3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make your own Deadmau5 Mau5head!
Love Deadmau5? Enjoy house music? Want to go to raves in style? Deadmau5's iconic Mau5head would surely turn some heads. I decided to go with the original red Mau5head, but you can choose any color your heart desires.
Step 1Materials
Materials
Things you'll need:
- 13" hamster ball
- A yard of red felt
- Hardhat
- White silk (make sure you can see through it)
- 6 sheets of stick on red felt
- 2 12" 3mm BIRCH BALTIC wood plates (NOT BALSA)
- Hard styrofoam ball
- Steel mesh
- Dremel rotary tool with cutting wheel
- Safety glasses
- Hot Glue Gun with sticks
- Spray on Tacky glue
- Regular Tacky glue
- Duct Tape
- Masking Tape
- Sandpaper
- Cutting Board
- Hobby knife
- fabric scissors
- Philips screwdriver
- Paper
- Dark colored sharpie
- Compass
578 comments
1-40 of 578next »
Mar 10, 2012. 9:18 AMmau5fan123 says:
Are you sure a 13" is big enough? Because for me it's kinda small...
Apr 23, 2012. 7:00 AMwillconners says:
uhuhuhuhuhuhuhuhuhuhuhuhuhuhuh
Mar 29, 2012. 10:56 PMJellyyFishh says:
real dimensions are 14"
Mar 25, 2012. 6:33 PMNxtfari says:
Maybe I'm missing something huge, but why is it necessary to add the hamster ball finger slots into the hardhat?
Helps it glue to the top of the mau5head. The normal top of hard hat is badly shaped
Dec 15, 2011. 8:27 AMpat.reyes98 says:
Does Anyone know where to get the Hamster Ball in the Phlippines?
Mar 25, 2012. 6:30 PMNxtfari says:
try a pet store.
Feb 13, 2012. 3:29 PMthomasthetankengine says:
http://www.housemusicessentials.com/mau5head-details-have-been-revealed/
This has the correct dimensions if you need to be official. They are from Mr. Mau5 himself :) 4.5" balls for eyes, 13" diameter for ears, 14" diameter for main head shell, eyes 5" apart, ears 3" apart, eyes 2" above mouth, mouth 50 degrees and goes around exactly half the circumference, ears 15 degrees tilted back, mouth 1/4 indentation.
:) nice 'ible. I will be making a silver and gold chrome-ish one for the North Coast Music Festival over the summer.
Feb 19, 2012. 11:08 PMprettycoolme209 says:
Are you going to take pictures to track your progress I am going to be making one and if it comes out good ill be making another for my self I would like to see your progress I am going to take lots of pics maybe record my progress.... I am going to be making my first one neon green and black... and the second one will be pink and possibly black.....
Feb 20, 2012. 9:16 AMthomasthetankengine says:
I might take pictures, if I remember. I often get too caught up in the fun of the project I'm doing before I remember to make an Instructable :) Despite this, if I do, I will definitely post them!
Nov 20, 2011. 8:04 PMsreed7 says:
Couldn't you use a football helmet?
Feb 19, 2012. 11:04 PMprettycoolme209 says:
no you need something thats big enough to fit your head and also beable to fit a hard hat or bike helmet inside.... I am in the process of making two
Oct 22, 2011. 6:55 PMwpuerta says:
how long does this take to make, if i got materials on Monday and worked everyday would it be ready by Halloween???? please answer soon
Oct 22, 2011. 9:23 PMrichfart231 says:
i built mine with black felt so you can't see any mistakes made on the fabric. I also put 10 feet of el wire around the head and mouth as well as yellow led's in the eyes. It's my FB profile pic. Any how you'll want 4" eye balls, and if you spend 2-4 hours a day for 5-7 days you'll be well past finished. If you manage to find extra time toy around with electronic wiring and minor touch ups to improve the look of it. I'm thinking about building another one out of an acrylic ball thats 14". its pretty expensive but i have extras from the first one. Please ask questions, this demo is a little tough to understand at some areas
Feb 19, 2012. 11:02 PMprettycoolme209 says:
I found them 14 in balls on amazon for $18 way cheap so i bought 2!!!
Oct 27, 2011. 2:56 PMnknele says:
How do you see through this lol?
Dec 22, 2011. 3:09 PMBlackmau5 says:
Dont use too much silk/mesh. Or, the silk/mesh is too thick.
Feb 12, 2012. 5:27 PMryan11504 says:
im going to make 0ne
Feb 11, 2012. 1:49 PMAlternateLives says:
I thought mine turned out pretty good!
Feb 9, 2012. 7:57 AMgardnsound says:
I like this! Check out my rave mask, man. it was inspired by the mau5 as well as Issac from Deadspace.
Turns heads for sure.
Feb 5, 2012. 11:41 AMblaker12 says:
Thanks for the guide! love the results !
Dec 13, 2011. 10:23 PMslimjimnixon says:
so about how much did it cost for all of this to make not including the power tools just the materials
Nov 22, 2011. 1:57 PMdgallegos2 says:
cant i just a freakin stiraphome or watever its called?
Oct 29, 2011. 6:47 AMrsuarez3 says:
i dont have a rotary tool is the something else that i can cut it with???
i need and answer ASAP!!!!
Nov 11, 2011. 8:00 PMrsoest says:
soildering iron, be careful and do it outside due to fumes
Oct 31, 2011. 12:38 PMmrigsbee says:
It would be pretty hard. We could have cut the ears with a table saw if we knew someone. The dremel gets hot and really softens the plastic ball.
Oct 31, 2011. 12:36 PMmrigsbee says:
OK people - This is my sons login - but after 9 hours working on this I have the following suggestions:
1. attach the hard hat before you attach the bottom portion of the hamster ball.
I found duct tape wasn't secure enough so I drilled through the ball and into the
hard hat securing it with a screw and nut.
2. Not a big fan of duct tape if you are going to be dancing, so, after we slid the ears in I marked a spot, pulled the ear out and drilled a very small hole. Then I threaded thin floral wire through and connected the ear to the hard hat. You could use just about anything thin - pipe cleaner, jewelry wire, etc.
3. I also used red paint to color the edge of the ear so that if the wood showed through it wouldn't be too noticeable.
4. The biggest AhHa, I could have stretched the felt over the ball and spritzed it with water. Felt is moldable when wet. I think doing this I could have avoided some of the seems.
Oct 31, 2011. 3:54 PMDarthscout says:
this about sums everything up that i did too! except the water spraying.
Oct 31, 2011. 3:52 PMDarthscout says:
i got mine done about 2 weeks ago, thank you very much...i am thinking on putting foam board and fiberglass as the ears for next year!
Oct 30, 2011. 8:57 AMalley1128 says:
does anyone know how to cut the fabric to cover the head so that it lays flat??
Oct 31, 2011. 12:51 PMtrevorcgross says:
Monokote spray
Oct 29, 2011. 8:43 PMkroehl says:
Will a 11.5" hamster ball?
I don't think a hard hat will fit inside 11.5" ball.
Oct 30, 2011. 9:41 PMhruvalcaba says:
Thanks for the guide... Love the results :D
Oct 28, 2011. 12:45 PMckingsly says:
:D I DID MINE IT 2 DAYS! ITS AWESOME! THANKS! BEST HALLOWEEN COSTUME EVER!
Oct 27, 2011. 3:34 PMtcorwin says:
im makking one right now and i cant wait to be done
Oct 25, 2011. 6:46 PMoleon1 says:
where can i get LED's?
Oct 23, 2011. 10:13 PMdmunoz8 says:
any idea where i can find a 14" globe?
Oct 25, 2011. 2:14 PMpencilpushrz says:
petsmart..24.99
Oct 24, 2011. 7:50 PMsmurat says:
i want to really make one but my mom says its to expensive ive probalbly got a smalle head i trieed reasoning here she just doesnt want to soo im going to say this can you please make one for me? sooo i want to make it but she reads the supplies and she thinks all heavey duty and wants to not buy it because it from a places where things look fancey and shes allways saying fancy things are lots of money!
1-40 of 578next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:PastaNoodles
