How to make your own Machete
 by Trollinwater
Featured
        Hello Do It Yourself-ers!  This is my first instructable, and I thought I would give documenting my machete build a shot and turn it into a How-To for the site!
        Now, we all know that a nice, big axe/knife comes in handy during camping trips or in survival packs.  In my case, I will be using this hefty, sharp piece of metal for camping trips.  It will serve the purpose of cutting down firewood or building small shelters, and boy, will i look cool doing it!
Materials needed:
1/8" x 3" x 3' steel or metal of choice (size, material and thickness depend on what you are looking for out of your machete)
Steel rod or dowels (to hold the handle to the steel)
Lumber
Epoxy
Tools needed:
jigsaw or cutting tool of choice
Sharpie
Tape measure
Grinding wheel and sharpening stone
Vice and clamps
Belt sander or disk sander
Rasp or file
Safety glasses
Sharpening tool of some sort
Step 1: Make your design and START HACKING!
      To start off, you may want to have a design or shape for your blade in mind.  For this blade I chose to keep it simple and have a larger section for weight towards the tip of the blade, and had it taper off into the handle.  NOTE: the blade will be built right into the handle so don't cut it short!  I cut about a 1/2" shy of the bottom of the steel for the bout at the tip, and tapered it down to 1 1/4" where the blade meets the handle, then continued on at 1 1/4" for five inches or so for the handle.
    Make the outline of your blade shape on the steel, and start cuttin'!  You want to make sure the steel is secured properly or it will just jump around on you and cutting will be a pain.  And please wear safety glasses!
Step 2: Refining the blade
      At this point, you should have a rough cut of your blade and hilt.  If you have a belt sander, use it!  smooth those edges up and make everything to your liking.  refining the hilt is not completely necessary because we will be cutting into that again.
Step 3: The handle
      Now that you have shaped the blade and hilt. its time to add a nice handle.  From a previous guitar build, I had a slab of mahogany left over so I cut out a block of wood, the thickness of the blade, and cut in half with the band saw.  You can do all of this with a jigsaw or hand saw. it does not matter.  from there on, I thicknessed the two pieces of wood to my desired thickness and sandwiched the two pieces of wood on the outside of the steel.  Finally, i cut the two pieces of wood to the length of the hilt.
      From here, you can square the steel to the wood and clamp down the wood and steel.  then drill two holes straight thru the steel and wood.  Make sure your drill bit is the same size as your metal rod or wooden dowel so they can secure the handle and blade together.
      Now, after drilling the two holes, mark the length you will need to cut your dowel or rod and cut two of them.  So, with all of your parts, its time to bust out the epoxy!  Slather up the hilt of the blade with epoxy and sandwich it between the two pieces of wood lined up with the holes you drilled, and put some epoxy on the two dowels/rods you cut and pound those in.  Finally, clamp the handle in a vice and leave over night!
Step 4: Make it your own!
      After a night of sitting, un-clamp it and get a feel for your handle.  you may just want to round it out and leave it as is!  For mine, I took the handle to the belt sander and made myself some finger slots, then clamped the blade into the vice and rounded the edges with a rasp.  The sky is the limit here!  After you have obtained your final look, you can sand it down so its smooth with 180 grit.
Step 5: Lets give this baby an edge!
      Sharpening this tool is really up to you.  If you want it razor sharp, it may take a while and don't expect it to keep its sharp edge.  Remember, its steel!
      I took the blade to my belt sander and gave it an edge, then finished the job with a cheap sharpening tool that I found at my local sporting goods store.  That thing works wonders and I sure will be using it in the future.
      I kept the blade moderately sharp to keep it simple to my uses, but again, the sky is the limit!
Step 6: Now, concur the outdoors...
      With your trusty machete, feel confident while at camping trips or know that a reliable tool is waiting for you in your survival pack.
In part two, we will cover how to make a sheath!
Explore with confidence, my friends!
seagrape33 says: Jan 19, 2013. 1:33 PM
When using a machete, you want to use your whole arm to swing the machete, with a snap of the wrist delivered just before contact. For more power introduce a bit of waist motion. This technique is useful for cutting down small trees and large branches. On the job I often use a machete to cut up palm fronds and branches. That wrist motion does help a lot. Finally (and you probably already know this), never use a dull machete! With a sharp machete and proper technique you'll get the job done faster and use less energy. Which means you'll be less tired and less likely to get into an accident involving a body part.
seagrape33 says: Jan 19, 2013. 1:25 PM
For starters, this is a nice instructable. Easy method for making a machete. I'll try it out myself. However, if you are serious about putting your machete through the ropes, you want to find a way to make the steel at the edge really hard; a harder steel will keep its edge longer, thus reducing the need for frequent sharpening. You'll know the steel is hard enough when even a Nicholson file won't bite into it.
One way to do this - and you'll need a forge that can accommodate the entire machete blade length - is to spread some moist clay all over the area behind the edge up to ½" from it, at a thickness of about ¼". This will prevent the steel from heating up too fast. (You'll know why in just a bit.) Then you put the blade in the forge until it's orange-yellow hot. Take it out of the forge and quench it in icy salt water. The clay-covered area will cool more slowly, so leave the clay on for an hour or two; clay tends to trap heat, so it will take time for the steel to cool down enough for it to be handled safely. Once you remove the clay, the steel in the back part of the blade will be rather soft, but the edge will be so hard that you cannot file it. You'll need a stone or carbide sandpaper on a wooden block to sharpen it. Also, do any beveling of the edge BEFORE putting the blade in the fire. Filing/grinding down to an edge thickness of about 1 mm is good enough; you want to do the shaping when the steel is soft and the sharpening when the steel is hard.
When you get to the sharpening stage, you can use either a belt sander, motorized grinder, carbide sandpaper, or rough whetstone to do the rough work. Usually a 220 grit abrasive does the job. When the side view shows the bevel comes to a tip, follow up with 400 grit. After about a minute of the 400 grit, do a minute on 800 grit. Finally, a minute on 1200 grit and a minute on 2500 or 3000 grit. At this point the edge will be sharp enough that you can shave hairs off your skin with it. You can use it just like that. If you want it even sharper, go with a 4000 or 6000 grit stone (this is overkill already) and finish off with 30 seconds on a strop + stropping compound. Usually such high-grit abrasives are for sharpening tools made from high speed steel or other really hard steels; these can keep a razor-sharp edge for a while. Even katana (samurai swords) are sharpened to such a keen edge; sometimes 8000 or even 10,000 grit stones are used to polish the edge. The result is a blade that is more than sharp enough for shaving.
If you do not choose to temper your blades, 1200 grit or 1500 grit is as high as you should go, since soft steel (steel that can be filed down) will not hold a very keen edge for long. Even so, a blade finished at 1200 or 1500 grit can still give good service. If you are interested in making scary sharp edges, look up "Japanese sharpening stone set" on Google. Different sellers sell sets of sharpening stones. For example, Highland Woodworking sells a 5-stone set for $169.99. http://www.highlandwoodworking.com/standardwaterstone5stoneset.aspx
If you cannot afford stones, you can get a piece of carbide sandpaper and put it on a glass surface or tape it to a wooden block.. Most hardware stores carry up to 2500 grit. The 3000 grit and higher ones are a bit harder to get. Even so, you can get a more than serviceable edge with just 2000 or 2500 grit, especially after tempering.
Tempering steel to the desired hardness consistently does take a good deal of playing around with the temperature, but usually just heating to a good cherry red and then quenching in icy-cold salt water yields a hard steel, good enough for cutting tools. If the piece of steel is small enough, you can just use a MAPP gas torch. If you're making, for example, small chisels from concrete nails, a MAPP torch is easier to use and obtain.
skimmo says: May 31, 2012. 8:08 PM
great instructable bro, but its not wise to use gloves when using grinding stones or belt sanders, if you scrap your skin on the sander it may hurt a little but if your glove gets caught, you can lose a finger.
but still really good job!
