3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make iodine from an Alkali metal iodide, hydrochloric acid and hydrogen peroxide.
video How to make iodine from an Alkali metal iodide, hydrochloric acid and hydrogen peroxide.
Make iodine from an Alkali metal iodide, hydrochloric acid and hydrogen peroxide.
Warning: This reaction makes small amounts of chlorine gas and should be performed outside or in a fumehood.
Our previous iodine making video: http://www.youtube.com/watch?v=2F_kPXbi2D8
Simply get some potassium or sodium iodide and dissolve in a minimal amount of water. Then add an equal amount of concentrated hydrochloric acid. Check this new volume and measure out five times more 3%hydrogen peroxide. Mix together the two solutions and let stand for ten minutes. Filter the iodine.
You can then purify by vaporization and crystallization.
19 comments
Jan 7, 2011. 1:40 AMjpoopdog says:
this reaction shouldnt generate any chlorine gas.
a sign your hydrochloric acid is contaminated is that if you mix it with hydrogen peroxide the peroxide will neutralise the acid and form chlorine gas, as well as also changing a redish orange.
these are often contaminants found inside pool muriatic acid or pool brand hydrochloric acid, and are not filterd out as they dont need to be. also use distilled water as it acts as normal water contaminants act as a catalyst to form chlorine gas in hydrochloric acid and hydrogen peroxide.
Aug 8, 2010. 2:08 PMpyrorower says:
I love many of the videos the folks at Nurdrage produce, though sadly I often have trouble carrying out certain experiments since I dislike buying chemicals from suppliers besides acids. With that in mind, do any suggestions where I can acquire a metal iodide? I don't mind if I need to purify it, since I love chemistry so much. So would I be able to somehow obtain a metal iodide through store-bought materials or will I have to order it offline? Thanks! :)
Sep 21, 2009. 11:35 AMSwindle35437 says:
sodium chloride is table salt!
Jun 19, 2009. 11:29 PMlobo_pal says:
muriatic acid is another name for hydrochloric acid isn't it? And you can get that for pools, would that work here?
Jun 2, 2009. 2:56 AMpryrofreak119 says:
what was that orange stuff
Apr 3, 2009. 5:49 PMS1L3N7 SWAT says:
I'm not sure that this reaction will produce chlorine gas. Most likely aqueous Cl- ions. Considering that:
2NaI(aq) + 2HCl(aq) -----> 2I(s) + 2NaCl(aq) + H2(g)
I think this is correct.
then
NaI(aq) + HCl(aq) + 2H2O2(aq) -------> I(s) + NaCl(aq) + 4H2O(L)
Tell me if this is wrong, in fact I'm sure most of it is. I just don't think any Cl gas will be produced.
Apr 4, 2009. 5:28 PMS1L3N7 SWAT says:
That's true, you can never be too safe, especially if you have little experience with chemistry.
But wouldn't the Cl produced by the H2O2 + HCl be aqueous? Although the HCl is in excess wouldn't the reaction be:
H2O2(aq) + HCl(aq) -----> H2O(L) + O2(g) + Cl(aq)
Then the excess HCl would react with the H2O, and that reaction would go to equilibrium:
HCl(aq) + H2O(L) <------> HCl(aq) + H2O(L)
The HCl being the acid, "donates" a H atom (or proton) to the Hydrogen Peroxide to produce H2O, O2 gas and aqueous Chlorine ions.
I think the energy required to transform the Cl ions in the HCl to gaseous chlorine is far more than any amount produced in this reaction.(I think)
Apr 4, 2009. 7:19 PMS1L3N7 SWAT says:
I knew I forgot something! But yeah, I meant chlorine ions, not monoatomic chlorine. Thanks for clearing that up.
Apr 3, 2009. 12:39 PMlemonie says:
I wouldn't be worried about small amounts of chlorine gas, but if you're going to issue warnings - breathing iodine vapour isn't healthy either. L
Apr 3, 2009. 3:18 PMlemonie says:
I've handled plenty of hazardous chemicals in my time - "why do my eyes sting? Oh that's probably residual benzene, now I know why it's got an eye-irritant warning on the bottle.." (The funnest were pyrophoric) I only meant that chlorine isn't a 'top' hazard in this. (keep up the good work!) L
Apr 3, 2009. 11:19 AMAndyGadget says:
Not something I'd want to do (my days of experimenting with nitrogen tri-iodide are long ago), but it's fascinating to watch chemistry done like this - all the good bits compressed down to a couple of minutes. Nice one, NurdRage.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
614
Author:NurdRage(NurdRage)
NurdRage is a dedicate group of science nerds trying to further amateur science with direct how-to instructions in video format. We saw what was already online and we thought "we could do better"... s...
more »
