This instructable has been removed by the author.
20
comments
Add Comment
This video looks awesome but you don't have enough instruction besides your video in order for it to be a full Instructable. There are two things which you could do. 1) If you can get some screen captures from your video then you can actually create a full Instructable right from the footage that you already have. First you can create some more steps in your Instructable to explain your project. Then, you can add those step by step screen captures into your Instructable to explain the additional instructions. Once you've done that, you should be good to go, so at that point simply republish your project. 2) If you don't want to turn your video into a full Instructable, that's ok too. That just means that your project should be submitted as a video and kept in our videos section. You can use the same text and embed code that you already have in this Instructable to create a new video in our video section, so it should only take you a few minutes to republish your project. Thanks for your submission and let me know if you have any questions along the way.
Feb 8, 2010. 3:40 PMarmyofpyros
says:
Just like thermite, but with titanium. If titanium melts at a higher temperature than iron why don't they use this stuff in incendiary grenades?
Dec 6, 2009. 6:42 AMtemp
says:
I'm guessing because titanium is more expensive and generally harder to work with. And iron oxide seems to do a good enough job. =)
Aug 10, 2009. 3:44 PMEvilblaze (author)
says:
No. In plastic explosives they use usually PETN or RDX. Sometimes they put nitrate esters in plastic, because it can be detected if there are nitrate esters in it. The common used esters are EGDN, NG. But there are no potassium chlorate in it.
Sep 5, 2009. 12:21 PMFunkNattidelic
says:
I read somewhere that you can make something similar to a plastic explosive my kneading KCLO3 into Petroleum jelly, 9:1 ratio respectively
Dec 14, 2009. 4:03 PMFunkNattidelic
says:
numerous places, anarchists cookbook being one i do believe =P. id love to know if it works, id try but i dont have KClO3 and i dont know if my idea for a blasting cap would work.
Dec 15, 2009. 4:32 AMEvilblaze (author)
says:
Potassium chlorate and gasoline has 6000-7000 m/s detonation velocity. It is a really strong explosive as you can see.
But this instructable is not about explosives.....
Dec 15, 2009. 3:17 PMFunkNattidelic
says:
So potassium chlorate and gasoline is a high explosive? Is it like a gel or a goop or what?
Dec 16, 2009. 12:56 PMEvilblaze (author)
says:
It's like wet sand. You don't need so much gasoline in it.
If you are interested in explosives, than write a pm or a mail.
Aug 6, 2009. 11:28 AMEvilblaze (author)
says:
Prült? Merthogy?:-D Amúgy te ki vagy? Kevés ezen a honlapon a magyar emberke....
Aug 6, 2009. 1:42 PMCoolKoon
says:
Már eleve az a tény, hogy ilyen kísérletet a jelek szerint bent csináltál....de jó, gondolom, gondosan eltávolítottál a közelébQl minden gyúlékony anyagot. Maradjunk annyiban, hogy én ilyet csak kint, pl. az erkélyen csinálnék :) Amúgy én egy, a "csináld magad"-mozgatom lelkes híve vagyok. Már elég régóta járok ide körülnézni, mert az itteni dolgok még ötletnek, meg inspirációnak is néha zseniálisak. Egyébként ami azt illeti, rendkívül szívesen csinálnék ilyen kísérleteket, de per pillanat még NYÁK-gyártást se igazán tqrnek meg, ilyenek után meg még a szqrömeg is kitennék...... Amúgy hol lehet ilyen anyagokat beszerezni? :)
Aug 6, 2009. 2:19 PMEvilblaze (author)
says:
Mindent be lehet szerezni, de a többit MSN-en vagy mailben. Küldd el az MSN címed PM-ben vagy küldj egy mailt. Üdv.
