it . Why do we need it?
Sep 8, 2011. 7:55 PMmslaynie says:
Cream of Tartar isn't a cream, it's a bright white powder. As others have said, it helps add elasticity to the clay, making it a bit more stretchy and pliable.
Jun 12, 2011. 1:14 AMkroach2 says:
do you need a kilm thing to use this clay or is it just an air dry clay???
because i dont have any access to a kilm :)
Jun 13, 2011. 12:44 PMJohnDeere312 says:
um, its a kiln and it says that it is air dry ;)
Jan 23, 2011. 12:29 PMluka1184 says:
This is nothing like Chavant? :(
Jun 12, 2011. 1:15 AMkroach2 says:
whats chavant
is it a brand name clay???
Jun 12, 2011. 2:10 AMluka1184 says:
Chavant is a oil-based modelling clay, making it easy and able to do small tiny details. Movie prop builders use chavant clay. It's not that expensive ^^
Jun 20, 2010. 10:27 AMtoedaniel says:
I have a good use for this clay if it can be used outdoors, hardened so as to be able to hold an item inserted in it, and be long lasting. Will it harden and be able to hold an item in an outside environment? Thanks!
Dec 22, 2009. 11:17 AModysseusesperson says:
im planning on making it into a pipe to smoke out of would this type of clay work for the application a wanna use it for
May 2, 2010. 12:09 PMIceTeaEdwin says:
Wtf, no e_e
Dec 11, 2009. 2:26 PMBroadwayalltheway says:
this is great! I made advent wreath candle holders with it.
Aug 23, 2009. 4:21 PMsamipiano says:
i think the "Cream of tartar" is the "Baking Powder"
Apr 4, 2009. 6:57 PMduckman1970 says:
whats the cream of tarter do and is it a necessity in the clay?
Apr 8, 2009. 11:54 AMA.C.E. says:
what do you think? It was an ingredient, AND it had an exact amount per batch, correct?
Feb 9, 2009. 9:56 AMbombillita says:
It is an exterior proof clay? I want to make some craft to my house outside walls. sun, rain weather proof??
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
778
Author:Plasmana
 "Energy cannot be created nor destroyed!"
more »
