Introduction: How to Make Easy Cheap Ninja Pad
Picture of How to Make Easy Cheap Ninja Pad
to make this pad u need:
1-Scissors
2-Drill
3-Tube 1.5 inch (use Sewage tube it is better than other)
4-Rubber strap
5-Sandpaper
6-saw
7-spray (silver)
8-marker pen
9-heated stove
Step 1: Cutting the Tube
Picture of Cutting the Tube
cut it from this part that  showed on the image and try not to cut it straight line start from big part and end with small part cut the parts with the saw and here is image show u how to cut it
make sure that after cutting the surface is smooth and clean u can use sand paper for that
Step 2: Heating and Shaping
Picture of Heating and Shaping
heat it until it became able to bend then u bend it untll it takes it's shape then cool it with the water to keep it's bend shape
but don't leave it mush time maybe it burn
bending it is not problem  because by heating it will be really really easy to bend
after that if u miss burn some part of it u will be lucky if u not remove it with the sand paper
after taking it's shape cut the useless part to form the following shape
use low heat to miss burn i burn my second ninja pad to show that u can remove the burn so don't worry about that
Step 3: Finishing It's Shape
Picture of Finishing It's Shape
this is the final shape of the pad after removing burn
here is word u can type on it by heating and rewrite  on it by marker pen , type any text u want
and now u must drill 3 holes on it at it's ends
insert Rubber strap on each 2 holes like on the image
Step 4: Painting Then All Will Be Done
Picture of Painting Then All Will Be Done
now paint it with silver spray and it will be read to use
thanks for seeing this
About This Instructable
1,167views
5favorites
License:
More by zordrecon:Sci Fi Glowing CylinderHow to make HF high frequency bladeHow to catch fish by bottle
Add instructable to:
