-Stickers, you can use about just any type of stickers, I had a lot left over.
-Box Cutter, cuts thicker portions, and cuts the air bubbles easier if needed.
-Scissors
-DVD box
-Your imagination
Remove these ads by
Signing UpStep 1The Case sides+Bottom
http://www.instructables.com/id/Reinforced-duct-tape-playing-card-case/
So this is what you do guys, as in the link above you want to cut out the size of your cards. So get a DVD case, then with the Box cutter or and thing else you can use, scratch around the card on the DVD box.
Measure the length, and the width is your choice on how big you want it, you know the wider the more cards you can hold.
Then, (I wish I took pictures of me making it) like in the link above, you want to lay our your stickers out, then lay the cut outs on the stickers, but before so, you want to lay them in the pattern to fold them in( Front, Side, Back, Side). Make sure after you fold your case, to add more stickers to hold it better. You can also layer your stickers front and inside of the case to give more reinforcement.( More reinforcement, means you have to work on the inside a little more, but the reinforcement is not needed).
Now comes the bottom, lazy man way to do it, fold up what you have, then trace around the case on the outside. Then sticker it up from the outside. Cut off the extra.
Here is a good tip to remember when you add your stickers! Make sure to cut in the corners and the side of the sticker so that it folds on the sides of the case. Also layering the stickers can help cover the case more as well as adding more strength to the hold of the case.
Add Comment
