How to make moonshine by pdub77
Featured
WARNING!!!!!
this is for informational purposes only and should not be used for illegal activities. there are many legal things one can do with a still including fueling cars (must register with the federal government) as well as extracting essential oils from plants (not necessary to register). also, implementing the following procedures could result in bodily harm from explosions, fires, burns, not to mention what could happen if you actually consume your final product. use your head, be careful and be safe.
Thank you to everyone who has made this a successful Instructable!  I appreciate the views and positive feedback.  Please cut me some slack where I am lacking.  I have recently updated to include a few more specifics, but this does not take the place of doing your own research.  I am not an expert, though I play one on TV.  I am also toying with a discussion forum for all the numerous repeat questions.  Please continue to check the comments discussions before posting questions.  Many have been answered before and plenty more than once.
as a further note, i have decided to add this link to clear up any misunderstandings about what United States law has to say about distilling. Hopefully this will make some of you think a little harder about this and the rest to stop posting comments debating the legality of this. This is ONLY for the US.
Distilling Code
let's begin.
anything alcoholic can be distilled. i've distilled everything from my own moonshine washes to jug wine purchased at my local liquor store. distillation is actually quite simple. the hard part is making sure you are getting ethanol and not methanol (or the like). in this instructable i will show how i made a wash, fermented it, and consequently--the most important part--how i distilled it. i have added more specifics in order to answer some of the most asked questions i've gotten in the comments.  i hope this helps. i might also mention that everything here is hypothetical and for informational purposes only. hope that covers the bases.
and. . . let's begin. for real this time.
(if this doesn't make sense or you would like more info, check out my instructable--distilling basics--for more detailed information on the distillation process or read through the comment strings before posting a question.  I get repeat questions constantly and I don't have time to answer the same questions over and over.  Sorry.)
Step 1: Fermentation
i used a sugar water solution to create a wash which i then distilled to a neutral spirit. i dissolved about 5lbs of sugar in 3 gallons of water (not an exact formula, play around a bit) and then let it cool to room temperature. this is about as basic a wash as you can get. many more options are available for different flavor characteristics.  for instance, if you ferment molasses you will end up with rum.  if you ferment blue agave you will end up with tequila. i was looking for simplicity for a beginner and ran with this. it is the easiest to procure and make. unfortunately white sugar creates a decidedly cidery flavor to the spirit, but much of that can be distilled out or masked by flavoring or blending.
the wash (fermentable solution, a.k.a. sugar water) was then poured into a clean carboy (big glass bottle, see pic). after that i 'pitched' the yeast (dumped yeast into wash) and then capped the carboy with an airlock (see pic). now we wait. depending on yeast, temperature, amount of digestible materials, etc., a couple of weeks is usually good. at this point yeast is eating sugar, and excreting carbon dioxide and alcohol. give it some time. let it work. when the bubbles stop (and look close) it's done.  if it is still bubbling, let it go.  the two week time is just a very rough estimate.  it will vary for everyone.
if the bubbles have slowed considerably, taste a bit. if it is sweet, let it go a bit longer.
when it is done. we're ready for the next stage:
distillation.
Step 2: The pot
in this instructable i will be making what is known as a pot still. it is a very basic design, but can be reasonably efficient. there are many variations on pot stills and many other types of stills. some more advanced, some less. this will be fine for our purposes, though.
helpful hint: goodwill and other thrift stores are great places to scrounge parts.
you'll need:
a tea kettle
a medium sized thermos
a cork stopper that fits the kettle mouth(I used rubber, but cork is safer, use that.)
copper tubing
a pipe cutter
tubing couplers
a thermometer
various other tools and what not
okay, let's get down to business.
drill two holes in the stopper. one to fit the copper tubing, and one for the thermometer. i'm using a digital cooking thermometer with a wire probe, but analog thermometers will work as well.  drill the holes just a bit smaller than the tube and thermometer probe to make sure you have a tight fit.  you don't want any leaks.
the stopper will fit in the spout of the kettle a la the photo.  your tube should be out of the liquid to capture the vapors and your thermometer probe should be immersed in the water, but NOT touching the bottom or sides of the kettle.  the kettle will get hotter than the liquid and skew your results.  you only want the temperature of the liquid.
the copper tube should be long enough to connect to the condenser (attach a coupler on the end). ah, the condenser. on to thee!
Step 3: The condenser
the pot was easy. the condenser takes a bit of finagling. whatever the inside diameter of your thermos is, you want to find something like a 20oz soda bottle or some suitable tube-like thing that is a bit smaller and wrap your copper tubing around it to make a neat little spiral (careful, copper kinks easily).  tube benders are available.  they are basically big springs that slide over the tube and allow you to bend without kinking.  filling the tube with salt, sugar, or even sand can work as well.  i was just really careful and bent slowly and it worked fine for me.
the bottom end of the spiral exits through a hole cut in the lower side of the thermos. the top will exit a hole cut in your thermos lid (see pic). seal the area around the exiting tube at the bottom. seal it well and let it dry completely before you use it. test it before you go full throttle, as well.
thread the top of the copper through the hole in the center of the lid (if it is a screw type, like mine, you want to be able to unscrew the lid to fill and empty) and attach an appropriate coupler that marries with the one coming from the pot. spend a little time in the plumbing department of your local hardware store and i'm sure you'll find something that will work (look at the pictures). just do not use anything that contains lead. very important!
anyway, let's learn how to use this thing.
Step 4: Implementation
fill your condenser with ice and water (a little salt wouldn't hurt either, lowers temperature - think ice cream). attach the copper tube coming from the pot to the tube from the condenser with the couplers. place something under the spout to catch your shine and go to town.  it may be good to have more than one receptacle.  you will see why if you continue reading.
now we need some heat. back in the day people would use wood fires, gas stoves, basically anything they could get their hands on. dangerous! play it safe. open flames are not good around a still. alcohol vapors are flammable! as well, precise temperature control of your heat source is not necessary. the solution will take care of that. electric heat is the best.
check the pic. i'm using an electric stove. works great. you can see how i have it set up and i hope it all makes sense now. you load your wash into the kettle/pot, apply some heat, and condense the results.  how?  i'll tell you if you'd just be patient.  geez.
okay, pour your wash into the kettle. place the stopper into the spout. turn on the heat. watch the thermometer. alcohol boils at a temperature lower than water. that's what makes distillation work. exact temperature will vary depending on elevation and barometric pressure, but water boils at around 212 °F while ethanol boils at around 173 °F.  methanol, that can make you blind and is what you really want to avoid, boils around 148 °F. while running your wash, watch for plateaus (when the temperature stays the same for a while -- forms a plateau if you graph it) on your thermometer and compare them to known boiling temperatures to ensure you get only what you want and leave the rest. check out my instructable to give you the basics of distillation.
basically if you begin to distill and the temperature reaches a certain point and remains there for any length of time you have reached the boiling temperature for a particular liquid component of your wash. check the temperature against the boiling point data you have researched and you can tell what it is you are distilling at the time. using this information you can discard anything other than ethanol. no matter what a solution contains, it will not boil at a temperature any higher than what the level of the component with the lowest boiling temperature is until that component is boiled away. check the comments or 'distilling basics' for a discussion or two on this.
as an example, if your solution contains methanol, ethanol and water it will happen like this: once the temperature of your solution reaches around 148 °F methanol will begin to boil and come out through your tube as vapor into your condenser where it will convert back to liquid and exit into your receptacle.  the temperature of your solution will not vary much beyond 148 °F until the methanol is gone and then will begin to climb again until it reaches 173 °F, the boiling point of the ethanol.  the same thing will happen here.  the temperature will hover around the same until the ethanol is boiled off and then on to water.
in order to get ethanol and exclude the rest you get rid of what are called the 'heads' and 'tails.' basically dump anything that boils lower than around 173 °F and everything after the temperature begins to climb again.  this is why i mentioned having more than one receptacle. use one for the heads, one for what you want, and one for the tails.
so once you've boiled off and then condensed your wash, you should be left with a solution containing a much higher alcohol content than what you started with.  you will still get a bit of water, but that's okay. running the product through the still again will further extract ethanol and raise the proof.
a bit of trivia: the Xes often seen on moonshine bottles in old cartoons, etc. represent the amount of runnings, or how many times it was distilled.
i've achieved a blue flame from a wash after a first run with this set up. you may or may not need to run the wash more than once. anything over about 150 proof will burn.  that's a pretty good result from a single run.
i do not recommend doing anything i've talked about. it's not very legal (in the US), and it's not very safe. i enjoy knowledge for the sake of knowledge, though, and just because i know how to do something doesn't mean i will. so take this to heart, and take care.
peace.
-p
1-40 of 935Next »
Jackoffmanytrades says: May 17, 2013. 6:23 PM
People didn't go blind from the methanol they went blind from the lead in the solder. Also some makers used old automobile radiators to cool down the product that's another reason why also metals other then copper or stainless. Alot of makers used whatever they could to make that cash from their shine.
wanabepro says: Apr 9, 2013. 4:21 PM
thank you pdud
if the thermometer is in the liquid what would the temperature brakes be for the head and tail
wanabepro says: Apr 9, 2013. 8:20 AM
wanabepro
I would like some info on installing a thermometer in my distiller .should I install the probe in the top to read the temperature of the vapor or in the bottom to read the liquid.
please help
pdub77 (author) says: Apr 9, 2013. 11:08 AM
The thermometer should go in the liquid and not touch the sides or bottom of the still.
Dogric says: Mar 18, 2013. 2:56 PM
How long can the wash/mesh sit after it stops bubbling? Does it effect the Alcohol?
tony5120 says: Jan 26, 2013. 4:46 PM
when running your product for the second time do you use the same water or do you need clean water. just made first batch and need some help
Pantera22802 says: Mar 14, 2013. 2:37 PM
You dont use any water your putting the alcohol back in the still to reduce the impurities and up the proof
Pantera22802 says: Mar 14, 2013. 2:30 PM
Watch this video this guy has a better still and explains it a lot better! He knows what he is doing! You only throw the head of the 1st run away and add the tails to the next run makes no sence to throw the tails away otherwise why not just turn the still off! Think about that.
http://www.youtube.com/watch?v=P-nGbAf81Zs
Dogric says: Mar 10, 2013. 10:01 AM
Do I need to throw out the head and tail on the second and third run?
Pantera22802 says: Mar 14, 2013. 1:35 PM
No you don't have to throw the heads away on the 2nd run if you threw them away on the 1st run and the tails always keep them and add them to next run because they still have good alcohol in them.
no clue says: Feb 11, 2013. 6:14 PM
is the coupler copper like the tubing
TJ72 says: Jan 27, 2013. 7:47 PM
Actually anything over 100 proof or 50% alcohol will burn. You claimed 150 proof.
BullFrog22 says: Jan 18, 2013. 11:30 PM
Just curious as to how high you turned the heat up on your stove. And can I just run the heat until it gets between 153 and 172 to get out the methanol, then when thats done boiling off turn it up to hit the ideal temp of approx. 173 to get the ethanol or should I keep it at a constant setting the whole time and let the temp. climb. Just a little unclear. Sorry if you've answered this already. I read all the comments and was never clear on that.
fragmaster4 says: Feb 25, 2010. 6:28 AM
I'm pretty sure you can make 100 gallons of alcohol for your own personal use in the U.S. You can MAKE Moonshine but you can't sell it. THAT is what is illegal about it.
mookiex4 says: Jan 2, 2013. 10:43 AM
You are not allowed to make a drop of the product. Beer and Wine wasn't legal until Carter. Unlike many other countries, (ie: New Zealand), I cannot see anytime in the foreseeable future that we will be able to make what we want to make for ourselves without the government regulating it.
amarlar says: Dec 5, 2012. 4:36 PM
Just because something's legal by state law it can still be legal by federal law. For example, marijuana is legal now under Colorado law but it's still a federal offense.
TennesseeGunslinger says: Jun 6, 2012. 12:58 PM
Nope, not in the US - can't make a drop without a distiller's license (Federal and State).
seasheead says: Feb 25, 2012. 3:49 AM
If you distill even a thumble of likker, your comitting a Federal Crime. You don't have to sell it to get locked up you just have to make it!
whiskymonster says: May 9, 2011. 1:47 AM
nope. every still must be registered and regulated by the govnt. its easy enought to get a fuel alc license, but its expensive
bobby73 says: May 14, 2012. 7:26 AM
http://www.moga.mo.gov/statutes/C300-399/3110000055.HTM
bobby73 says: May 14, 2012. 7:19 AM
According to the Missouri statutes in Mo. you can make 100 gals of distilled alcohol, 200 gals if there are more than one person over the age of 21 living in the residence per year. But it has to be for personal and family consumption it can not be sold
TennesseeGunslinger says: Jun 6, 2012. 1:00 PM
Nope - not a drop. It's a federal law.
pdub77 (author) says: Feb 25, 2010. 4:11 PM
Not true.  You can make certain amounts of beer and you can make certain amounts of wine, but you cannot make liquor of ANY quantity without registering your still with the federal government and therefore, I would assume, pay the taxes on it.
I'm not sure why I'm debating this.  Check my link about distilling laws.  And if you still don't agree, cite your statute.  = )
chinds says: Jun 20, 2011. 12:01 AM
pdub77 is right, you can brew beer, wine, mead, and that kind of stuff all day long in your garage as long as you're not under 21 and not distributing it. i believe you need a business license to distribute it. not sure about the liquor thing though, but moonshine, aka 100% pure alcohol is illegal to possess just like a drug. everclear is only legal because it's made by government-authorized stills and is only about 99% pure, they add that 1% of water just to be pricks. lol i think you might be able to register a moonshine still for ethanol-powered vehicles though, but it's probably expensive to get the license and you gotta pay taxes.
pdub77 (author) says: Jun 20, 2011. 4:17 AM
You can't get 100% pure ethanol with a basic still. Google 'azeotropic solution' to see what I'm talking about here.
ppires00 says: Dec 16, 2012. 8:11 AM
i was just reading some of these post to learn more cause there is always something to learn about this hobby. i have been learning about this for about 4 years . and the one thing i learn is if you making high proof stuff inside your house on your stove you need to stop a pot with paper clips and tape around the copper please stop befor you hurt yourself and your family the steam at 173 degrees if it escapes you will hate your self for the rest of your life if you even make it. it took me a year to build a proper still and make my first run this stuff is a art and there alot of info on the net to do it right take your time dont rush if you have questions orneed help with something ask ask ask ill even ansewer anything i can but i ony ansewer if i know the ansewer to be a fact not a opinion
mookiex4 says: Jan 2, 2013. 10:41 AM
Water boils at around 212 and depending on altitude where you live Alcohol will vaporize at 168 to 174. If you run too hot all you have to do is call that a stripping run and do a distillation run as a second run.
madmans firework emporium says: Dec 6, 2012. 4:15 PM
if the tails are only water, why do you need to remove them? are they detrimental to the final product?
mookiex4 says: Jan 2, 2013. 10:37 AM
The tails contain any remaining sediment that may have passed when filling the distiller. It will ruin the flavor of the product. Not to mention if you just keep distilling like Vodka. if you read the bottles of vodka that say they are triple distilled or more, what theya re saying is they have distilled all flavors from the product and it is as pure as it can become.
lukeyj15 says: Dec 17, 2012. 5:34 PM
They water it down, and you end up with the by-products of yeast in the final product. What professional vodka producers do is get the proof as high as they can, filter the vodka heaps, and then dilute it to a drinkable proof with pure water. It just yields a cleaner result.
moonshine dave says: Dec 29, 2012. 9:24 AM
illegal as it is there are some who continue to keep one of the oldest professions active (ain’t life great).
