3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make moonshine
Step 2The pot
the pot
in this instructable i will be making what is known as a pot still. it is a very basic design, but can be reasonably efficient. there are many variations on pot stills and many other types of stills. some more advanced, some less. this will be fine for our purposes, though.
helpful hint: goodwill and other thrift stores are great places to scrounge parts.
you'll need:
a tea kettle
a medium sized thermos
a cork stopper that fits the kettle mouth(I used rubber, but cork is safer, use that.)
copper tubing
a pipe cutter
tubing couplers
a thermometer
various other tools and what not
okay, let's get down to business.
drill two holes in the stopper. one to fit the copper tubing, and one for the thermometer. i'm using a digital cooking thermometer with a wire probe, but analog thermometers will work as well.  drill the holes just a bit smaller than the tube and thermometer probe to make sure you have a tight fit.  you don't want any leaks.
the stopper will fit in the spout of the kettle a la the photo.  your tube should be out of the liquid to capture the vapors and your thermometer probe should be immersed in the water, but NOT touching the bottom or sides of the kettle.  the kettle will get hotter than the liquid and skew your results.  you only want the temperature of the liquid.
the copper tube should be long enough to connect to the condenser (attach a coupler on the end). ah, the condenser. on to thee!
32 comments
Jan 23, 2008. 8:46 AMNaTeB1 says:
Your setup up is pretty proportionate did the ice do the job for the entire run? Was there any vapor coming out? I like the thermostat addition. You cant go blind from distilling small amounts Perhaps if you drank the entire forshots of the batch you would get a intense headache. In order to reach LD from meths in distilled spirits you would have to be distilling in the hundreds of gallons.
Jan 23, 2008. 1:09 PMNaTeB1 says:
Dont know if anyone has suggested this but you could use running cold water instead of ice Just attach an inlet near the bottom and an outlet near the top. Having a constant flow of cold water circulating around the coil is incredibly effective compared to most other methods although it is very wasteful I always collect as much used water as possible for other uses
Jan 16, 2010. 7:34 AMthe rowdyboy says:
i cool my codenser with water pumped from a7 gallon bucket which sits below condenser i use a pond pump and water comes out of the bottom of condenser bucket. it works well and stays pretty cold.
May 25, 2012. 12:03 PMkretzlord says:
i know this is years old now, but you could use saltwater/ice pre-cooled in a freezer. salt water holds a lower temperature. just a thougth....
Jan 22, 2012. 4:47 PMfredricksburgthethird says:
be very careful when attempting this... i used a very similar setup except had a tea kettle with lid, and it blew its top spewing 200 degree mash all over my hand. very painful. i want to try it again but im not sure anything that i can put together will handle this much pressure.
Jul 29, 2009. 11:58 AMlakerboy11 says:
does th stove produce consistant heat? does the dubber affect th temp reading on the thermometer?
May 9, 2011. 1:34 AMwhiskymonster says:
(removed by author or community request)
May 11, 2011. 2:31 AMwhiskymonster says:
sorry dude.drunken brainfart. comment removed
Dec 6, 2011. 8:31 PMjdelahoussaye says:
hello im jamie can you by chance e-mail me the way you cook moon shine you can find my info on facebook.
Dec 9, 2011. 4:54 AMwhiskymonster says:
www.homedistiller.org/forum
check these guys, especially the safety section.
whilst this is a reasonably safe thing to do, you're still boiling something that burns as well as gas on thew stove, which is an inherently silly thing to do!
do your research, and when you think you know what you're up to, read it all agian!
then have fun!
Nov 5, 2011. 1:19 PMkchawk46 says:
what if your boiling temp goes past 174 and reaches 200 and holds there. Is something not right?
Mar 4, 2011. 5:37 PMSchpool says:
would ther be a difference in the set up when useing a tea kettle with a lid and spout vs. a tea kettle without a lid, but with a spout when boiling the wash?
Jun 27, 2009. 11:37 AMiv06 says:
i have a mini freezer that opens from the top, could i fill it with water drill holes in the sides and kind use it for the cooling device? seal up the holes so my water dont leak?
Sep 14, 2009. 5:30 PMklaad3 says:
yea that would work, i had a crappy little beer fridge. all u need is a bucket of cold water in the fridge and your copper tubeing in the bucket. dont flood the fridge it will probably make a huge mess, oh and dont forget to turn the fridge to the coldest you can get it otherwise it wont work
Sep 11, 2009. 2:15 PMmadscientist103 says:
would it be safe or even work well to make a still using a glass or pyrex container instead of a steel or copper pot?
Jun 1, 2009. 5:32 PMRadke22 says:
Could I use a cork in place of a rubber stopper? Or something else? I don't know where to get a rubber stopper that fits. Help please.
Jun 2, 2009. 11:44 AMRadke22 says:
oh ok thanks. I also have another question... Let's say (hypothetically of course) that I was going to consume the results. I have researched online this topic quite well and have read several warnings about methonal vs. ethonal alcohol and found that methonal is the stuff you don't want (blindness) so is there a way to rid the moonshine of the methonal? and how do I do that? Thanks.
May 17, 2009. 5:28 PMdschmidt1450 says:
what size of copper tubing would be best to use? what would be too small
Feb 6, 2009. 2:24 PMrebelkid7 says:
what tempurture does it have to be at to make metonal
Aug 8, 2008. 12:47 PMtbarry2112 says:
how long does this take not the making the kettle part but like the time it takes to run through the copper tubing?
Aug 12, 2008. 9:07 AMtbarry2112 says:
thank you.
Aug 4, 2008. 6:51 PMboombam says:
would aluminum piping work?
Jan 11, 2008. 7:16 AMknowonesreal says:
u tryin to go blind or poison ur self bro...........the pot HAS TO BE COPPER..!!
Jun 8, 2008. 4:07 PMKveldulf says:
Copper is beneficial in the arm, condenser, etc. but not necessary. It simply reacts with the distillate to reduce bad flavors. Making the pot out of it is largely aesthetic. (it looks nicer when you have an all copper set-up) Blindness is the result of methanol, which is concentrated in the process with or without copper. Myths about moonshine blindness come from the days when moonshine was augmented with methanol, along with paint thinner, and many other nasty things. All you have to do is toss the first 100-200ml per 20l that comes off a pot still, and you've got less methanol than most store bought products. If you get a bad hangover/headache, it's largely because of methanol. Nicely home-distilled stuff is often superior in this regard.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
79
Author:pdub77
'eclectic' is a good way to start. . . I like to build things, make things, take things apart and mod things. No matter what, though, humor is the best medicine. And I can't believe how many times I...
more »
