How to Make Your Own DIY Leather Bicycle Grips (with Waste Materials)
60,528
256
28
Published
Introduction: How to Make Your Own DIY Leather Bicycle Grips (with Waste Materials)
About: Crazy about bicycles, outdoors and diy projects
I have been using these leather grips for a week now and I can honestly say that they are amazing. And they look awesome as well. It's weird having strangers tell you that I shouldn't invest on my beat up bicycle, by buying expensive parts! They wouldn't believe that these grips are homemade with straight out of the bin materials! I ‘ve never had proper bicycle grips in my life. All I had was worn out bicycle grips or new very cheap ones. My DIY leather grips are my first proper very expensive looking grips. And I got them for free. Check bellow how I did it.
I've only used:
- A pair of worn out lock-on grips (if you don't have, or you can't find in your friends' garage, you can buy them off ebay for around 3$)
- an (unusable) leather belt that you don't want/like (non-slip, tough, amazing feel, beautiful looks, your hands doesn't smell rubber after the ride, doesn't leave black spots on your hands.)
- razor / knife
- A good pair of scissors
- a piece of thick fish line (incredibly resilient to the elements, most of the times you can find it for free, looks great, amazingly strong). I found mine tangled around a stick in my city's port. I guess the stray animals will thank me!
- A Dremel
- Needle-nose pliers
Step 1: Strip Off the Worn Out Rubber
Firstly, strip off the worn out rubber using the razor. Remove most of the rubber without worrying too much about it. We need some leftovers so the leather parts don’t slide around.
Step 2: Cut the Belt
Then, find out how many pieces of leather fit in your grip. If they can't fit perfectly, make a thinner strip for each grip so they can cover the whole length. By wrapping the belt around the grip you can see where to cut it and then with your scissors trim it enough so the two ends almost touch each other (there should be a gap). When you have them ready, open some holes with the Dremel. Try to make the holes on each end of the leather strip isometric. The holes must be as tight as possible (maybe as small as the fishing line).
Step 3: Thread It
Now, cut diagonally the end of the fishing line so it goes through the holes more easily. Using the needle nose pliers grab the end and make it go through the top hole and then the hole bellow (from the other side). Now, make it go through the same holes again but this time take the end and make it go through the next top hole. Don't make it tight yet.
Step 4: Squeeze the Leather and Tight the Line
Using your pliers squeeze the space between the threading so the two ends snug to each other perfectly.
When you finish the first piece of leather, make all the threading tight (a used a fork). For the next strip make the line go through the next hole and keep doing what you did with the first.
Step 5: Melt the Knots
When you finish the threading, make it tight enough and then make two knots on each end. Hold the knot down as you pull the fishing line so it stays as close to the hole as possible. Using a lighter, make the end of the pliers very hot so you can melt and flatten the knot to prevent it from unbinding.
Step 6: They Look Nice, Don't They?
You can visit bicycleobsession.wordpress.com for more bike obsession or like bicyclosis on facebook!
    • Stick It! Contest
      Stick It! Contest
    • Backpack Challenge
      Backpack Challenge
    • BBQ Showdown Challenge
    28 Discussions
    Nice idea. Taking it further...If someone doesn't have an old belt: thrift stores have lots of options on the cheap. Alternatively, something like some old cowboy boots or potentially even a baseball glove could yield a single piece of leather to cover the whole grip.
    On another note, when rawhide leather is being tooled for something like a the webbing for a traditional snowshoe it is worked wet. I don't have any experiance working with leather like this, but the fact that leather shrinks when it dries out, it might be worthwhile to soak the leather overnight then sew it onto the grips wet. It should shrink when dry and provide an even better hold :)
    next time try carbon cleaner on removal. let sit for few minutes ..you'll be amazed!
    It should not be cleaned properly because the leftovers of the rubber prevent the leather stripes from twisting around!
    I have a white mountain bike that has quite a "modern" image, and I don't think leather would really suit it and it's "image" :/ but idk
    My motorcycle hand grips need replacing about every two years. I'm going to go this route, next time, and see what happens.
    I haven't imagined that this could work on a motorcycle as well but why not! Please, try them and let me know what you think :)
    yay! I think it's perfect now, this is a really awesome idea, but they wouldn't suit my bike :(
    this is really cool, but it needs proof reading because I've spotted numerous places where words that sound the same but mean different things to what would be correct have been used eg "wee" instead of "we", "those" instead of "these" etc etc
