loading
WARNING!!!!!
this is for informational purposes only and should not be used for illegal activities. there are many legal things one can do with a still including fueling cars (must register with the federal government) as well as extracting essential oils from plants (not necessary to register). also, implementing the following procedures could result in bodily harm from explosions, fires, burns, not to mention what could happen if you actually consume your final product. use your head, be careful and be safe.
Thank you to everyone who has made this a successful Instructable!  I appreciate the views and positive feedback.  Please cut me some slack where I am lacking.  I have recently updated to include a few more specifics, but this does not take the place of doing your own research.  I am not an expert, though I play one on TV.  I am also toying with a discussion forum for all the numerous repeat questions.  Please continue to check the comments discussions before posting questions.  Many have been answered before and plenty more than once.
as a further note, i have decided to add this link to clear up any misunderstandings about what United States law has to say about distilling. Hopefully this will make some of you think a little harder about this and the rest to stop posting comments debating the legality of this. This is ONLY for the US.
Distilling Code
let's begin.
anything alcoholic can be distilled. i've distilled everything from my own moonshine washes to jug wine purchased at my local liquor store. distillation is actually quite simple. the hard part is making sure you are getting ethanol and not methanol (or the like). in this instructable i will show how i made a wash, fermented it, and consequently--the most important part--how i distilled it. i have added more specifics in order to answer some of the most asked questions i've gotten in the comments.  i hope this helps. i might also mention that everything here is hypothetical and for informational purposes only. hope that covers the bases.
and. . . let's begin. for real this time.
(if this doesn't make sense or you would like more info, check out my instructable--distilling basics--for more detailed information on the distillation process or read through the comment strings before posting a question.  I get repeat questions constantly and I don't have time to answer the same questions over and over.  Sorry.)
Step 1: Fermentation
i used a sugar water solution to create a wash which i then distilled to a neutral spirit. i dissolved about 5lbs of sugar in 3 gallons of water (not an exact formula, play around a bit) and then let it cool to room temperature. this is about as basic a wash as you can get. many more options are available for different flavor characteristics.  for instance, if you ferment molasses you will end up with rum.  if you ferment blue agave you will end up with tequila. i was looking for simplicity for a beginner and ran with this. it is the easiest to procure and make. unfortunately white sugar creates a decidedly cidery flavor to the spirit, but much of that can be distilled out or masked by flavoring or blending.
the wash (fermentable solution, a.k.a. sugar water) was then poured into a clean carboy (big glass bottle, see pic). after that i 'pitched' the yeast (dumped yeast into wash) and then capped the carboy with an airlock (see pic). now we wait. depending on yeast, temperature, amount of digestible materials, etc., a couple of weeks is usually good. at this point yeast is eating sugar, and excreting carbon dioxide and alcohol. give it some time. let it work. when the bubbles stop (and look close) it's done.  if it is still bubbling, let it go.  the two week time is just a very rough estimate.  it will vary for everyone.
if the bubbles have slowed considerably, taste a bit. if it is sweet, let it go a bit longer.
when it is done. we're ready for the next stage:
distillation.
Step 2: The Pot
in this instructable i will be making what is known as a pot still. it is a very basic design, but can be reasonably efficient. there are many variations on pot stills and many other types of stills. some more advanced, some less. this will be fine for our purposes, though.
helpful hint: goodwill and other thrift stores are great places to scrounge parts.
you'll need:
a tea kettle
a medium sized thermos
a cork stopper that fits the kettle mouth(I used rubber, but cork is safer, use that.)
copper tubing
a pipe cutter
tubing couplers
a thermometer
various other tools and what not
okay, let's get down to business.
drill two holes in the stopper. one to fit the copper tubing, and one for the thermometer. i'm using a digital cooking thermometer with a wire probe, but analog thermometers will work as well.  drill the holes just a bit smaller than the tube and thermometer probe to make sure you have a tight fit.  you don't want any leaks.
the stopper will fit in the spout of the kettle a la the photo.  your tube should be out of the liquid to capture the vapors and your thermometer probe should be immersed in the water, but NOT touching the bottom or sides of the kettle.  the kettle will get hotter than the liquid and skew your results.  you only want the temperature of the liquid.
the copper tube should be long enough to connect to the condenser (attach a coupler on the end). ah, the condenser. on to thee!