Yes making alcohol is one of the oldest professions, this one led to the other oldest profession we hear about.
Not that I would admit to making this myself, due to the federal laws prohibiting the distilling of spirits….
I have heard that to make a wash, use 18 pound of table sugar adding enough luke warm water till you have
6 ½ gallons of wash. Stir in a package of “Turbo Yeast”, seal the fermenter and let it go till bubbling has quit. If the wash is cloudy, use “Turbo Clear”. When the wash is clear, siphon off into the still and go for it.
I have heard that it will take several hours to distill a wash this size using a 7 gallon pot still and produce around 21/2 to 3 1.75 liter bottles of 130 proof moonshine, it varies.
Turbo Yeast, Turbo Clear, fermenting containers, 7 gallon still can be obtained at the local wine/beer making store or online.
WARNING: The consumption of alcohol may create the illusion that you are tougher, smarter, faster and better looking than most people and make you think people are laughing WITH you.
wicked_acer says: Dec 16, 2012. 2:50 PM
what does it mean if you are boiling the stuff and it passes 174 and stops at 200 but is still producing spirts? is it still safe to drink?
kevans59 says: Dec 6, 2012. 4:21 PM
what would be a good frist run and the measuremint of mash in a 5 gallon jar and how long to let it sit
amarlar says: Dec 5, 2012. 4:32 PM
How much yeast should I pour in?
cantrellsp says: Nov 9, 2012. 8:23 PM
hey pdub I hope your still responding. I have a quick question. Throw everything out until it reaches 173 degrees. Then do you immediatly want to keep the 173-2105 degree product or should you wait a few minutes once it hits 173 to make sure all the methanol is out??
cantrellsp says: Nov 9, 2012. 8:24 PM
173-205 degree sorry typo
munkeyman22 says: Nov 8, 2012. 2:00 PM
ok so after i put the wash into the kettle and i dis gaurd the head n tail must i do this every time i put wash into the kettle since the whole wash will not fit all into the small kettle, remember this is all still from the same wash
cheif lemaster says: Aug 14, 2012. 9:37 AM
pdub77 i am lil confused on your heads and tails.. what are they???
RichardBronosky says: Nov 7, 2012. 9:15 PM
Heads = what boils off first (at low temp, Methanol)
Tails = what boils off last (at high temp, Water)
Middles = what boils off after the Heads but before the Tails (at ~173°F, Ethanol)
I hope that helps.
What's really fascinating is why the temperature plateaus and only a certain liquid boils off. To understand this you will learn about the definition of a calorie[1] (or gram calorie). Specifically, 1 calorie is the amount energy required to raise 1 gram (or cc) of water by 1 degree centigrade. That is until it reaches its boiling temp. (Here is where it gets interesting.) At boiling temperature (100°C), it takes an additional 540 calories to evaporate 1 gram of water. That's a big difference between 1 calorie and 540 calories. The Associative Property of multiplication allow us to state that another way: The energy that could raise 540 grams of water 1 degree, goes into evaporating a single gram of water. Let's apply this!
The energy required to raise the temp of a solution is going to be absorbed and used in the "power hungry" endothermic evaporation process of the part of the solution with the lowest boiling point. You don't have to be very precise with your heat delivery because evaporation is taking drastically more energy than raising the temperature. What you do have to be careful about is the precision of your temperature measurement.
[1] http://science.howstuffworks.com/dictionary/geology-terms/water-info2.htm
[2] http://en.wikipedia.org/wiki/Thermodynamic_equilibrium
zombiefire says: Oct 18, 2012. 6:57 AM
could you add some tags please cos i dont understand the pic's much
1-40 of 935Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
