3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make perfume
How to make perfume
Why spend a fortune on perfume or cologne when you can make your own for cheap. Brand name perfume/cologne can cost from $50-100, why spend that much when you can create your own fragrance with vodka and essential oils.
Instead of wearing a fragrance that everyone else wears you can make your own unique blend. Your own aromatic creations also makes a thoughtful gift.
Step 1What you need:
What you need:
Ingredients:
  • Vodka (the higher percentage alcohol the better) or Everclear if you can get it
  • Essential oils*, fragrance oils**, infused oils, even flavour*** extracts (make sure it's pure) such as vanilla extract
  • distilled or spring water
  • glycerine (this can be found in pharmacies)
Other stuff
  • pretty glass bottles to put the finished product in, preferably coloured glass, reuse bottles or find them at the dollar store.
  • glass jar for mixing fragrance in
  • measuring cup/spoons
  • a dropper if you have one
  • funnel
  • aluminum foil or wrapping paper if you are using clear glass bottles
  • a pencil and paper for jotting down your recipe
  • a discerning nose is helpful
*You can also make your own perfume oil Be a Romantic Scientist: Distill your own perfume oil.
**Fragrance oils are synthetic and are less expensive than essential oils.
***Quite a few perfumes use food flavours in them, so extracts are an easy way of incorporating them into your own creations.
126 comments
1-40 of 126next »
May 16, 2012. 4:49 PMmyna 07 says:
hey can i use food flavors from market as a replacement for some expensive oils???
May 22, 2012. 7:06 AMmyna 07 says:
really??? are you referring to me??? can you give me a simple recipe of a perfume??
May 6, 2012. 6:28 AMmlira1 says:
I wanted to make a really strong vanilla scent so I bought some vanilla musk oil and I added like 30 drops but it just smells a lot like alcohol still. THat's the only oil I added because I want the scent to be super soft. Any tips for fixing this problem??
May 3, 2012. 8:25 AMgrandof8 says:
Where is the best place to buy your oils? I bought some from Liberty and the shipping was almost as much as the oils.
May 4, 2012. 1:37 PMgrandof8 says:
ChrysN Can Fragnace Oils be used as well as Essential Oils? Some of the Notes in mesmerize I tried to find and no luck. Thanks
May 3, 2012. 8:20 AMgrandof8 says:
wuld you know the oils in Mesmerize?
Aug 18, 2011. 4:03 PMjoeny1980 says:
Very interesting. There is a very expensive cologne thats over $200 I'd love to try to replicate instead of buy. I found it on basenotes and can see exactly what all the notes are. Now, a cpl questions
1. you said 25 drops of oil... so is that 25 drops TOTAL of all oils used? In other words for every 1/4cup of vodka, and 2 tbsp of water and 5 drops of glycerin it should have approx 25 drops of oil in total?
2. when you're mixing the oils are you mixing them in the alcohol or
3. with regards to top/mid/base notes - does that affect the amount of oils used or is that just the classification of them. In other words, if there is a top note of melon and a mid note of chocolate, am I typically using more melon than chocolate?
4. Have you sucessfully replicated perfumes that already exist with this method by simply following basenotes.net.
May 2, 2012. 6:39 PMgrandof8 says:
Hi joeny1980.. Can you tell what you are making and the swnts you are using
Aug 21, 2011. 9:21 AMjoeny1980 says:
Yes thanks. It helps. One more question - you said when making a spray add more water... can you clarify approx how much . I dont want to over-dilute and ruin it.
Aug 22, 2011. 8:31 AMjoeny1980 says:
Great thank you for the great instructable and tips. As we speak I'm ordering all of the oils 10 in total, and IPM Isopropyl Myristate (which is an alternative to Perfumers alcohol... apparently). All else I'll need is glycerine from the drug store. I'll let you know how it turns out. The total of this order is $45 shipped (and I bought the oils in small 1oz sizes, so I could have saved money buying in bulk). And just this amount will probably make me several bottles of this cologne which retails for about $150 for 3oz
I suppose I have one more question - the product I'm trying to replicate is called a "Eau De Parfums" spray which I assume might mean a different amount of 'watering down' of it. Any additional guidance, considering that classification?