Step 3: The Condenser
the pot was easy. the condenser takes a bit of finagling. whatever the inside diameter of your thermos is, you want to find something like a 20oz soda bottle or some suitable tube-like thing that is a bit smaller and wrap your copper tubing around it to make a neat little spiral (careful, copper kinks easily).  tube benders are available.  they are basically big springs that slide over the tube and allow you to bend without kinking.  filling the tube with salt, sugar, or even sand can work as well.  i was just really careful and bent slowly and it worked fine for me.
the bottom end of the spiral exits through a hole cut in the lower side of the thermos. the top will exit a hole cut in your thermos lid (see pic). seal the area around the exiting tube at the bottom. seal it well and let it dry completely before you use it. test it before you go full throttle, as well.
thread the top of the copper through the hole in the center of the lid (if it is a screw type, like mine, you want to be able to unscrew the lid to fill and empty) and attach an appropriate coupler that marries with the one coming from the pot. spend a little time in the plumbing department of your local hardware store and i'm sure you'll find something that will work (look at the pictures). just do not use anything that contains lead. very important!
anyway, let's learn how to use this thing.
Step 4: Implementation
fill your condenser with ice and water (a little salt wouldn't hurt either, lowers temperature - think ice cream). attach the copper tube coming from the pot to the tube from the condenser with the couplers. place something under the spout to catch your shine and go to town.  it may be good to have more than one receptacle.  you will see why if you continue reading.
now we need some heat. back in the day people would use wood fires, gas stoves, basically anything they could get their hands on. dangerous! play it safe. open flames are not good around a still. alcohol vapors are flammable! as well, precise temperature control of your heat source is not necessary. the solution will take care of that. electric heat is the best.
check the pic. i'm using an electric stove. works great. you can see how i have it set up and i hope it all makes sense now. you load your wash into the kettle/pot, apply some heat, and condense the results.  how?  i'll tell you if you'd just be patient.  geez.
okay, pour your wash into the kettle. place the stopper into the spout. turn on the heat. watch the thermometer. alcohol boils at a temperature lower than water. that's what makes distillation work. exact temperature will vary depending on elevation and barometric pressure, but water boils at around 212 °F while ethanol boils at around 173 °F.  methanol, that can make you blind and is what you really want to avoid, boils around 148 °F. while running your wash, watch for plateaus (when the temperature stays the same for a while -- forms a plateau if you graph it) on your thermometer and compare them to known boiling temperatures to ensure you get only what you want and leave the rest. check out my instructable to give you the basics of distillation.
basically if you begin to distill and the temperature reaches a certain point and remains there for any length of time you have reached the boiling temperature for a particular liquid component of your wash. check the temperature against the boiling point data you have researched and you can tell what it is you are distilling at the time. using this information you can discard anything other than ethanol. no matter what a solution contains, it will not boil at a temperature any higher than what the level of the component with the lowest boiling temperature is until that component is boiled away. check the comments or 'distilling basics' for a discussion or two on this.
as an example, if your solution contains methanol, ethanol and water it will happen like this: once the temperature of your solution reaches around 148 °F methanol will begin to boil and come out through your tube as vapor into your condenser where it will convert back to liquid and exit into your receptacle.  the temperature of your solution will not vary much beyond 148 °F until the methanol is gone and then will begin to climb again until it reaches 173 °F, the boiling point of the ethanol.  the same thing will happen here.  the temperature will hover around the same until the ethanol is boiled off and then on to water.
