How to Make the Fishtail Braclet With a Loom
1,875
Posted in CraftJewelry
Introduction: How to Make the Fishtail Braclet With a Loom
grab your materials, you will need......
Step 1: You Will Need a Loom
you will need the staggered configuration if your using the official rainbow loom.
Step 2: You Will Also Need a Hook
a hook.
Step 3: You Will Also Need Bands
chose your colors, its helpful to have them ready befor you start.
Step 4: Twist....
twist your band on your fingers into a figure eight, then place it on 2 pegs on your loom, go to the next picture to see how it should look
Step 5: It Should Look Like This
Step 6: Now Place,
now place, two regular band on your loom no twisting. just put it regularly on your loom. like that below (or above)
Step 7: Now Grab Your Hook
now grab your hook and go to the figure 8 rubber band take on side and pull it over onto the top of the rubber bands. go to the next picture to see how it should look.
Step 8: It Should Look Like This But You Have to Do Both Sides.
as you can see im takeing the bottom band and placing it over to the top bands, do it to both sides.
Step 9: Now It Should Look Like This
now it should look like this.
Step 10: Now Do It Untill Its Long Enough
now you repeat the steps untill the end, so he is the second loop, now just keep doing it till its long enough to fit your rist.
Step 11: Now That It Geting Long Enough
it should start to get long like this if not you did somthing wrong, go back and repet the steps.
Step 12: Heres How You Take It Off
now go under and grab the bottom band and pull it to the top like the first few steps.
Step 13: At the End
it should look like this, attach you c clip or s clip to finish your braclet
Step 14: ENJOY
ENJOY
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
