How to Make Your Clip Tek Gun Aim Better
Published
Introduction: How to Make Your Clip Tek Gun Aim Better
About: I'm Cool!!!!!!!!111
So you want to make your Clip Tek gun have a better aim? i will tell you how to do it. the best way to improve your aim is to use a laser aimer. it will cost you less than $10.
Step 1: You Will Need...
1) a 650nm 5mw 12X30mm brass case $4.50 from AixiZ ( laser pens won't work!!)
2) a on/off switch from Radio Shack---$1.99
3) a 9-volt clip from Radio Shack---5 for $2.99
4) a 9-volt battery
5) a clip tek gun
Step 2: The Wires...
connect the red or black wire to the red or black wire of the clip ( one wire only!!). connect the other wire to the switch and the other wire of the clip to the switch. ( for example, i connect the red wire of the laser to the red wire of the clip and the black wire of the laser to one side of the switch and the black wire of the clip to the other side of the switch.
Step 3: Tapeing...
tape or glue the laser on top of gun (or on top of the mouth of the gun) and glue the switch to the side with hot glue and put the battery on to the clip. tape the battery to the side of the gun and you're almost done.
Step 4: Test It Out!
test it out!
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    3 Discussions