in order to get ethanol and exclude the rest you get rid of what are called the 'heads' and 'tails.' basically dump anything that boils lower than around 173 °F and everything after the temperature begins to climb again.  this is why i mentioned having more than one receptacle. use one for the heads, one for what you want, and one for the tails.
so once you've boiled off and then condensed your wash, you should be left with a solution containing a much higher alcohol content than what you started with.  you will still get a bit of water, but that's okay. running the product through the still again will further extract ethanol and raise the proof.
a bit of trivia: the Xes often seen on moonshine bottles in old cartoons, etc. represent the amount of runnings, or how many times it was distilled.
i've achieved a blue flame from a wash after a first run with this set up. you may or may not need to run the wash more than once. anything over about 150 proof will burn.  that's a pretty good result from a single run.
i do not recommend doing anything i've talked about. it's not very legal (in the US), and it's not very safe. i enjoy knowledge for the sake of knowledge, though, and just because i know how to do something doesn't mean i will. so take this to heart, and take care.
peace.
-p
Why is a coupler necessary? Why can't you just use a copper tube and just run it from the kettle to the condenser? Also, must the coupler also be copper?
<p>Great article. In my country it is legal to distill 86 litres of alcohol (p&aacute;linka) /year at home from fruits but we have to pay the tax on it because of the EU laws. By letting us to do it the government tries to preserve the tradition of the 100% made-of-fruits spirits versus the industrially produced (alcohol+sugar+coloring ingredients+who-know-what-sh@t-they-put-in-it) booze.</p>
it says only vapor at 178&deg; is what you want to take anything lower is not good to drink, how does this work with a thumper still? does the vapor coming out of the thumper have to be 178&deg; or how do you know alcohol is coming out of the thumper?
is the alcohol you want
<p>I don't have a thermostat a friend of mine who is all so stilling said I can use a lighter and a teaspoon as soon as I flick the lighter and draw the flame over the moonshine it must burn blue? if it doesn't burn it must be cast away and if its burning blue orange color must all so be cast away? only if it is a pure blue flame it is good to bottle? Can I rely on this method to avoid methanol?</p>
<p>I like your mini still idea mine was similar but it was actually a pot with the lid welded on. Unfortunately I forgot about possible gas build up and added ice to my condenser plus had a piece of coil bend down unknowingly : ( BOOM was my second run the cork blew out and what a mess! I have a background in chemistry and thought about all those big beautiful glass finishing stills that we all dream of being able to pay the 1-5 thousand$$$ for and went looking for copper at lowes. What came of that was a 3 foot long 3/4 inch copper pipe with a half inch inside pipe and a reducing coupler/tee at each end. the tees are 3/4 to 2 1/2 inch. weld like plumbing and perfecto. add a cold water suply to the bottom and attach a hot water washing machine hose to the top plus your water out at the side top. nobody thinks of the science anymore lol. I also use a pressure cooker that I found at a thrift store for $5 and wow it works nice. I was looking for new recipes to try but yours is almost exactly mine i just add 5 grams of yeast nutrient and I use corn sugar and make 4 times as much. I hope I gave you good ideas so keep happy and shine on :) remember to weld the pipes inside and out with a lead free solder if you try this and if you have any questions feel free to ask</p>
<p>it is interesting https://www.youtube.com/watch?v=WDqlqShgT6o</p>
Made basic sugar shine 10 pounds two quarts white grape juice five gallons water two packets of red star champagne yeast bubbled first and second day slowed way down taste sweet can I or should I pitch two more packs of yeast??
Anyone got any advice
If there were preservatives, it may prevent your yeast from doing its thing. Did you start the yeast in warm (not hot) water? How warm/cool is the environment, if it's too cold it won't ferment either. Just a few things to think about.
Did you activate your yeast before adding to the mash?
<p>I had somethin like that once.. Turned out the lid of my vessel was not properly closed. It is worth a check, including your airlock</p>
<p>Also if you are using a &quot;thumper&quot; or &quot;thump keg&quot; pour your grape juice into it, instead of using it in your mash recipe. You do not get a lot of flavors from the mash itself. Sure you can detect a little here and a little there. I assure you though if you do add them to thumper, you will be very pleased with your end flavor.</p>
<p>What was the temperature, Any mash is going to give you optimal performance at 75-95 degrees, with the optimal temperature being around 80-90 degrees. You do not have to have no fancy container with a &quot;bubbler&quot; on top. Because it isn't required to be airtight in order to perform. Old timers would use a wood barrel and cover it with a canvas tarp, or a piece of 2x2 plywood. I have &quot;seen&quot; people mash in many times in a 30 gallon stainless steel pot and cover it with a broken piece of marble counter top.</p>
Too small of a boiler
I've unsucessfully made many batches of shine and can't figure out what i'm doing wrong. I've been using corn, sugar, yeast, and water for my mash and let is sit for 3 days to ferment.(whether that's right or wrong i got it from a website) well any way when i try to distill it, it comes out cloudy not clear and definitly not drinkable. plus i've tried to keep my temp at 173 degress F. but nothing happens till about 200. there is some alcohol in the wash and when it comes out of the still but not much. Can any one tell me what i'm doing wrong?<br />
<p>Davids60 is right about temps usually 175-180F. Did you clean the copper first. Use 1/4 of vinegar and 3/4 water in your still on the first run. Other than that the only thing that comes to mind is burping which means it's to high of temp and your ingredients is boiling into your worm, instead of vapor only, which doesn't sound like your problem but could be a possibility.</p>
<p>Yep. You're temps are too high. You have to be PATIENT and let the vapor build up. </p>
<p>In a 4.5 gal pot still about 85% full... about how long does it take for that vapor to build &amp; produce once I reach 173. minutes? Hour?</p>
<p> 3 days is waaayyy tooo short. Sounds like your trying to make sourdough bread starter.</p>
Your running your still to high temp and sounds like you need to study up on fermenting start simple like this sugar shine three days is way early man
<p>pdub is right they yeast would not even finished multiplying even turbos take longer then that to ferment, but once you get it keep it up soon you won't buy likker at a store i know i havent in a long time.</p>
3 days is never enough time to ferment.&nbsp; Try two to three weeks.&nbsp; <br />
okay i didn't think it was long enough but i wasnt sure thanks. I'll let you know how it goes<br />
<p>First of all, I would just like to point out that if you engage in the art of using any vessel (i.e. still) for the purpose of making a product (i.e. liquor) into a more concentrated form you are NOT breaking a federal law. I reside about 60 miles from where the late hero Marvin &quot;Popcorn&quot; Sutton lived, there are about 4-5 articles every year in the newspaper and on the news starting in about April or May and ending in late September or early October. You are only committing a MISDEMEANOR when you distill spirits not a FELONY. while you can quote any federal or state statue there is available on the subject, and tell me word for word what the law says, I have never in my life known anyone to go to a FEDERAL PENITENTARY for violating a law that results in committing a MISDEMEANOR. Now with that being said, would it be a legal headache ? Check. Would it have every local law enforcement agency within it's legal jurisdiction sniffing around your place, and threatening you with anything they can imagine including the death penalty ? Check. The Federal authorities MIGHT involve themselves, but it is still rather highly unlikely. If you do have a 3,000 gal still then they will more than likely involve themselves, but with even a 50 gallon still it is highly unlikely, because they know they still face an uphill batlle convicting you of violating tax and alcohol laws Because in convicting someone of a crime in this great country, they will have to prove that without any REASONABLE DOUBT, that you were planning to profit tax free dollars off of the finished product. In other words maybe you were going to use it for &quot;personal reasons&quot;, or simply give it away. Now on to the facts. If you are caught transporting the liquor. FEDERAL CRIME. If you are caught selling the liquor. FEDERAL CRIME. Just ask yourself how many times have I ever heard of anyone in my life of going to a federal prison for possessing moonshine. My point exactly. Use your head and do not have a large operation with 300-400 gallons sitting around, and you are going to be fined and placed on 11/29 probation, we come back to REASONABLE DOUBT, because you were not conspiring to defraud the United States government, you were simply thirsty. Use your heads for more than a hat rack, quit watching, listening, reading, and subscribing to every scare tactic non-sense piece of fiction you can get your hands on, and do something that makes them squirm and cringe.......think for youself.</p>
