Remove these ads by
Signing UpStep 1Step1 clean/dismantle
usually its very simple to take something apart,
the Darth Vader bank im hacking is held together with just 4 screws, which allows me access to the back of the battery tray
you dont want old battery acid all over your power leads so make sure its clean!!
check out the thing you plug into the wall that charges your gameboy
there should be a tiny spec sheet
the sheet should say
"input voltage" (which is the voltage from the wall 120V AC)
and
output voltage (the power going to the gameboy)
if the power going to the gameboy is about 5V DC and 2amps or less it should be okay
also christmas lights:
there are battery pack operated sets, the LED ones will never burn out, and u can light up more LED then normal bulbs because they use alot less power
i wouldent reccomend putting more then 10 lights in a string
my set came as a set of six, and works fine
just becautious of your limits, electricity is a fickle thing!
like it says
white=v
blue=g
Green=c
orange =d
so is
white=white
blue=black
green=green
orange =red
??? I'm confused
and blue is ground
L
Thanks
L
i do reccomend only modding things that use small batterypacks
some larger things can have too much draw and not function properly
