3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make organic planting pots using old newspapers
This is a great way of making your own organic planting pots. The final product (ie the pots) are great for your small plants, they can be put very tightly together and when the plant is ready to be put into the ground you can plant it with pot still on. The paper will gradually break down in the ground.
On the market there are a few different tools to make this pots, this is an easy way using things you probably already own.
Step 1What you need
What you need
Newspaper
Bottle
Pair of scissors
Soil
(seed)
81 comments
1-40 of 81next »
May 31, 2010. 1:23 PMchicks_with_sticks says:
I've been using a whole section of newspaper for each pot. It makes them much sturdier and holds water better, but it is still okay to plant the pot?
Apr 20, 2012. 12:04 PMMrs.V says:
It should be fine. Will take longer to decompose and make sure you put drainage holes in the bottom. Most plants, especially tender ones, don't like to get their feet too wet :)
Jan 14, 2012. 11:51 AMGregTraver says:
This is a such a great idea! I am always looking for a project that helps get the kids involved, they are already excited about starting seeds this Spring for the raised beds. I am sure they will have a great time experimenting and discovering all sorts of variables on this. Thanks
Jan 12, 2012. 9:41 AMLuffchylde says:
One thing I haven't seen mentioned is the fact that degrading newspaper attracts earthworms! Don't worry about the naysayers, some people will find something negative to say about anything. I've read articles about these, but never anything saying how to do it. Awesome and simple!
Nov 4, 2008. 7:48 PMozi says:
Don't you find that the water leeches and evaporates out of the pots quickly?
Apr 3, 2011. 1:53 PMac-dc says:
It's not much of an issue because you still have water loss through the top of the soil, an area you have to keep watering anyway because it's where the seed/root starts out. Plus, if you didn't have the water loss then the newspaper would stay very wet all the time which could lead to early rupture before you're ready to transplant.
Apr 2, 2011. 5:33 PMdmackie1 says:
About chemicals on newspapers: worth checking that the inks on the newspaper you read are fully soy based. From what I understand, the Guardian newspaper in the UK still uses mineral oils, which are quite toxic.
These are very quick to make...
Mar 28, 2011. 3:32 PMcosmov says:
this is great... i did it just to save money and now I have starts for the whole neighborhood....thanks
Aug 8, 2010. 5:11 PMWesttexian says:
wow ! Thanks for the instructions. I am always sharing cuttings with friends and I never have "extra" pots. This will sorta insure that they will survive at least until they get to their new home!
Mar 21, 2010. 4:46 PMmississippi_man says:
 Great idea,  I used a piece of PVC pipe as the mold and I used an old phone book with soy based inks for the paper.  If you tuck in paper on the bottem edge and then tamp it down from the inside it is a little sturdier.  I used a small piece of masking tape to secure the paper after I wrapped it around the pipe. I also tamped down the damp potting soil with a piece of dowel rod to compact it like a peat pellet.  When you plant the whole pot in the garden leave a little of the paper above the ground and this will help prevent cut worms from killing your plants.
Feb 15, 2010. 3:56 PMMccall101 says:
 Can you make drainage holes?
Feb 18, 2010. 6:21 PMnearyjm64 says:
The newspaper is porous, so if you over water your plant, the water will soak through the newspaper.  Just make sure you put your organic planting pots in a tray to collect any water in the event that you do accidentally over water.
Feb 11, 2010. 11:46 AMduleonar says:
Thrifty Nickel here I come!!!  :)
Aug 10, 2009. 6:11 PMfmlywomn says:
Jun 1, 2009. 12:00 AMjcdines says:
Here is one more pic. I grew all the plants from seeds... using a 200 count plug tray. BTW ... the size of the measuring cup in this picture is 4 cups.... just to give you and idea of the size of the containers I made. Hope this inspires all of you to get out there and get growing !!!
May 31, 2009. 11:53 PMjcdines says:
After your plants have out-grown their small containers you'll want to transplant them into bigger ones.... and leave then there until they get big enough to be able to survive all the critters that will want to snack on them !!! I made the bigger containers out of a 64 oz plastic container. The container happened to have an indentation on the bottom .... which allowed me to fold the newspaper into it so that it would stay in place. If the indentation had not been there I probably would have just cut out a big enough hole to accomplish more or less the same thing. Here is a picture of the bottle I used and the containers I made. As you can see, I transplanted one of the tomato plants into the larger container.
May 30, 2009. 4:47 PMmrsthursday says:
my pots have been misshapened and wobbley, your bottle guide idea is excellent.