<p>About recipies; it seemed that the legend Popcorn Sutton did not use any yeast. Or at least did not add it. Does anyone know the recipe of his mash?</p>
<p>I'm new to distilling. I made a still from a 22L canner. Clamps to seal the lid (I add clamps if there is any steam linkage), temp gage installed &amp; 10' 3/8 copper tube direct to a bucket as the worm. For wash I used cracked corn &amp; sugar fermented in an airlocked brewing bucked 8 days (mixed a few times) till bubbles stopped. I run it up to 175ish but the still will not produce. How long does it take for the steam to build up? Is there an easy way to test the still. I'm trying to figure out if it's the hardware or mash, or am I just not waiting long enough.</p>
I want to make corn whiskey the was it was made in the old times.i am reaearching recipies and techniques for a book if there is anyone who can help me i would be very much obliged.
<p>Hi Distill Bill. I recommend How to Make Moonshine by RW Marshall. I got a copy on Amazon...it's pretty thorough, and easy to understand. First part of the book is how to and includes corn whiskey recipes. Last half is recipes. Before reading it, I didn't know about using malt or amylase with the corn, but like Marydavet below, I agree, it's needed to convert starch into sugar when fermenting any grains into alcohol. </p>
<p>Moonshine by Matt Rowley Corn whiskey employed the use of germination of the seed, to convert the starch to sugar. Amylase is an easier and much simpler process.</p>
<p>Been looking into this type of stuff, having a hard time finding a yeast ratio though, any help?</p>
<p>Hi creative badger...I've found that those little packets of yeast you can buy at the wine store will be enough to do up to about 5 or 6 gallons of wine, beer or moonshine. You can make a 'starter' but I usually have no problem just adding it. Two things to watch, make sure your must is warm, but not above 90 degrees, and stir vigorously for a couple minutes to oxygenate it, since yeast do 'breathe'. Most yeasts you buy will have instructions for how much to use for a specific volume. I would recommend you stick to a wine or distillers yeast, since they will yield a cleaner flavor and higher alcohol level than bakers yeast or bread yeast. I found a really good book at Amazon called 'How to Master Moonshine' that takes you right through the process and gives lots of recipes too! It answered a lot of my questions that I didn't know before, like turbo yeasts. I found out it will give you up to 20 percent alcohol...I use one pack of turbo yeast, 4 - 2 kg bags of white sugar in about 5 gallons of warm water. It's also faster than other yeasts, hence the name I guess!</p>
depends on what kind of yeast you are using. I use red star dady and it calls for 1-2 grams per gallon ( i pay less than $10 for a pound of it one package will ferment up to 450 gallons) if you use turbo its a whole pack per 7 gallons. if you use bakers yeast I used one pack per 5 gallon bucket of wash.
Nice information first question if it burns a real good blue flame is that near 150 proof cause i though it was like a little over 50 percent it will burn if it is 150 proof yeah me . And second any info on these turbo yeasts cause the more i read it seems like they have set backs almost like to many nutrients that linger . They get into talking about carbon cleansing and such .which i dont think running it through a brita filter would be bad and way more simple and i like simple. I like the sugar wash very much straight and blends well so what proof does it burn blue and whats your take on turbo yeasts cause ive seen blue flames on bakers yeast .
yeast and color of flame have nothing to do with each other. turbo yeast is just a high abv yeast with nutrients already mixed in with them. the nutrients make the yeast work faster and live a little longer. turbo yeast can take your wash to 20%abv in a week bakers yeast is only good for about 15%abv and can take 2 weeks or more to get there. the trade off is turbo yeast can sometimes give off smells and or flavors that need to be filtered out. some hobbies find a yeast that gives no off flavors ( I use dady ) let that ferment for three or four days then pitch turbo to speed it up without giving it time to make the bad smells and flavors.
