Step 8Tracing the butterfly
Some of the terms I use may be unfamiliar, especially if you haven't used Inkscape before - but do not worry!
The video shows you what to do so you'll get to see what the terms mean. If you do want to become more familiar with some of the terms and concepts of vector graphic software, you can check out Inkscape's help manual.
Set up your drawing area
Use the magnifying glass to zoom in on part of the image.
Draw a rough shape
Select the pen tool and draw a rough outline over the top of the image.
I did this by drawing points along the outline of your image. I hold down the mouse button and and transform each point into bezier curves by dragging the handles that appear on each side. In the video, you'll see how I use these handles to edit the curves of the butterfly.
Refine your shape
With the shape roughly traced, go through and edit each bezier so the curve matches the curves of the butterfly.
Finishing your Shape
At this point it's easier to see how your finished butterfly will look if you remove the imported image from your drawing area. You can then make any additional tweaks.
Add Comment
