3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make delicious coffee liqueur
Step 3Caramelize the sugar
This step is pretty much essential if you have any sort of pride in your final result. Sure you could just add the sugar to coffee, but why then don't you just go to the liquor store and buy coffee liqueur.
To caramelize the sugar, mix the 1/2 cup of sugar and about 1/2 cup of water in a pot. The sugar will dissolve easier as you heat the mixture, so don't try to mix it before setting it on the stove. Basically just keep stirring the mix as it heats up even once its mixed. It will start boiling and bubbling and will require much more frequent stirring. I guess there is a fine line between making caramel and making candy, but it will all dissolve into the coffee anyway. Its tough to tell when enough is enough (ok, I'm not a professional caramelizer), but you'll notice eventually that the stuff is thickening. Thats probably a good point to add it to the coffee. Don't heat up the coffee to blend the caramel in. You don't want to burn the coffee.
Like I said, its difficult to determine the point of caramelization because you are stirring while hot when the stuff tends to flow the best.
Uhh, I guess I looked it up, and this is not the way to make caramel. Its the way I made it for the liqueur, so I'm going to leave it until I try differently. There isn't an instructable that gets at it, but Wikihow suggests just melting sugar.
http://www.wikihow.com/Make-Caramel
3 comments
Jan 13, 2011. 2:02 PMhoffmakd says:
Caramelizing sugar and making actual caramels are two totally different things. That might be where you got tripped up. As far as I know, you're doing just fine with your method!
Dec 4, 2009. 2:38 AMhixfixit says:
You can also caramelise sugar in the microwave, be careful as the sugar holds a lot (A LOT!) of heat so will continue cooking for at least 30 seconds after removing from the microwave.
Nothing usually happens for the first  minute or two, then pow, it's burnt.  you have been warned.
Nov 14, 2010. 5:16 PMmoonchildmeli says:
I could have not said it better myself!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:brawns214