Aug 25, 2011. 6:03 PMjoeny1980 says:
Ok, so I just finished mixing and now I've stored away to age. I gotta tell you, for a first try... so far I'm pleased. I hope the scents mature as they age, the cologne I'm replicating has been described as very complex - so I wasnt sure if I'd get close - but I think I'm pretty close.
My first impressions:
I'm glad I got that IPM Isoproply myristate - it was inexpensive and completely odorless, I was concerned about off-odors of vodka.
One drop at a time is smart, I got lazy a couple times and did two and had to compensate for it.
I have a question - do you ever use anything else or anything otherwise 'odd' in your perfumes? For example - though its not listed in the basenotes, the cologne I'm trying to replicate is frequently described as salty or like sea air. I dont want to get too crazy, but my first thought is.... why not add some salt?
Second - I did a very small side batch mixing with the glycerine and water - the oil and water seperate. I suppose thats a given - but what fixes that? Obviously commercial perfumes are not seperated.
Aug 25, 2011. 8:52 PMjoeny1980 says:
One more thing ... is there anything to do to improve the projection of the perfume?
Aug 29, 2011. 1:54 PMjoeny1980 says:
Great thanks for all the feedback.
I read that there really is no way around it with the oil/water mixing - but commercial perfumers dont use oils maybe they are distilling the aromatic compounds or somehing - I dunno - anyhow, I can deal with it - just curious.
Actually after I wrote that - I looked, and go figure - they actually have a "sea salt" fragrance oil, with the scent of salt.
May 2, 2012. 5:08 AMgrandof8 says:
No I was not seeing the steps so I clicked on your message ( one Page) I was also able to get on the masculine scent page. Thanks for your help.. I have learned alot in the past days from your postings to others and to me.
May 1, 2012. 7:07 AMgrandof8 says:
Where can you get the steps mention in the posts below. and is there a list for woman and men scents. Thanks
Apr 4, 2012. 1:38 PMt800 says:
Thanks very much for the really interesting instructable!
I have a question: would you normally add more base note oil drops than middle and top to make up the 25 drops total? ...I mean would you go for, for example, 4 drops for the top note fragrance, 7 for the middle and 14 for the base if you planned to use 3 oils, or the other way round, 14 top, 7 mid and 4 base?
May 1, 2012. 5:18 AMgrandof8 says:
h much alcohol are you using for that ratio?
May 1, 2012. 6:09 AMt800 says:
I used 1/4 cup as per Instructable but I left the 2 tablespoons water out because the vodka I used is not very strong.
Apr 30, 2012. 10:27 AMgrandof8 says:
I'm just getting started and could use help. I what to make body or talcom powder and colonge for men. Right now I have Cedarwood Virginia, Pine Scotch ad Patcouli Dark. Can these be used togather or just seperate. Any ideas for other oils. Thanks
Apr 30, 2012. 1:06 PMgrandof8 says:
thank you!! what is step 4 and how many drops should i start with. Thanks
Apr 30, 2012. 4:22 PMgrandof8 says:
Thanks I will try something with this info and plan to get the three you mention. I only see step 1 above
Mar 30, 2012. 5:02 PMjaydenjayjay says:
that takes to long and than you have to bye it all
Feb 14, 2012. 12:28 PMlalala59 says:
Where could i buy the fragrance or essential oils?
Jan 26, 2012. 6:21 PMEmily800h says:
I am trying to create my own line of perfume. Here are some recipe ideas i have, will they work? *rose,lavender,amber-*peppermint,basil,cedarwood and/or sandalwood-*cherry+vanilla,grapefruit+lemon,frankincense-*orange blossoms,corianderor+/or tagete,oakmass. Do you think these are good pairs?
1-40 of 126next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
451
Author:ChrysN
I like sewing and crafts,and trying new things. I'm vegetarian and always looking for new recipes. My cat's name is Mirko and likes to be in the centre of things, so you will see him in several of m...
more »
