Introduction: How to Make the BEST Command Prompt (cmd)
Hello, everyone!
Today I will show you how to make one of the BEST CMDs ever.
Please rate this Instructable, by the way!
Step 1: Materials
Here's what you need:
• Computer
• Text editor (Can be simple, I'm using Notepad for Windows)
• You
• Keyboard (Optional, see step 2)
• Mouse (Optional, see step 2)
• Hand(s)
If you have most of the above, (must include computer, keyboard/mouse and hand[s]) then you can click Next Step
Step 2: The Code
Ok. Here's the code (copy between the stars) then I will explain:
@echo off
cls
title Command Prompt - by account3r2
ver
echo (C) Copyright Microsoft Corp.
echo.
:cmd
set /p "cmd=%cd%>"
%cmd%
echo.
goto cmd
Yes, about step 1... You can use the mouse to copy, paste and save the file. Or you can just use the keyboard, using MouseKeys or shift-select then CTRL-C and CTRL-V.
Step 3: The Explanation
@echo off ----- This tells the computer not to display commands unless it is told to do so.
cls ----- This clears any text on the screen.
title Command Prompt - by account3r2 ----- Displays the text after "title" on the title bar.
ver ----- Displays the version of Windows you are running.
echo (C) Copyright Microsoft Corp. ----- Echo displays text, The rest just says the Microsoft has copyright.
echo. ----- Echo with a period after it skips a line, like pressing enter twice does.
:cmd ----- Sets a point to access called "cmd".
set /p "cmd=%cd%>" ----- Makes a line you can type on, then saves what you typed tempararily into "cmd".
%cmd% ----- Does the command you typed.
echo. ----- Still skips a line.
goto cmd ----- Goes to the access point set called "cmd"
Step 4: Saving the File
Now we will save the file.
First, press file. (OR Alt+F)
Next, press Save or Save As... (OR S) (OR Just Press CTRL+S at #1)
Then, Type a name like "whatever.bat" or "CMDPRMPT.bat" but whatever it is put .bat at the end (you can use on screen keyboard for this)
After that, press save.
Step 5: Running the Program
Next you run the program by double clicking it or by selecting it and pressing enter.
It should look like the picture below.
Step 6: Suggestions? Updates?
If anyone has any suggestions or updates for this program, please leave a comment below. Feel free to leave any comments for anything else, and again, please rate this! Thanks!
