3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make juggling balls
Nice juggling balls can cost over $45. Make better ones for under $5. They're a great way to make money while traveling, just make some balls and then go juggle on a corner. Sell them to kids and teach them how to juggle. Watch the video bellow if you want to skip all boring reading stuff.
Step 1Get Everything Together
You will need the following:
Tennis Balls
Balloons
Hand Snippers
Dirt'
All this stuff is best bought at Target, because Wal-Mart sucks.
47 comments
1-40 of 47next »
Jan 21, 2012. 2:21 PMJustPrism says:
+\\ # Copy/Paste if you + ##+can juggle 3+#3 33 33
Mar 2, 2010. 9:14 PMmvkid360 says:
 I once tried to make juggling balls out of just water balloons and rice. it was all going well until i realized that one of the baloons had an air pocket which caused it to pop. rice everywhere. bad idea. this looks much better and i will give it a try
Feb 26, 2010. 8:55 AMbulletproofkevlar says:
im sorry but i dont want to sound mean or anything i just dont thing i could ever sell a modified tennis ball... not a bad idea but not exactly what i thought it was gonna be
Jul 17, 2009. 10:06 PMnomooremr.niceguy says:
I made some with racket balls. I drilled a small hole in the side, used an injector and filled them with water, then I sealed the hole with hot glue. I just thought I'd throw that out there if anyone wanted another idea. I didn't think of the balloon idea though. I really like it. I'll have to do that. Thank you! It's a great instructable.
Jul 14, 2009. 5:55 PMryanpriehl says:
Jun 30, 2009. 11:58 AMJ@50n says:
Jun 4, 2009. 11:11 AMclown96 says:
but i will also add to use something to wigh them so then they will all be the same weight =)
Apr 26, 2009. 8:35 AMthegamist says:
May 5, 2010. 4:22 PMhereinmyRedJar says:
I had a similar idea a while back and filled the balls with rice. I like the balloon feature though. I just put some tape over the holes instead, but I think I'll go and get some balloons now for them.
Mar 31, 2009. 6:54 PMgameboy7oa says:
Mar 31, 2009. 2:30 PMluthiz says:
These are nice juggling balls, for sure. I suggest getting the highest quality balloons you can find, to avoid the rotting funk that results from the lower quality rubber drying out.
Jun 15, 2007. 6:04 PMBurningApple says:
I just got 3 tennis balls. As soon as I get the balloons, I am soooo gonna make this. Thanks! +
Mar 15, 2009. 5:34 AMcupebill says:
You don't actually need the tennis balls. Take a balloon and fill it with sand. Cut the neck and the bottom off of a second balloon. Wrap it around the first. Done. It's really tough, but if your worried, add a third. Rotate the openings so they don't match and these little buggers last a long time. Maybe I'll do an inst4rutable on that soon. So easy. Kinda like the rice idea mentioned elsewhere. Lighter for those who need it.
Jan 17, 2009. 10:32 AMbassclarinet23 says:
I've been looking for a cheap way to get some nice juggling balls...these are nice.
Oct 13, 2008. 7:15 PMjayro707 says:
Jan 17, 2009. 10:28 AMbassclarinet23 says:
Jan 12, 2008. 3:27 PMlawizeg says:
I hear you.
Jan 17, 2009. 10:23 AMbassclarinet23 says:
They're cheap, but at the cost of their employees.
Mar 24, 2008. 12:35 PMA good name says:
metacafe videos haven't been working lately :(
Apr 22, 2007. 7:33 AMntgrater says:
If you want to work out you arms you can fill them with bbs or lead shot
Mar 21, 2008. 1:27 AMFull Frontal Graphic says:
I use cast iron balls from http://www.castironballs.org
plus it's just fun to have a set of cast iron balls.
Nice instructable. These are very similar to the stress balls we sold at a store I worked, they were several dollars each wholesale.
Apr 24, 2007. 11:17 AMendotoxin says:
I was just about to mention this as well. So-called Exerballs can cost as much as $90 a set, but this gets anywhere between 1 and 1.75 lbs per ball for perhaps a $12 investment. I also use rubber cement to seal the hole before wrapping it in a balloon for stability.
Mar 21, 2008. 1:31 AMFull Frontal Graphic says:
Cast Iron Balls sells their bigger size for under 30 for 3 balls... they will last for centuries and are 100% recycled
Mar 21, 2008. 10:59 AMendotoxin says:
Where does one find cast iron balls? Are you talking about "Grape Shot" or something different?
Mar 21, 2008. 3:46 PMFull Frontal Graphic says:
No, they have 2 inch and 2-and-a-half-inch / 2-pound solid cast iron balls
The ones I have are shiny plated, but they sell plain iron too.
I put the address on an earlier post... but if you cant spot it, :http://www.castironballs.org
Apr 30, 2007. 4:11 PMLlama Nerds says:
You can also do something similar for a lot cheaper: Get a few rolls of pennies and stuff them in the tennis balls. I have some of these I've used for a nice workout. I'll have to do the balloon thing to them to dress them up a little. Also, anyone know how well the tennis balls would bounce if you didn't cut them or fill them, just wrapped the balloons around them? I suppose racquetballs might be cheaper....
Apr 10, 2009. 9:49 AMLlama Nerds says:
Having tested my own theory, I can say that the balloon rubber has no effect on the bounciness of the tennis balls. I've done this with a few tennis balls I had laying around, and they work fine for reverse juggling.
Apr 9, 2009. 11:57 PMfrollard says:
You dont want bounce in juggling balls...hence why you half fill them with dirt or sand - it absorbs the impact.
Apr 10, 2009. 9:48 AMLlama Nerds says:
I actually like having bounce in my balls (heh) so that I can do reverse juggling too.
Apr 10, 2009. 6:57 PMfrollard says:
this is true - bounce juggling balls want a lot of bounce - when learning you want balls that will absorb the hits with your hands to ease catching.
Apr 24, 2007. 8:04 PMntgrater says:
make sure you fill them all the way or the will spin off balance i found if you put some sand in them they balance out
Apr 21, 2007. 8:16 PMSgt.Waffles says:
Thats pretty cool! Too bad i dont know how to juggle though. +
Apr 23, 2007. 7:30 AMich bin ein pyro says:
again geez you stole what i was gonna say also if someone does know how they could post an instructable on that
Dec 2, 2007. 2:23 PMsilverpapermaker says:
i dont know how to juggle but i could make like 20 of those and have wars with my friends..... ow bloody nose owowow crap ow i need a tissue!!
Apr 30, 2007. 4:14 PMLlama Nerds says:
I know how, but I don't have a video camera. If I can figure out a good way to present it using just still pictures, I'll post one.
May 1, 2007. 6:28 PMLlama Nerds says:
Okay, it's up here. Enjoy!
Oct 22, 2007. 6:11 PMKLUTZYscientist says:
Joy, my own dirt filled juggling balls, and for "Sgt. Waffles", what was the point of watching this video if you have not learned to juggle? But in all .. I liked the idea ..
Sep 15, 2007. 6:56 PMdacker says:
If dirt or sand is too much weight for some, try uncooked rice, dried beans beans, or dried peas. I've used rice or beans for my juggling beanbags ( which are better for learning to juggle than rigid balls.) Mmmm, rice & beans. Now I'm hungry!
Jul 19, 2007. 6:49 PMmaxpower49 says:
you need to add some sound to the viedo
May 1, 2007. 9:59 AMwalkthewalk says:
Pretty cool. I used to do something similar to make practice street hockey balls. After filling with dirt, I just wrapped it with duct tape.
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:burningion
