3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How-to make your own Ethernet "splitter"
How-to make your own Ethernet \"splitter\"
With an Ethernet "splitter", you can simultaneously connect two computers (or other network devices) on one Ethernet cable. You can buy Ethernet splitters for approximately $ 20.00 USD but you also can make your own.
Context:
One office, one ethernet jack and two computers, or
One living room, one ethernet jack and one HTPC and one XBox.
If you can't realistically (without tearing apart walls or renting a scissor lift) pull one more ethernet cable from the patch panel to the office / living room etc. you can consider the use of an Ethernet "splitter".
I'm assuming all the four pairs of the ethernet cables are properly connected within the ethernet wallplate and the patch panel.
Step 1What you need
What you need
In order do make your own Ethernet splitters you'll need the following:
  • Two RJ45 Crimpable Plug
  • Four RJ-45 keystone jack
  • Short Ethernet Cable Scrap (approximately 2 feet)
The tools you'll need:
  • RJ45 Crimp Tool
  • Craft knife
  • 110 Punch Down Tool
  • Loctite Super Glue
125 comments
1-40 of 125next »
Apr 11, 2012. 8:04 AMkdrayer says:
this set up is for B configuation, is there an A?
Thanks
Feb 9, 2011. 12:28 PMRodHq says:
Hi, great instructable, but i have a question. If I want to do this, but I want three female ends instead of two, and no male ends, how should I wire the Keystone jack instead of the crimpable plug
Apr 11, 2012. 8:00 AMkdrayer says:
Your set up is for B wiring configuration, do have the A version.
Thanks
Mar 20, 2012. 7:31 PMjcasper66 says:
DUUUH, I answered my own question. My 'sharer-splitter' adapters worked fine once I determined that BOTH keystone connectors and RJ45 plugs would use only the orange/green pairs. The router keystone connectors and or the DVD/TV cable box inputs must just use one half of the wires, those being the orange/green pairs.
The adapters allowed me to operate two separate devices off of a SINGLE Cat 5 cable as long as I had two free router outputs.
Thanks to all the comments as in the end they saved me from running an additional cable.
Mar 15, 2012. 3:10 PMjcasper66 says:
Is it possible to use a SINGLE Cat5 cable to connect two outputs of a cable TV router to a TV cable box AND a DVD (both needing separate ether-net inputs)??????????? I have no specs on any of the installed equipment but the concept of this thread seemed promising.
The simple solution of using TWO cables is not feasible due to access issues and the DVD/Cable TV converter are NOT wireless.
I tried simple homemade splitters at BOTH ends of known good SINGLE cable but only the side with the green and orange wires functions. The standard is 56B. I have probably oversimplified my solution but if there is some simple trick short of patch boxes/switches it might save me and other users some money. I can not open the cable box to see how the output and input keystone connectors are wired. Am also not a network guy but did work on vacuum tube TVs back in the 60s so I can follow a wiring diagram.
Reviewing other comments did not seem to help but since so many had similar issues with one side not working I am led to believe that what I am trying to do is just not that simple. The cable TV company is of no help either as they do not understand why I would not simply drag another cable through the wall.
Any help most appreciated.
Mar 15, 2012. 5:50 AMSpndavillain says:
I did all the steps but i cant seem to get it right. after i completed the splitter if i connect only one jack it doesn work but when i enter 2 jack only one works. i tried with the combination of colours you gave and the combination of the rjs i found on the existing set up
Mar 10, 2012. 9:30 PMKlaudiuszm says:
I like the idea :D. I haven't tried this, but in theory it would work.
Feb 24, 2012. 10:43 AMgiltech says:
followed your instruction jack #1 works Jack #2 don't wok please advise thank you
Feb 5, 2008. 6:45 PMNova_Logic says:
is there any way i could jsut buy this from walmart or somthin, i dont feel like doin any big complicated projects
Sep 30, 2008. 12:25 PMDBLinuxLover says:
Lol this isnt complicated.
Jul 20, 2009. 2:32 PMGroxx says:
Unless, of course, you don't have any of the required tools for this (which would cost more than making a few of these splitters).
I'll admit, it's not a "big complicated project", but there's no reason to pick at people.
A simpler option is to just buy a network hub, they're pretty cheap (often $20 or less). This is similar to an un-powered hub, though this is incompatible with PoE and Gigabit.
Jan 2, 2012. 11:19 AMmeenzal says:
No, not 'nough said... A lot of very experienced engineers read here but don't post. Their offering their expertise should be appreciated, not slammed. There's a reason that ethernet hubs have fallen out of favor compared to switches, and you have built a 2 port hub. They do create network bottlenecks and dropped packets and packet collisions. Your instructable is good for a fast 'n nasty, but to split a connection a switch is really the only way to go, especially when it comes to gaming where microseconds can be the difference between success and failure.
Jun 23, 2011. 7:14 AMmgalyean says:
Most bottlenecks with home LANs occur at the cable/DSL/whatever modem. With the typical 100MB (or even 1GB) network two computers sharing a cable via a hub or switch will still be orders of magnitude faster than the ISP feed...typically. Unless you are doing a lot of heavy bandwidth stuff within your LAN that doesn't traverse the modem then worries about LAN bottlenecks are usually unwarranted. Unless WiFi is involved. That is an entirely different can of flying monkeys, but isn't relevant to sharing a cable via hub or switch.
