Step 2Make the coffee
To make coffee from a moka pot, just fill-up the bottom container with water up to the pressure release valve. Place freshly ground coffee into the strainer and place into the bottom container and screw on the top receptacle. If you have the ability, try to grind the beans as fine the coffee maker can take before they start seeping into the coffee. It takes trial and error.
Place the coffee maker on the stove at a low heat and wait for the coffee to start coming out. Once you see it start coming out be prepared to take it off the stove. Remove as soon as the coffee stops flowing and all you get is air. The longer you leave it on the stove at this point, the more burnt the coffee is going to get. Also don't attempt to reheat the coffee (for the same reasons).
Cold brew coffee does not have the somewhat acidic aftertaste that some hot brewed coffee can have.
