One of the most difficult and yet common mechanical systems is a gear train. A great way to transmit mechanical power from one place to another or to increase or decrease power (torque) or increase or decrease the speed of something.
The problems are always that to make efficient gears needs quite a lot of drawing and mathematical skill as well as the ability to machine complex shapes.
For a lot of amateur work it isn't necessary to have maximum efficiency and therefore we can get away with a much easier to make, even with hand tools, system.
A gear is basically a series of teeth on a wheel.
http://automata.co.uk/gears.htm
provides a very good explanation of how gears work and how to work out gear ratios.
Remove these ads by
Signing UpStep 1Formula and Maths (the bad news)
Formula for drawing and making gear teeth are all over the web BUT they seem, to the beginner, very complicated.
from http://www.engineersedge.com/gear_formula.htm
So I decided to simplify the issue and it works very well at both large scale and small scale. At small scale it works best with machine cutting with laser cutters for example when very small gears can successfully be made this way.
http://www.instructables.com/id/simple-wooden-sprocket-without-cnc-machines/
but good work rickharris
This is a way to make gears at home that for low pressure system work quite well.
large size you can make with a drill and round file, smaller sizes really need some kind of machine to cut them. A laser cutter works very well as in my picture.
thanks again.
Just bear in mind, there are very good reasons why gears have the profiles they really do !
Remember for hundreds of years Windmill manufacturers got by with simple squirel cage and pin gears.
http://woodgears.ca/gear_cutting/template.html
There are other sites that provide gear drawing software as well - I believe inkscape has a gear drawing engine in it .
This is just a very simple way for someone to do it with basic compass and pencil tools.
