Introduction: How to Make Real Computer Games. Fun and Only Take About an Hour
Hey this project will show you how to make games!!! real games for computers and it dosent require you to know any confusing codes. when you complete this project you will know some of the basics of game creating and you can make as many as you want.
IF YOU NEED ANY HELP WITH THIS PROGRAM LET ME KNOW I WILL BE HAPPY TO HELP.
P.S I WILL BE MAKING MORE PROJECTS ON HOW TO BUILD DIFFERENT GAMES AND ONLINE AND 3-D GAMES ALSO. PLEASE RATE THIS PLEASE RATE THIS PLEASE RATE THIS PLEASE RATE THIS ALSO IF YOU HAVE USED THIS AND WANT ME TO MAKE ANOTHER PLEASE LET ME KNOW
Step 1: This Is the Main Interface of the Game Software
OK this is only the first bit but the full project will be on a power point for you to download this week so please dont be leaving comments saying this instructable is rubbish or saying there is no information on it. it takes a few hours to make the game and even longer for me to explain it. i will try to finish it as soon as possible.
THE NEXT STEP WILL SHOW YOU HOW TO MAKE A VERY SIMPLE GAME.''
Step 2: A Very Simple Game
First we have to add sprites( these are images that will appear in the game) to add a sprite
1.right click on the sprite folder and click add.
2.a box will appear and you need to click on load.
3.chose an image for the game bored. (a gray block looks best for this game)
do the same again only instead of adding a gray block add a picture of a ball or another picture that you want. the ones you get free with game maker are best. i used a small football in one of the sprite folders.
1. right click on sprites again and click add.
2.load another image of a ball
3.now there should be 2 images in the sprites folder.
Step 3: Adding a Background
Now we are going to chose a background for our game level. this game is only going to have one level so using a simple background is best. to add a background it is the same as a sprite.
1.right click on the background folder and click add
2.load a background and press ok
Step 4: Adding an Object
Now it is the harder bit of game making..... we have to give each sprite a command to follow, only if you use game maker 6.1 you dont need to know any sort of codes. on game maker there is simple buttons that you can use instead of commands. first right click on objects and click add, then a box will appear, where it says "
when another box opens with arrows that you can click on, click on them all and put the speed to 3 and click relative at the bottom and click ok.DONT CLICK ON THE MIDDLE STOP BUTTON it should look like my image below.
Step 5: Adding the Next Object ( the Wall)
again right click on the objects and click add , this time when you are choosing a sprite choose the wall (the gray block). below where the sprite name is click on solid, so now it should be solid and visible now click ok and move onto the next step.
Step 6: Making Different Objects Interact (make the Ball Bounce Off the Wall)
now double click on the ball object to open its properties again. click add event and select "collision" and pick the wall sprite then on the side menu chose the movement again click all the arrows apart from the stop middle button, change the speed to 0 and tick the relative box then click ok
Step 7: Collision With Mouse
Now click on add event on the same object, click on mouse, a drop down menu will appear, click "left button". in the side menu click on the movement command we have been using, click all the boxes again apart from the stop button, in speen type +2 and tick the relative box and click ok, it should look like my screen shot. this means when you click on the ball it will gain more speed.
If you want to add a score board follow these instructions:
1.add a new event
2.click "other" in the event menu
3.click "game start" in the "other" event menu
4.in the tabs at the side of the object box that says move, main1 ,main2 etc.. click score
5.look at the second pictures on this instructable and find both the commands, one that is a small white box saying "slh" and drag that into the menu
6.add the first command in that tab and set the score to 0 and tick the relative box, it is a small gray box with 3 yellow circles in it.
Step 8: Score Board and Point System
now we need to command the points.
1. goto the mouse command you made earlier in the ball object(left button)
2.click on the score tab and the first command button again, it is the square with the yellow circles in it.
3. type in the box that appears +10 and then tick relative and click ok.
now when you click on the ball it will get faster and also add 10 to the score.
You may notice when you play the game that when the ball gets too fast it can some times fly out of the room. to prevent this add a new event and click "key pressed" then click on "
Step 9: ROOMS(the Level)
Ok now the very easy bit, making the level, first right click on the rooms folder, click add room, the level editing box will appear,
click the background tab
look down the screen for a box saying "foreground image"
do not change that, look below it and click and it should show your background you choose
then go back to the first tab on the rooms folder (the tab is called objects)
then select the wall, cover the whole border of the level with it like mine in the screen shot
place the ball in the middle of the map
press ok
save the file
press F5 to start the game
IF YOU HAVE ANY QUESTIONS AT ALL LEAVE ME COMMENTS OR MESSAGES,'' I WILL BE HAPPY TO HELP,
P.S SORRY IF THE GUIDE IS HARD TO UNDERSTAND BUT IT IS CONFUSING TO EXPLAIN
Step 10: APRIL FOOLS PART Contest<more Advanced> (THIS BIT IS ONLY OPTIONAL TO SCARE PEOPLE THAT ARE PLAYING THE GAME)
If you want to scare(funny more than scary) people with this game you could add in a scary voice and image to appear when the score is equal to 30 by right clicking on the ball object and adding a new event called step and in it copy what i have in my print screen.
Next get a scream sound and add it to the sounds folder and get another scary image sprite.
make a new object and chose the scary image sprite and add and event called create and in that use the "play sound" command and chose the scary sound.
RESULTS
this means when the game score is 30 a scary image will appear and scream. it is more funny than scary.
PLEASE RATE THIS
