3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make your own Deadmau5 Mau5head!
Step 3Eyes and ears part 1
Take your compass and make 12" circles on your birch baltic wood. Take your Dremel and cut out them out. Sand the edges to avoid splinters. These will be your ears. Now take your stick on felt and start applying it on the ears. Take your hobby knife and cut off the excess felt. An ear uses up 3 sheets of felt. Make sure you cut on a cutting board so you don't ruin any surfaces. Now take a piece of sandpaper and start concaving the insides of eyes until it sits flush on the surface of the ball. Do this process outside because it gets really messy.
15 comments
Oct 31, 2010. 7:11 AMOctane_Phantom says:
Just one question, where in fact did you get the wood plates??
Aug 26, 2011. 11:36 AMovanegas says:
home depot
Apr 18, 2011. 6:05 PMjags945 says:
micheals arts and crafts
Oct 2, 2010. 2:07 PMboomheadshot135 says:
Beleive it or not, If you're lucky enough to find large thick felt circles at your local craft store, they work a lot better than wood plates, mostly because its easier to go through doors and whatnot lol. Unfortunately, I only obtained circles with happy face cutouts in them... but I'll see how everything works out!
Jul 26, 2011. 2:24 PMesobie says:
You could cover the smileys with red felt.
May 26, 2011. 2:46 AMSabali7 says:
how does it take up 3 sheets of felt, if you only have 2 sides?
Dec 14, 2010. 10:58 AMdemonxwing says:
how much did all the materials cost? and that is a great idea im going to make it a project with my dad
Nov 15, 2010. 1:10 PMDeadm0use says:
SO FKN GREATH :D:D:D !!!
Oct 29, 2010. 8:32 PMOctane_Phantom says:
(removed by author or community request)
Oct 30, 2010. 2:22 PMhottamaleindustries says:
That's what I'm using
Oct 28, 2010. 3:54 PMandybuday says:
For the ears, I used lids from 10gal buckets - available at hardware stores. If you're using the hamster ball, just cut a couple of notches in the rim of the ball about 3" apart and cut off a bit of the lip, then force the 3" segment through one of the slots. You can slide it up and down to position it correctly. They bend without breaking, but are very stiff and hold themselves up very well.
Oct 24, 2010. 4:54 PMAnthonyRawrsU says:
What is that black mark? i'm really confused...
Oct 28, 2010. 3:52 PMoms925 says:
thats a pen.... just a pen... lol
Oct 28, 2010. 9:45 AMlemasterjmc says:
I couldnt find those wooden plates because everywhere i went said they discontinued them at their store, would styrofoam or cardboard suffice... as long as im careful haha
Oct 5, 2010. 3:32 PMseagallsballs says:
will a cheap $20 dremel tool work?
Sep 21, 2010. 6:57 PMChanderson37 says:
question on this step. is there an easier way to make it so you can not see the seams? I mean when i test it out i can see where the pieces of the stick on felt meet, so i was wondering how you fix that problem.
Sep 22, 2010. 10:48 AMleonandkobe says:
Not really, in fact if you look at his proffesionally made heads, you will see a seam around the back of the head where they have to stich it. No way around that. You have to pull super tight to get only one stich around the back at that. I did mine in 4 quarters since I am attaching el glow wire around the outside of the mask you wont see the seam going vertical.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:PastaNoodles