Sep 23, 2009. 12:51 AMjongscx says:
... Do they even sell hubs anymore? We tried to find some for our "Intro to Networking" class, to show bottlenecking and signal crossing... and nobody had any in stock anymore... Unless of course you guys are talking about switches...
Jun 25, 2011. 6:43 PMkill-a-watt says:
I dug a hub out of the trash at work a few years ago. It was only 10 Mb, so that's why I assume it was tossed.
Engineers hoard the things at my new place of work. It's an easy tool to use to sniff network traffic.
Jun 23, 2011. 7:18 AMmgalyean says:
I haven't seen hubs in stores for awhile either. For those who don't know, a hub shares the available bandwidth among all connections, while a switch typically has a backbone that is much faster than the ports so it can better insure that each connection gets full speed and doesn't have to share. In other words, two 100MB streams via a 100MB hub will get 50MB each. On a switch with a 1GB backbone inside they'd both see 100MB. Switches are so cheap now there is little reason for anyone to market a hub given their shortcomings.
Sep 23, 2009. 1:21 AMGroxx says:
They definitely do, though switches are primarily taking over because they're so cheap to make now. I think I remember finding an un-powered / power-optional hub a few years ago, too. As proof that they still exist, a quick search yielded one from Best Buy for $19. Though a switch with one more port was $22, and was 10/100, not just 10, so there's not much of a reason to go for that one in particular.
Sep 21, 2009. 2:14 PMLuistheguitarist says:
How does it create a bottleneck? 2 computers on a hub and 2 computers on this splitter still puts them on the same collision domain. In fact some hubs do exactly the same thing. Both layer 1 devices. Help me understand.
Sep 23, 2009. 12:54 AMjongscx says:
This device does not split the signal... it splits the cable. Normal ethernet on a Cat5 (4-pair) cable only uses half of the wires in the bundle (2 pairs). All this "splitter" does is redistribute signals so that one computer uses 2 pairs and the other computer uses the other two. They are on separate collision domains because they are still connected to two separate ports on the router... The analog to this setup is if you just had two ethernet cables running normally connecting two computers to a router.
Sep 23, 2009. 12:01 PMLuistheguitarist says:
Of Course! So simple. I should've read the instructable. Needless to say this won't work with gigabit networks then. Thanks for clearing that up.
Sep 23, 2009. 9:19 PMjongscx says:
no, it wont.
Dec 27, 2011. 4:44 PMjchusky says:
i was wounding can you use both the ports at the same time .i have xbox 360 and a internet tv
Oct 2, 2011. 7:50 PMRedion says:
Well in my case I only have one ethernet outlet upstairs in the apartment building but I have 2 pcs. So i need a splitter!
Jul 29, 2011. 12:05 PMsoudeh says:
i try it but jack 2 is not working
Jul 12, 2011. 8:57 AMmahinder says:
There are different configurations for  Ethernet splitters, which depends on the objective of the usage for example an rj45 splitter used for data- data splitting different  from that of data- voice splitter and which is again different from the voice - voice splitter. The user must be aware of this while buying an ethernet splitter.
Jun 13, 2011. 8:40 PMmickad27 says:
Would this work with 1 ethernet and 1 USB connection? Like instead of the 2nd ethernet port, I would put on a USB port. Or would there be cross-talk?
May 7, 2011. 3:26 PMrrrmanion says:
am i right in thinking packet collisions are more common with this setup?
Jul 7, 2010. 11:09 PMsmitdesai says:
Is this work if 3 pc connected to single internet connection ??
May 7, 2011. 3:25 PMrrrmanion says:
or, connect a hub to the modem router, or if you get internet access through a modem on one of the computers, set that up to share it's network connection, then hook up a switch to that
Oct 4, 2010. 8:57 AMjefftoshey says:
I also cant get the two computers connected simultaneously to the switch. only one can connect to the internet. kindly assist
Nov 27, 2009. 6:10 PMleethebee says:
Hello Chrismake,
I have attempted to do this to connect 2 computers to one modem, but it is not working.  Only the oranges and greens are working.  I'd like to use this concept to run 1 ethernet cable to my bedroom (from the basement) to connect 2 computers to the internet.  Am I missing something or a step?  I didn't really understand step 6...
Apr 11, 2011. 10:41 AMphilhartree says:
Hi
I realise this is a couple of years old, but I wondered if I might ask you to check the text against the pictire.
Specifically, assuming the top left connector in the pic is pin 1, the colours don't match the text.
Your input would be greatly appreciated.
Regards, Phil
Jun 16, 2010. 2:55 AMnzsammy says:
Its main aim, is on a 10/100mb Lan (which only uses two pairs) utilizing the other two pairs in the cable for a second Ethernet device. This is for cable only and will not work by trying to run two pc's off one switch port, each pc must use its own port, but two pc's can share one cable. The same can't be said for Giga-Bit (1000mb), This uses all four pairs so using a splitter would force the NIC to 100mb.
May 18, 2010. 1:25 AMpierlinn_buenvenida says:
help me --- what is the main purpose of that spliter its use in 2 pc or its for hub or rounter thank you
1-40 of 125next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:chrismake
http://www.christophecaron.com/?page_id=2
