loading
Step 41: Mount the board, and hook up the motors
With some (more) foamy tape, stick on the board to the rest of the robot.
Make sure the mini-jack (the metal ring in one end of the board) is placed so it is easy to plug in a cable, because you will be doing that many times! And be careful to make sure that the bottom of the board does not touch any metal ;)
Hook up the motors wires, into the A&B-pins that you soldered on earlier:
One motor's 2 wires goes to A on the board, the other to B. It does not matter which goes to which, we will manage the rest in the programming.
Oops, one of my motors wires was too short, so I added little blue extensions from a scrap piece of wire that I found.
Where do you get all of the things from like literally that's why I don't know
<p>where could i buy the shorting blocks to ship to finland, there is a website called pololu which is the only one i could find which ships internationally but i dont trust it so please help me!</p>
<p>go to usa</p>
<p>Pololu is a great site for robot components and other electronic components. I've used them many times for a different projects and I've always been satisfied with the quality of their parts and the depth of their documentation.</p>
<p>wow it is so easy they told you the wrong thing dudes</p>
<p>how do u code it. like when u conect it to your computer how does it work</p>
<p>can i use a ping insted of a sharp</p>
<p>I bought your project and i want to go a step forward, instead of using the board for sensor robot i want to make a remote control walking robot. I need your help!! How could i contact u privately. thank you :3 Chaknithg@gmail.com Facebook:Chak Nith</p>
<p>sorry i didnt made it yet</p>
I love ur project and o want to make it,please please tell me the price of this project<br>
<p>its about 300 euros if you do not live in USA</p>
<p>Niiiiicccccceeee! You're great! Thanks for this ible:)!</p>
<p>how</p>
<p>Cool dude!</p>
<p>Hello fritsl what kind of solder do you need does it matter because ive never really heard of a solder and imgonna buy one and I wondered if there is a certain type of solder or solder iron</p>
<p>Thank you so much for the instructable, I just finished it!</p><p>The only issue I had was in the programming, where in the sample program you used &quot;readadc1&quot;, unlike the &quot;readadc0&quot; used when introducing the range of values from Sharp. So &quot;readadc1, b1&quot; caused b1 to always be 255, b/c the analog pin 1 was connected to V by the shorting block. Seems simple now, but took me ages to pinpoint this as the problem! I hope this can help someone else! :)</p>
hi! where can i buy the materials?? does it have online selling? <br>and how much will it cost?
HOW MUCH WILL BE COST TO MAKE THIS ROBOT.
This is really cool. Thank you for adding this. Will the store(solarbotics) be getting your kit in stock any time soon? I was also wondering if this kit is RoHS compliant? Thanks.
where do i find these?
I&nbsp;have wanted to build a robot like this for a long time, but I have been putting it off because of all the support behind Arduino. Would it be possible to get advice on how to build this same robot, but with an Arduino. It seems like I&nbsp;am going to invest in a microcontroller, I&nbsp;should do so with something that I&nbsp;am more likey going to do more with besides the bot... any suggestions? I&nbsp;am not dissing Pic, just so much maker momentum seems to be with Arduino...<br />
Check out Scratch for Arduino!
I always wanted to do this walkthrough with an Arduino based setup, as a parallel, so people could chose.<br /> <br /> However, things are just that more &quot;complex&quot; with Arduino. One line of code makes a servo go to a direction with Picaxe. And that is even one simple and logic line of code, that your dog can understand:<br /> <br /> servo 1, 150<br /> <br /> With Arduino, you'd have to upload a library first, and then deal with many lines of hard-to explain-for-the-novice-code and syntax.<br /> <br /> - For doing the excact same thing. And that's just the servo, things just get so much hairier. I want people to get a good start, not to meet a wall.<br /> <br /> But I like Arduino, and every now and then I think about how to present it as &quot;your first project&quot;, in the spirit of the walkthrough above. I Just have not found a way yet :)<br /> <br /> There are, however, tons of walkthroughs on how to get started with Arduino. I am just focusing on how to get started building robots here. And for that purpose, I have chosen the components listed, because I believe they are the best mix for a starter who wants to dive in to fun-zone right away :)<br />
I have had experience with Parallax's Basic Stamp board. As you said with Pic, it takes only a line of code for a servo to go in a direction. Same with Basic Stamp, it doesn't require much more then pic, PULSIN 1, 150. I believe that is the right way to write it. I haven't used it in awhile. But Basic Stamp can be very easy. <br> <br>http://www.parallax.com/ <br> <br>You can go here to find more about it. <br> <br>I never have used Picaxe or Arduino before. I hope to use both. <br> <br>This is still very good.
Thanks, that makes a lot of sense. Do you think Picaxe is the way to get started with Microcontrollers in general?<br />
You could also put a 5v voltage regulator on it and use 6 rechargeable batteries, you would get 5v and for a longer time because you could use more batteries.
you are a genius. you make robotics easy to understand. thank you<br>
Not that your robots not good (i actually luv it) but i think i can make an easier and cooler one. 1 rc car and 1 picaxe 08 motor controller board. Thats Practicelly all it takes. And sensors for a good and cool robot. Nice job though.
could you give me the artist's name who sings the song in part 1 of your instructional video?<br><br>I tried looking it up on Google and there are people in forums wondering the same thing (they heard it on a you tube video) but no answers so far.<br><br>Great song and great video
can i use an ultrasonic range finder instead of the sharp, without having to change the program?
wow,its ousom,great
how to do that?????
Yeah! Mario Bros!<br> <br>
fritsl, i need help, im 12 years old and very smart, i bought the robot and put it together but im having trouble programming it, sometimes when i type in engine codes like: high 4 low 5 high 6 low 7 i hear the engines moving but the wheels arent, the wheels arent touching anything either. ill try recharging the batteries but dont think thats it. Plz respond, i need help and this was a pretty decent investment for me. all i have left to do is figure out the right engine codes and ill be done completely, unless the wheels wont turn like now. THANKS!! and to all who are wondering if they should uy this I RECCOMEND IT!!! =]
Great job, with one caviat though.&nbsp; If you use a lighter to activate heat shrink tubing, you need to keep the flame from having too much direct contact with the tubing.&nbsp; A heat gun, or a hair dryer,&nbsp;works better and is more appropriate anyway.&nbsp; I've caught heat shrink on fire before by using a lighter.&nbsp;
I do not agree with you, but thanks for the points, now people can try both ways :)<br />
I'm sorry you don't agree, but you admitted yourself, that you burnt the wires.&nbsp; You can deny reality all you want but eventually it bites you in the butt.&nbsp;&nbsp; Good luck.<br />
Pkranger88, Your opinion may be based on the type of heat shrink tubing you are using.&nbsp; There are several types of heat shrink tubing available, and they are not all created equally.&nbsp; One of my favorites is polyolefin.&nbsp; I&nbsp;personally use heat shrink tubing almost every day of my life, and have done so since the early 80's.&nbsp; I carry a Bic lighter for that explicit purpose.&nbsp; While in some cases a heat gun is more appropriate, in many cases it is not.&nbsp; Your version of &quot;reality&quot; does not necessarily coincide with someone else's.&nbsp; In my experience and my &quot;reality&quot; you'd have to be a real dunce to catch good quality shrink tubing on fire!&nbsp; The fact that the author disagrees with you doesn't indicate a denial of reality.&nbsp; It may simply indicate a difference in experience and or skill level.&nbsp; Good luck to you as well.
Most heat shrink tubes are flame retardant anyway, I usually use my soldering iron to shrink them.
Once you get the hang of it it's not too hard, as you probably know.<br />
Did you think about putting the &quot;head&quot; on the back of the robot facing forward? That should give you enough space so that it won't freak out when something's close, shouldn't it?
If you are thinking about the &quot;dead zone&quot; within 10 CM's in front of the Sharp, you are absolutely right!
Cool, it's not very often that that happens. ;)
Very well presented and detailed instructable, can't wait for payday to make this badboy<br /> <br /> 5*'s<br />
Yay! The kit's on sale!<br /> <br /> ...damn.... bit expensive. Looks like I'll have to save up!<br />
&nbsp;good job.
<big>Hey, you should sell kits here on Instructables:</big><br /> <tt><br /> https://www.instructables.com/community?categoryGroup=marketplace&amp;category=kits</tt><br />
Agreed!<br />
I think &quot;Wholes&quot; is&nbsp;should to be &quot;Holes&quot;
About This Instructable
249,175views
449favorites
More by fritsl:Your first real robot the easy way, learn all the basics while at it :) How to build your first Robot ($ 85)
Add instructable to:
