3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make wine
How to make wine
In this instructable, I will demonstrate the process of making a medium-quality apple wine.
Step 1Materials
Materials
You will need the following as base materials for this project. There are cheaper ways to do this, but the resulting wine will have a different taste and texture. These materials will produce a medium-grade wine, somewhere between hobo wine and connoisseur wine. Check out the Alternatives step for other options.
Sterilization:
1 - bottle of the cheapest vodka you can find (isopropyl alcohol also works for this, but requires a bit more rinsing)
1 - gallon size sauce pan (or whatever large size you might have)
1 - pair of tongs
Bottle and Bottling:
1 - 5 gallon water-cooler jug (or a 5 gallon carboy)
1 - large funnel
1 - pack of coffee filters
Air Lock:
1 - 6" section of 1/4" inner diameter PVC pipe
1 - 4' long 3/8" inner diameter, food rated vinyl tubing (The "food rated" quality is important for safety.)
1 - rubber stopper, 1-3/16" x 1-1/2" x 1" to go on the jug
1 - empty 20 oz bottle
1 - drill with 3/8" bit
Wine Contents:
2 - 1 gallon jug of apple cider, preferably unpasteurized. NO preservatives.
1 - 5 lb bag of granulated white sugar
1 - WLP775- English Cider Yeast
Cost:
I don't have receipts for any of this, but here are my best estimates, and estimating high for worst case. (Also, rounding up to nearest 5 increment, for those checking my math.)
Vladimir vodka: $15 (only maybe 1/3 of it was actually used in this project though)
Bottle and bottling: $40. (We had to buy a full 5-gallon water jug, which drove the price up. Empty jugs would lower the cost down to around $25. Check Craigslist for empty jugs.)
-Jug: $35ish
-Funnel: $1
-Coffee Filters: $1 (only like 1/10 of these were used though)
Air Lock: $15. (All parts can be picked up at your local Lowes or Home Depot. Also, this cost is assuming you already have the drill and bit.)
-Stopper: $5 (came in a larger pack)
-PVC pipe: $3
-Vinyl tubing: $5
-20 oz bottle: $1
Wine Contents: $30 (Shipping for the yeast hits this number pretty hard. It was almost as much to ship the yeast as it was to buy it.)
-Cider was about $4 each with tax
-Yeast was about $14 with shipping
-Sugar was about $7 with tax
Totals:
One time (Start-up) cost: $50 (bottle, air lock, and funnel)
Content cost: approximately $9.50 per gallon for 4 gallons, or $11 per gallon for 2 gallons
22 comments
Jun 3, 2010. 4:34 AMakinich says:
hey nice ible
ok i have a question
i used fresh fruit and first what i did was boiled the water and got it to room temperature then i added the sugar afterthat did i put the fruit pulp
then i added the yeast
it does not bubble at all
what should i doo?
Jun 3, 2010. 4:38 AMakinich says:
oh yeah 1 more thing
after a while the fruit floats to the top and the liquid is in the bottom
please reply fast
Mar 18, 2010. 8:42 AMchakra says:
of all instructables, yours make a lot of sense to a simpleton like me!! straight and easy way of tellin...
  i'll be tryin with grape juice i made on my own from fresh grapes!!
thanks a lot!!
Sep 24, 2009. 8:42 PMArx says:
That's not an air-lock. It'll certainly reduce the amount of air that gets in, but a proper air-lock that you can fill with water or alcohol costs about $3 If you want to keep it as cheap as possible, a balloon with some pin-holes in it is the traditional ghetto method. It'll be cheaper than your rubber bung and pipe, it'll work better, and it'll also allow you to see if it's fermenting (the balloon will stand up)
Sep 24, 2009. 8:37 PMArx says:
You're not properly sanitizing that bottle at all. it might work if you poured a lot of vodka in straight and swished it around without adding water, but it's way too expensive to use that way. You can get a 1/2 lb package of Potassium metabisulphate for a few bucks. It can be used to sanitize your bottles/equipment, and is also the same chemical used to prevent competition to your yeast during fermenting, and as an antioxidant to allow the wine to age better after you bottle it. The couple shots of vodka in 1/3 bottle of water works out to about 0.5%ABV. That's insignificant. You could just drink the shots instead, and your odds of spoilage won't get any worse.
Sep 9, 2009. 12:26 PMGrady says:
I made wine out of a bunch of peaches, regular fleischmann's yeast, sugar, water in a 5-gallon pail. It turned out o.k., but the flavor sure could've been improved. LOL
Apr 1, 2008. 8:48 AMBabyshoes says:
Looks good! A friend of mine tried making wine with grapes, and it was horrible, so if yours tastes ok, then well done! Here in the UK, of course, cider is already alcoholic. I assume ordinary apple juice would do the same job? (Assuming it is pure with no additives...) How is this wine different from English cider? I assume it must be, but I am not sure how, since you use 'cider yeast'... Does it taste like normal wine, or is it still apple-y? Also, in the US, what is the difference between cider and apple juice? Is there a difference? (Just curious!)
Sep 9, 2009. 12:23 PMGrady says:
juice is juice. Fermenting 1 time produces the booze; Ferment it again, & you have Vinegar. So, apple cider vinegar is apples that has been fermented twice. This is what I read in a book;.
Sep 30, 2008. 9:55 PMtellumo says:
Just writing separately with a little more on the difference between UK and US cider, and US apple cider and apple juice. BrainiacVince was quite correct: there's no legal difference between "apple cider" and "apple juice" in the US. "Apple cider" tends to be less sweet and less finely filtered, whereas "apple juice" is very sweet and clear, but these distinctions aren't defined or enforced by law. "Hard cider" is also available, which is roughly equivalent to English cider, although markedly weaker--4-5% alcohol by volume is typical, whereas I understand the English product can range up to 8.5% (a very stiff tipple by the standards of many Americans, but I wouldn't mind trying a bottle). There's also "applejack," a freeze-distilled hard cider that can contain as much as 30-40% abv and, as I understand, have effects similar to those I've heard are experienced by consumers of rough scrumpy (viz. waking up dressed as a schoolgirl in a ditch three towns away from where you started drinking).
In any event, "cider" or "apple cider" without further qualification will always refer to the non-alcoholic product around here unless the context makes it very clear that the drink is alcoholic. "Hard cider" is the term to use otherwise. As for brands, Wyder's is widely available, but I like Woodchuck better, and it's not much harder to find. Naturally, if there's a local brand, I'd advise going for that--that's the way to go for getting good beer here in the States as well.
Apr 20, 2008. 1:04 PMjoeny1980 says:
Great instructable! Thanks for taking the time. I've read instructions on making wine before and have always been hesitant of how much work it seemed - but your instructions make it pretty straight forward. To filter, I assume you are using paper coffee filters? Is there a reason you arent just including that as a firm step rather than just a recommendation - it sounds like the most sensible way to avoid dead yeast in your product. Does it lose anything else by straining? Do you know/think commercial wineries strain their product? Also, as an alternative to pouring/straining and dealing with foam and dead yeast - what do you think of this idea: using a hand pump syphon (probably could get one at the dollar store or an automotive parts stores). Suspending it halfway down the bottle will avoid both the foam and the yeast sediment at the bottom. Just a thought What types of wine have you tried making - and what has yielded the best results?
Apr 20, 2008. 4:01 PMjoeny1980 says:
Thanks for replying. I read a few more instrucatables on the topic and others have said you need three other chemicals to make this. Any idea on what the difference is with or without these?
Aug 9, 2009. 12:58 PMTrevorD91 says:
could you use Fruit punch or something instead of grape juice or apple juice?
Sep 19, 2008. 5:59 AMFireBAT says:
To clarify the definitions- if the drink is labeled "juice" it must be 100% juice, fresh or made from concentrate. It can not have any added water or sugar. If it is made with juice but has other things added, it is a "juice drink". The American version of cider is apple juice that is not processed- no filtration (except maybe straining out the chunks and grit). Commercial cider must, by law, be pasteurized, which kills bacteria, and, probably, the yeast that causes fermentation. Fresh, unpasteurized cider may be sold by orchards, but it must have a warning saying it is not pasteurized. Apple juice is cider that has been extensively filtered and clarified to remove the suspended solids that give the cider its cloudy colour and sharp flavour. It is still 100% apple juice. Hope that helps. I'm currently processing about 500 pounds of apples using a 150-year-old hand-cranked cider mill.
Jul 17, 2008. 7:15 AMMatt D655 says:
yo braniacvince- my dad told me if u leave a gallon of apple cyder in the basement fir a long time it will ferment,is that true?
Apr 2, 2008. 6:08 PMPATSY001 says:
I homebrew my own beer (very similar to brewing wine), and sanitation (sterilization) is the most important part, you don't want to skimp on this part. Take your time and do it thoroughly or you may end up with "off tastes" or even worse you could end up with a batch full of mold. make sure to sanitize EVERYTHING that will come into contact with your wine-making (spoons, pots, pans, hoses, carboy, bottles, hands, etc.) A good place to find economical, easy to use sanitizer (as well as almost everything else you could ever need for brewing beer/wine) is:
http://www.northernbrewer.com/sanitizers.html
I prefer the "One Step"
Apr 1, 2008. 4:37 AMgmjhowe says:
Very nice, written up very well. and i love the stuff u used, most of it easy to get hold off. You should start selling it now!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:BrainiacVince
I am currently working as a programmer. I hold a Bachelor of Science in Computer Engineering and an Associate of Science in Computer Science. I have a strong background in physics, electricity, and ...
more »
