If there is anything that you think I should improve just tell me, because this is my first Instructable.
Remove these ads by
Signing UpStep 1Tools and materials needed
Tools you will need
A hot glue gun cool heat, not high heat, high heat will melt through the foam backer rod
A knife
Materials you will need
Half inch Foam Backer Rod or FBR( can be found at Home Depot or any other hardware store) don't get Foam King, it's junk
Steel airgun shot, or steel BBs .177 Cal. or 4.5 MM, they are both the same
Performix Plasti Dip( can be found at the Home Depot in the paint area around the spray paint)
A carpenters square, but if you don't have that you can just use two rulers( one to measure the FBR and one to keep it straight.
Home Depot, I said where to buy it right after the name
p.s. I want a magstrike
