Introduction: How to Make Slotted Holes in Angle Iron
Picture of How to Make Slotted Holes in Angle Iron
There are lots of reasons why you might want to put slotted holes into a piece of metal. If something needs to slide or be adjusted, it's a great way to secure pieces together.
I made this at TechShop where I used the vertical mill to make the holes.
Step 1: What You'll Need
Picture of What You'll Need
For this Instructable, you'll need the following:
  • Parallel bars
  • An end mill
  • Coolant and cutting oil
  • Your work piece. I'm using 2" steel angle iron.
  • Sacrificial paint brush to remove metal flakes
  • Sacrificial square tubing. Since I'm using 2" angle iron, I'm using a 2" square tube
Step 2: Setting Up Your Piece & Machine
Picture of Setting Up Your Piece & Machine
Securing your work is really the trick to this entire thing. The milling is easy. I found this to be the easiest way to clamp your angle iron and get it ready for milling.
Please see my notes inside the image for details.
Put your endmill in the machine and set your speed. I'm using a 5/16" endmill, so I used the following calculation:
172 / 0.3125 = 535 RPM
Once your material is secure and the endmill is installed, you can optionally position the endmill where you need it and set your zeros.
Step 3: Mill the Hole
Picture of Mill the Hole
Now it's time to turn on the machine and start milling.
Apply some coolant or cutting oil to your material. Begin by plunging into the material. When you do this, peck at it by only going a short ways in, then backing off. For my material and endmill size (1/8" steel and 5/16" cutter), I decided to make my slot in 3 passes. So I only went 1/3rd the way through the material.
When you get to your desired depth, use the quill lock to hold it in place. Now, move your X or Y axis (depending on which way you're making your slot) very slowly. Continue to apply coolant and use your paint brush to remove chips and see what you're doing.
Repeat until you are all the way through the material.
Step 4: Done!
Picture of Done!
Repeat for as many slots as you want to make.
pfred2 (author)2014-04-22
Having that leg of the angle iron that you are milling unsupported really isn't the best setup. I'm glad that it worked for you but you should really hold pieces completely.
That formula for calculating spindle speed is wrong too. This is the real formula
(PI * DIA X RPM) / 12 = SFPM
Using your formula it says to run a 5/16 inch cutter at 550 RPM which is only 45 SFPM, less than half the speed you should run. You should mill steel at 100 SFPM or more.
I'll mock up a better setup. Ignore the burn holes in the steel. It is the first piece of scrap angle I found laying around. Anyhow, the hold down on the leg keeps it from fluttering around. Chatter is a bad thing when machining.
trev25 (author)pfred22014-04-23
Thank you for the suggestion. Are you supporting the leg of the angle iron with anything underneath? I can't quite tell from the picture.
mdhteach (author)2014-04-23
Nice... Clean and Direct... Good Instructable...
About This Instructable
6,393views
18favorites
License:
More by trev25:How to make a "walking target" for airsoft/BB guns/slingshotHow to fix a snapped tire ironHow to make a spinning target for airsoft/BB gun/slingshot
Add instructable to:
