Introduction: How to Make the Letters J and O With 1/2in PVC
Picture of How to Make the Letters J and O With 1/2in PVC
In this instructable, you will learn how to make the letters J and O using 1/2in diameter PVC.
Step 1: Materials for J and O
Picture of Materials for J and O
In order to make the Capital letter J, you need the following materials: (all joints and PVC is 1/2 in)
1 T-joint
2 90-degree elbows
2 2in PVC
1 1in PVC
1 4in PVC
Materials for capital O:
4 90-degree elbows
2 4in PVC
2 8in PVC
Step 2: How to Build the J
Picture of How to Build the J
Take the T-joint and on each side insert the 2in PVC
From the bottom outlet of the T-joint, insert the 4in PVC
On the end of that connect a 90-degree elbow
On the end of that, insert the 1in PVC
On the end of that connect the 90-degree elbow( the two elbows should be flush against each other)
Now the J is complete.
Step 3: How to Build the O
Picture of How to Build the O
Lay out the 4 90-degree elbows in a square
In between the top two and bottom two, insert the 4in PVC
In between the side two, insert the 8in PVC
Now the O should be complete.
About This Instructable
558views
1favorite
License:
More by cpowell2014:Cómo hacer un organizador de armario hecho de PVCHow to Make a Closet Organizer Out of PVCHow to make the letters J and O with 1/2in PVC
Add instructable to:
