Step 4Adding an object
iImage Information
Now it is the harder bit of game making..... we have to give each sprite a command to follow, only if you use game maker 6.1 you dont need to know any sort of codes. on game maker there is simple buttons that you can use instead of commands. first right click on objects and click add, then a box will appear, where it says "" click the tiny blue button beside it and a drop down menu will appear with all the sprites you loaded in them. chose the one that you want to be the level ball(or the object you chose instead). then click "add event" then another box with multiple options will appear. click "create" there will be a little bulb beside it. when you click this there will be other options on the right side of the objects box. look for one that is alot of red arrows pointing in different directions. it is the first button on the move tab on the right side.
when another box opens with arrows that you can click on, click on them all and put the speed to 3 and click relative at the bottom and click ok.DONT CLICK ON THE MIDDLE STOP BUTTON it should look like my image below.
