3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make sturdy umbrella stands for under $15
In this tutorial I will show you how to make sturdy umbrella stands for under $15.
We recently added a pool and deck to our home and added some tables with chairs along with umbrellas to the mix. My concern was the wind, and also what if I wanted to move an umbrella to provide a little shade when I am laying out on the day. A little shade to cover my face for instance.
So I needed something to hold the umbrella and I didn't want to spend $80 on an umbrella holder. I like to MAKE things and I wanted to see if I could get by cheaper.
What you will need.
1. A Pot ( like a flower pot) You can get these at any Lawn and Garden or hardware store, even Wal-Mart. I have seen some for as little as $5 that are plastic.
2. Some PVC pipe. I had some lying around, but you can get a 10' piece for around $4 at your local hardware store. I used 1-1/2 inch pipe
3. A bag of quickcrete. I bought an 80 pound bag that did both of my pots equally. The bag was only $5 at the local hardware store.
4. A hacksaw or other cutting device to cut the pvc pipe with
5. Wheelbarrow or something to mix the concrete in.
6. A Hoe or other garden tool to mix the concrete.
Now lets begin.
Step 1Cut your pipes
Cut your pipes
I had two pots around the house and I cleaned them out and put my pipe in the pot and marked where I wanted to cut with a marker. For me it was about an inch over the top of the pot.
I used a hacksaw, but you can use anything that will cut the PVC pipe to the length you specified for yourself.
I positioned it in the center and then used painters tape to hold it in place so that I could pour the concrete in the pot around the pipe.
10 comments
Jun 28, 2010. 9:16 AMmlcorson says:
Great idea! I do see a problem trapping water after it rains. Possible mosquito breeding issue. Maybe crowning the concrete pour over the top of the pot to keep the water from accumulating within the top space?
Jun 28, 2010. 9:59 AMjhines0042 says:
I wonder if you were to get a "pot with a hole in the bottom" variety and fill the concrete to the level of the pvc pipe (which would be lower than the top of the pot) if you couldn't avoid the water issue when the umbrella is down. Of course you've have to be careful to not have the concrete ooze out the hole... maybe glue the pvc to the bottom first? Great idea, BTW!
Jun 28, 2010. 12:33 PMjhines0042 says:
Just one more thought (cause I'd hate for you to ruin your awesome existing marbles)... drill a couple of small holes in the pvc right where it meets the concrete. Water will drain in the side of the PVC and out the bottom. Again, nice work!
Jun 28, 2010. 2:14 PMmlcorson says:
Not so fast pilgrim...that will only work if you shaped the concrete to slope toward the center. A great idea if you do that in the first place.
Jun 28, 2010. 9:12 AMj0shu4 says:
The glass stones are a nice touch man. All in all a neat idea. Looks like the pot was just small enough to fit between the legs of your tables. Good thinking!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:digeratimvp(seizethepage)
