3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make stackable Gobos
  • last photo ←
Instructable by Jim Robert ( Death By Protools )
Gobos are really useful things especially if you're working in a sub-par recording environment (ie. your living room). So what exactly is a Gobo?
Baffle - A physical object that absorbs or otherwise reduces the volume of sound which passes through it, or is reflected by it.
Gobo - see Baffle.
In other words, It absorbs or blocks sound. Those are the 2 main ways this effect can be achieved:
1. Absorbing the sound (converting it to heat via friction) - this is what foam, cloth, and other porous materials do.
2. Reflecting the sound (bouncing it back where it came from) - this is what concrete, and other non-porous materials do.
Here's a youtube video of the finished product:
Step 1Gather your materials
Recipie for 2 Gobos:
note: Each step covers what to do for one gobo. You need to do the instructions from step 3 - 12 twice to complete both gobos.
Ingredients:
  • 16 feet of 2x12 lumber
  • 12 feet of 2x4 lumber
  • 2 - 2' x 2' pieces of 1/4" plywood
  • 2 - handles (I used cabinet handles)
  • Box of 2" wood screws
  • Fiberglass insulation
  • A cover for the absorptive side of the gobo
note: I used pegboard for my absorptive side. I evens out the frequency response a bit, if you're not sure what that means, my advice is to use pegboard. If you want your gobo to absorb lots of high frequencies the you can staple canvas around the open side of the gobo instead.
13 comments
Sep 3, 2009. 5:35 AMdrugstoremarc says:
Damn it, man. Awesome idea and beautiful execution. You've done a great job helping me out with this. Thanks a lot!
Jul 1, 2008. 7:41 AMpopproject says:
excellent idea and execution. i wonder if there might be a way to make the gobo lighter using a different material instead of wood. i.e. plastic storage bucket, cardboard etc...
Jan 7, 2009. 1:47 AMalexanderm says:
You could, but keep in mind that different materials have different absorptive and reflective qualities. Some might argue that the more dense materials are preferred. Even the type of insulation used makes a pretty radical difference. Using layers of different types can assist in a more linear attenuation across the frequency spectrum. Personally, extremely dense insulation in the center, with a thin layer of lighter insulation, covered with a canvas is preferred. The 2x12 construction used in this 'ible seems a bit of overkill to me, personally... my recommendation would be 1/2" or 3/4" plywood for the top, the sides, the bottom, and the reflective side. If canvas is used with a non-rigid insulation, it may need to be braced up, to keep it from pushing out on the canvas too much. Just my 2 cents... as a professional audio engineer. ;o)
Jun 23, 2008. 9:31 PMJustinger says:
Very nice instructable. Due to the nature of the insulation, I wonder if a version that is collapsible for storage would be possible? The portability alone is great though.
Jun 30, 2008. 6:08 AMcarpespasm says:
I would imagine you could rip the 2x12 boards in half to 2x6s and then put hinges inside so you can make them flatter but larger. there might be some problem with repeated or prolonged use squashing the insulation though.
Jun 23, 2008. 11:04 PMZak says:
Justinger, I'd think a zig-zag of strips of soft fibrous material (like used for some pinboards, or maybe even acoustic ceilings) could work and could indeed fold up like a screen. By not opening the zig-zak, but leaving the angles acute, damping will be better. Not tried this though.
Jun 29, 2008. 12:55 PMcarpespasm says:
These look like they would be very useful in setting up a home/garage recording studio. I might make some of these some time in 4ft units. Do you think the batting would stand up on it's own in that legnth or would it need some pegs run through it to keep it from "slouching" in the box over time?
Jun 24, 2008. 10:34 AMfrugal says:
Aren't those 1x12, not 2x12?
Jun 24, 2008. 4:32 AMgmoon says:
Very nice, good job.
(The term Gobo is also used for light baffles. I.E., creating background patterns in photographs, "masking out" light, etc...)
Jun 23, 2008. 8:23 PMstandupclothing says:
Although I would never probably use a gobo, this instructable is very well illustrated!
Jun 23, 2008. 2:32 PMTheCheese9921 says:
Simple and effective, I like it
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:JustAboutRealJAR
