Pepakura Designer 3
Pepakura Designer allows you to create a development for paper craft easily from 3D data used in 3D CG software. You can load a 3d image and make adjustments (not featured in this tutorial) or you can load already saved files from Pepakura and print them out to assemble a 3d object using only paper!
The .pdo files that are shared here are saved to be printed on A4 paper. This is a universal standard size paper, however it is not what is typically used here in the United States. To use 8 1/2" x 11" paper (Letter) or 8 1/2" x 14" paper (Legal) we will have to change the settings and manipulate the images to make sure they fit on the paper. But don't worry, we will cover that in this tutorial. ;-)
If you are planning on using the print-outs from Pepakura to place onto another medium (such as cardboard or foam board) you can easily print the designs on regular computer or copy paper. However, if you plan on using your printed pieces of paper as your main structure, I recommend printing on card stock paper. You can find bundles of card stock at just about any paper store, or for a much easier (and probably cheaper) find, head over to your local Wal-Mart.
