Introduction: How to Make the Simplest Compression Fitting for a Silent Air Compressor / Vacuum Pump
A simple compression fitting that you can build yourself for a silent air compressor or a vacuum pump.
It basically consists of two fittings that have flat faces (surfaces) that are brought closer when one is screwed into the other. Between the two you put one or more rubber washers. You put the fitting over the tube and ss you tighten the fittings together they squeeze the washer/s and the whole inside them contracts forming a tight seal. Make sure you tighten it well. If done correctly there are no leaks whatsoever even at 50 bar.
elkaddalek (author)2017-01-23
What are the fittings called. I'm having trouble finding them.
Я ? Россия (author)2015-06-07
This will blow out.
About This Instructable
6,436views
41favorites
More by kerimil:Simplest and cheapest adjustable power supplyHow to make the simplest compression fitting for a silent air compressor / vacuum pumpHow to log data from the arduino board
Add instructable to:
