How to Make Coiled Wire
Introduction: How to Make Coiled Wire
You will need :
Marker (Or something that you wrap wire around)
Heat gun
Step 1: Wrapping Wire
Start to wrapping wire around marker and secure it with tape
Step 2: Covering
Cover the taped sides aluminum foil, reflective side out.This will reflect heat from the heat gun away
Step 3: Heating the Wire
Heat the wire with heat gun,but when plastic come smoking let it stay minute or two and heat it again.
Step 4: Testing
Remove foil and tape.
Test the wire before you use it
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    Nicely done. I didn't think that something like that would be so easy. Thanks for showing us.
    Wouldn't it be wiser to use a hair dryer? Nice instructable anyway.
    well you can use it but it needs longer to heat the wire
    In the canadian series "How it's made" (season 15 episode 12) there was actually an episode of "How retractile wires are made". The important last stage was to reverse the coils of the wire to give it extra strength and 'spring', otherwise it remains quite loose.
    The factory used a proprietary machine that wasn't allowed to be shown but an employee demonstrated the method using a hand drill grasping one end of the wire. Offcourse for a shorter and thinner wire as this a drill would be an overkill.
    Neat, I have tried this method in the past for some jumper wires for breadboards but they don't keep the shape for long, probably because the ones I used felt more like solid wires. I see you are using bigger stranded wire and was wondering if they kept the shape permanently.
