How to Make the Letters F and the Letter X Out of PVC Pipe
Published
Introduction: How to Make the Letters F and the Letter X Out of PVC Pipe
Materials :
- PVC Pipe
-90 degree elbow connectors
-T- connectors
-45 degree elbow connectors
- 4 pieces of 1/2 pvc pipe
Step 1: The Letter F
-gather a 90 degree elbow, a t-connector, a 8 inch pipe, two 4 inch pipes and one 2 inch pipe
-insert the 2 inch pipe into the 90 degree elbow.
-add the t-connector to the other end of the two inch pipe.
-insert the 8 inch pipe into the end of the t-connector
-now insert the 2 inch pipes into the 90 degree elbow and the side outlet of the t-connector
*all pipe should be 1/2 inch*
Step 2: Letter X Intro
Materials :
-four 45 degree elbows
-2 t-connectors
-5 3/4 inch
Step 3: The Letter X
-take one of your 45 degree elbows and insert one of the 3/4 inch pieces into the end --  make sure you hold the 45 so it makes a backwards C shape
-insert a t connector with the side outlet pointing to the right
-insert a 3/4 inch piece into the side outlet on the t
-add a 45 degree elbow to the piece
-insert another 3/4 inch piece into the third side of the t connector
-connect another t  *with the side outlet facing the left*  to the bottom of the first t connector
-add a 3/4 piece to both remaining sides of the t connector
-add a 45 degree elbow to the bottom of the t  * make sure the 45 makes a regular  C shape *
-add your last 45 degree elbow to the side outlet of the t connector  * make sure it points upwards *
Step 4: You Can Now Make the Letters F and X With PVC Pipe !
    • Backpack Challenge
      Backpack Challenge
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    This isn't lego. Why is it in the lego category?