May 12, 2009. 11:06 AMsal243 says:
You do not even need to cut the paper. Just use the whole sheet and fold in the excess at the bottom. That way there is no scraps. Also the length or height of the newspaper should depend on the plant, some require different depths.
May 6, 2009. 7:08 PMFeltprincess says:
Thanks for posting this as a first year gardener it was very helpful since it's expensive to get started. Very Awesome!!!
Apr 27, 2009. 11:36 PMRobil says:
I just made about 40 of these neat little pots in about an hour! Some helpful techniques I used are: 1) fold an inch wide flap down across the length of the paper to give your pot a crisp top edge, extra support, and a more pleasant aesthetic (it resembles the top edge of a terracotta pot). 2) use a little dab from a non-toxic glue stick (along the last edge you roll up) to keep the roll from coming undone before you fill it with soil 3) prepare all of your materials (cut and fold paper, cut strips of tape, and get a scoop of the proper size for the soil) before you start to manufacture the pots in large quantities- this improves your efficiency at least twofold!
May 6, 2009. 3:57 PMFeltprincess says:
Thank you for your added suggestions, they I didn't do the glue stick cause I cut a little bit and tucked it under the flap. But the folded edge allowed for the flap and I do prefer that look. Again thanks!
May 2, 2009. 12:37 PMchuckfortneyiii says:
This is a fantastic idea. I never thought about making biodegradable pots from newspaper. it helped me alto to start my garden this year great Instructable!
Apr 26, 2009. 12:41 PMlikesfish says:
you can get a really nice wooden kit that presses them out always meant to get one but this works just as well. my first instructable completed but will I keep the plants alive longer enough for it to matter:)
Apr 16, 2009. 5:59 AMcshore1213 says:
Can you transplant the seedling into your garden without removing the newspaper? Will it break down in the soil fast enough so as not to harm the plants??
Apr 21, 2009. 6:25 PMpatanddave says:
thank you just made 6 pots planted seeds tagged and are now sitting in my greenhouse a great money saver
Apr 21, 2009. 1:38 PMcc1016 says:
this is a money saver and it is really cool
Apr 21, 2009. 1:35 PMcc1016 says:
hey this was a great idea it was fun to do with my children
Apr 21, 2009. 10:38 AMtatihana00 says:
this was a great idea!!! i used my old phone book though, i'm not too worried about the ink and other things because all the phone book ones grow my marigolds. so it's great because i went from one marigold to now having six. thank you so much for the instructable.
Apr 14, 2009. 4:36 AMAstralQueen says:
I use biodegradable cellotape whem making these pots; they break down pretty quick so when my plants are ready to transplant all i do is tear the bottom bit of the pot open and plant the whole thing into the ground. the tapes break down into this sticky stretchy thing, it's really pretty awesome. :D I love this idea; i saw this instuctable a while back, and i have only recently created my account to comment.
Apr 5, 2009. 10:03 PMboldaslove says:
I make these too - and its so much easier with a long metal ruler. You can just place it down on the paper and rip against it...
Mar 30, 2009. 11:11 PMdusterpie says:
wouldn't there be effects from ink or chemicals on the paper? Just wondering.
Apr 4, 2009. 3:29 PMitalmrci11 says:
I'm pretty sure newspaper ink is soy based, obviously it has some dyes and chemicals but it really isn't that harmful. Also, the paper generally has a high percentage of recycled material in it, so it breaks down quickly and has less chemicals then standard printer paper.
Apr 2, 2009. 1:42 PMmaxgork131 says:
Pretty good
Mar 30, 2009. 5:59 PMp2kyrock01 says:
cool...! the paper may get wet when you water the plant. but this is great
Mar 30, 2009. 1:36 PMjustoskar1 says:
dosent paper rip wen wet ??? so no water for them
Mar 30, 2009. 12:26 PMamanda86 says:
I did this yesterday and again today. It was really easy! I love your tags too!
Mar 16, 2009. 11:16 AMgreenfarmerandprofessional says:
I have a Masters degree in Communication, and an undergraduate degree in Journalism. Soy ink has been used exclusively in newspaper, magazines, on coupons, etc. for more than 20 years. It will not poison you, your pets, the environment or anything! Enjoy reading and looking! :O)
May 6, 2008. 1:28 AMnabielmx3 says:
hate to break it to yall but using news paper with ink thats made with led and other chemicals is far from organic. drop me offff
1-40 of 81next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
92
Author:yngla