<p>One safety-related comment for all to consider: one should <em>never</em> distill alcohol in an enclosed environment such as the kitchen shown. Move your &quot;system&quot; outside <em>en</em> <em>plein air</em> as the French Impressionists of yesteryear did with their painting. One small leak, one ignition source and your containment structure (house, garage, kitchen, etc.), with all contained therein, will be subject to a rapid, unplanned, violent and potentially lethal, random--and, I am certain, unwanted--disassembly.</p>
<p>There's many dangers about making and consuming homemade moonshine.</p><p><a href="http://lessaccounting.com/moonshine" rel="nofollow">http://lessaccounting.com/moonshine</a></p><p>Plus it's a felony in many states, it's just not worth it, stick to brewing beer.</p>
<p>Most of that information is FUD spread by the ATF to continue support for keeping home distillation illegal and tax revenues up. For example, the first thing and most prominent warning is the risk of methanol. Methanol (wood alcohol) is produced by fermenting wood. Methanol is indeed a deadly poison and causes blindness it is required by the ATF to be added to &quot;denatured alcohol&quot; sold at the hardware store to prevent anyone from drinking it without paying tax. During prohibition people likely did try fermenting wood and removing methanol from the ethanol (drinking alcohol) sold at the hardware store.<br><br>It's important to remember almost all REAL dangers come from what is distilled because distillation is physical and not chemical process.* The output only contains the substances that were in the mash. If you distill a bottle of wine down to a glass of brandy drinking that glass is no more dangerous than drinking that bottle. You won't be any more intoxicated and generally speaking you won't be exposed to any more methanol, acetone, propanol, butanol, or amyl alcohols (all the things listed on that dangers site) than you would drinking the bottle of wine. That is regardless of whether the person doing the distilling knows what they are doing or not. They will be more concentrated of course but that generally balances out because the ethanol is what is most concentrated. In practice, every how to on making &quot;moonshine&quot; on the internet will tell you a method for removing the &quot;heads&quot; (lower but close boiling point elements like methanol) and tails (higher but close temperature elements) and following any of the above would mean the distilled output contains LESS of these undesirable substances than your starting bottle of wine.</p><p>That said, there ARE dangers. I just think repeating the same old tired nonsense detracts from them. Which is especially bad because they are easy to avoid in the modern age.</p><p>The only real danger of home alcohol distillate to the consumer that is not also in the liquid being distilled is in common with all lab processes is anything introduced by the distillation equipment. For example, if lead based solder is used to make a copper still (lead based solder is always clearly labeled as such), galvanized steel, or anything else which reacts with ethanol or releases something unexpected in the presence of heat. This is easily solved by lightly regulating equipment sold for distillation and spreading information about safe practices for those making their own equipment. The short answer is to stick with glass, pyrex, noble metals, and/or stainless steel. Any rubber should be made for high temperature lab use. Copper can be used with the correct solder the output will contain copper but within limits considered safe in drinking water. Some ceramics can be used as well but I hesitate to mention them because ceramic is a broad term for most any hardened mixture. You could make a ceramic containing lead for instance.</p><p>For the person doing the distilling there is the risk of explosion and fire if there were a substantial leak of fumes in the still. There are actually many many things at home that carry a similar level of risk and cooking with wine carries the exact same kind of risk, cooking with flour carries an even greater risk (a puff of flour in the air is a very powerful dust explosive). Again, standards on commercially produced equipment and spreading information is the answer here. <br><br>So if anyone reads this and is thinking about distilling. First, only ferment things that are safe to eat. Keep fermentation vessels sterile. Make fermentation vessels out of food grade HDPE plastic/g. If you aren't sure if it is food grade </p>
<p>This guy wins.</p>
I'm pretty sure you can make 100 gallons of alcohol for your own personal use in the U.S. You can MAKE&nbsp;Moonshine but you can't sell it. THAT&nbsp;is what is illegal about it.<br />
<p>FALSE. It is legal to make your own beer or wine in some locations but it is against FEDERAL law to concentrate the alcohol (distill it) from your mash. Not illegal to own a still, just to use it to distill alcohol. You can distill the chemicals out of your tap water though!</p>
<p>WRONG YOU CANNOT MAKE ANY MOONSHINE FOR ANY REASON ! I use our still to condense water, we have a shallow well we use for drinking water &amp; it makes it a 100% better tasting. it is done the same way as shine but, w/o mash. just plain water !!!</p>
You can make 100 gallons per year per person 21 and older in your house
Not true.&nbsp; You can make certain amounts of beer and you can make certain amounts of wine, but you cannot make liquor of ANY quantity without registering your still with the federal government and therefore, I would assume, pay the taxes on it. <br /> <br /> I'm not sure why I'm debating this.&nbsp; Check my link about distilling laws.&nbsp; And if you still don't agree, cite your statute.&nbsp; = )<br />
pdub77 is right, you can brew beer, wine, mead, and that kind of stuff all day long in your garage as long as you're not under 21 and not distributing it. i believe you need a business license to distribute it. not sure about the liquor thing though, but moonshine, aka 100% pure alcohol is illegal to possess just like a drug. everclear is only legal because it's made by government-authorized stills and is only about 99% pure, they add that 1% of water just to be pricks. lol i think you might be able to register a moonshine still for ethanol-powered vehicles though, but it's probably expensive to get the license and you gotta pay taxes.
pdub77 is right, it is physically impossible to distill an ethanol/water solution above 95.6% and that's why Everclear clocks in at 95% or 190 proof (in the states that high of a proof is legal). It's not them being pricks, it's a thermodynamic impossibility for them to go any higher with the product being safe for human consumption. Anything you see that is labeled as 200 proof ethanol is denatured, meaning that a third chemical has been added to the solution during distillation to break the azeotrope (limit). Chemicals such as benzene or cyclohexane are often used and residual amounts of those are why you should never ever drink any 200 proof ethanol.
You can't get 100% pure ethanol with a basic still. Google 'azeotropic solution' to see what I'm talking about here.
Good post. I saw another one where the guy was very unclear as to how to get rid of the methanol. He basically said throw out the first half cup of distillate. <br> <br>Here's the link to the ATF regulation governing distillation. Look at section/chapter 19. <br>http://www.gpo.gov/fdsys/pkg/CFR-2003-title27-vol1/pdf/CFR-2003-title27-vol1.pdf. You can't distill alcohol in the US without jumping through all kinds of hoops. You have to be bonded, your facility can only be used for distillation, no private residence, sheds or garages, permits from the ATF, yada, yada, yada. If you're running a still it better be for something other than alcohol. <br> <br>The amounts of beer and wine you can make are dependent on the state. I'm a home brewer BTW, not a distiller. (Although I wouldn't mind trying it) <br> <br>Also, I love the comment at the end of the post, &quot;just because i know how to do something doesn't mean i will&quot; Uhhh, you have a picture of a still, presumably yours, and you claim to have gotten a blue flame off a first run. Self incrimination? :-D <br>
You are not allowed to make a drop of the product. Beer and Wine wasn't legal until Carter. Unlike many other countries, (ie: New Zealand), I cannot see anytime in the foreseeable future that we will be able to make what we want to make for ourselves without the government regulating it.
Just because something's legal by state law it can still be legal by federal law. For example, marijuana is legal now under Colorado law but it's still a federal offense.
About This Instructable
4,023,185views
1,355favorites
License:
Bio: I like to make things
More by pdub77:Cómo hacer alcohol casero, conocido como "moonshine" Roll Your Own Bongo Cajon Emergency Backup Fluid for Zippo Lighter
Add instructable to:
