Step 5Making the Gun Barrels
iImage Information
Again, I found a scrap piece of PVC water piping small enough to use as barrels on the side ports. I cut them to desired length. Then, cut smaller pieces for the 3-D effect of the barrels. Using the heat gun and needle nose plairs to strech the small PVC pipes to slip over the barrels. Another way to do it is cut the smaller PVC pipe vertical, slip it on the barrel and heat it up with the heat gun. After it cools, use a drop of glue on the pipe ring so it won't fall off. Finally, I used large picture hanger from Ace Hardware on the inside of the knee armor to connect the strap that will go behind my knee to hold the armor in place.
