3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make laser-cut jewelry for Valentine's Day
Step 7Adding a hole
Adding a hole
In this step I need to create a hole so that the Pendant can be hung from a chain.
I start by creating some guides so I know that I will be getting the hole in the middle of the shape. I click and hold at the side of the screen on the page rulers. I then drag guides out and position them roughly where i want them. I double click on the guide and a dialog box opens that allows me to edit the value so i can define exactly where they are. I enter the value to the nearest 10. I then reposition the rectangle so it snaps to the guides.
(You can edit your guide properties by going to File:Document Properties and adjust the snap sensitivity)
I create a 3mm circle which will be the hole in the Pendant. I drag another guide onto the screen. This guide is to centre the hole. I know the circle is 3mm so I set the dimensions for the guide 1.5mm off the center of the rectangle. This way when i position the circle on the guide it will be in the middle of the rectangle.
I drag another guide which I set 2mm down from the top of the rectangle and then reposition the circle so it is on the guides.
Zoom out and group the circle and the rectangle.
2 comments
Jul 4, 2008. 10:31 AMKoLAddict says:
how do you make the guides on the top and left sides measure in millimetres? they only measure in pixels for me.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:danemery