BJMN in reply to skimmoSep 17, 2012. 7:53 AM
Good thinking - but, having worked in safety for a large multinational manufacturing firm, I must point out that statistics show that wearing gloves while using a sanders or polishers do reduce injuries. The likelihood of the glove catching on the rotating belt or disc exists, but most hand/lower arm injuries with this type of equipment is not from the belt/disc - they are from pieces of material being caught and flipped back, or shattering, etc.
Standard industrial practise is to insist on gloves at all times even when using this type of equipment.
AR10NZ says: Jul 28, 2012. 10:09 PM
Nice Instructible. As a 14 y'old Canadian, I made a machete out of an old 2 man cross cutting saw. Excellent steel, with spine thinner than cutting edge. Shaped & ground cold, no need to heat treat. The blade tip could be bent to 90 degrees, excellent spring back.
Moose horn grip, and rawhide sheath. Had it for 37 years, then a low life stole it from my camp site, in Australia. Cheers
Trike Lover says: Jul 1, 2012. 12:00 PM
When I was a child my father made two machete-type blades, one using a broken lawn mower blade, the other with a piece of car or truck leaf spring. I got to help with the "safe" jobs. He said he had learned the process while stationed in India in WWII. He had been a night-fighter pilot, and a blacksmith near the field used to make knives for the pilots, as there were no service-issue ones for aircrew. Since they flew at night, he watched the smith during the day.
I may have some of this mixed up - it was 45 years ago. Our forge was a thick steel bowl, the bellows made with fence boards and canvas. One of my jobs was pumping the bellows.
To start with, the blade outline was cut using a hacksaw. (I got to do this-a slow job). Then Dad heated the blank in the forge and, alternating sides, gradually hammered the "business" edge thin all down its length. This took much re-heating and hammer-and-anvil work. When he was satisfied he heated the blade very red, then quenched it in old motor oil.
I got to polish the pieces using Emery cloth, which took quite a while. The shiny piece was then heated until different colours rippled across the shiny surface - he called this "drawing the colours". When the edge turned the right shade of blue it was quenched - I think in oil. The edge was finished on an elderly hand-cranked grindstone with a water-drip. Another long job - I was grindstone-cranker.. Handles were cut from the seat of a wooden office chair - Oak, I think, and leather lace wrapped tight on the grip.
As I said, I may have details wrong, memory being what it is. I do remember that the finished blades held a very good edge. One was a machete profile, and the smaller more like a Malay parang. Both were stolen from my campsite some years back by some low-life scum.
Very interesting Instructable, and it brought back a lot of memories.
State50 says: Jun 3, 2012. 3:26 AM
Was watching a subtitled Japanese travelogue and they had an old gentleman who used one loop from a big ship's scrapped anchor chain to forge a blade. I guess high-hardness steel is wherever you find it.
ottist35 says: May 25, 2012. 4:55 PM
Great instructable! Will be looking forward to your guitar post.
EmcySquare says: May 24, 2012. 8:24 AM
Nice piece of work. It started to get addictive after a short while.
Advices:
- There are not "Metals of choice" : a good job is done only with carbon steel
- You NEED to heat treat it right: it's not simply a forge&magnet thing
You might also consider having it HT-ed by a company
Waiting for the next one ;-)
flamesami in reply to EmcySquareMay 24, 2012. 12:39 PM
well, that depends on the steel you use... stainless = forget any diy heat-treatment; cheap carbon steel, you probably could get away with it;) it's the tempering that'll have to be more controlled, but even so, it can be done with dthe back-draw method (blowtorch heating the spine). greenpete over on youtube has an series of vids on making a knife out of a file. quite interesting.
and kudos to Trollinwater for doing this, my first knife still needs tang-holes and HT
Trollinwater (author) in reply to flamesamiMay 24, 2012. 2:03 PM
could i use a sheet of thin spring steel?
flamesami in reply to TrollinwaterMay 25, 2012. 3:49 PM
assuming it was the right size and shape, and not too thin, yup!
no problem as long as you can get it hot enough (non magnetic) all the way through (you might need quite a large forge) and then quickly cool it
make sure you know how to quench it - if you bought it, ask if it is air-quench, oil-quench or water-quench, if it is just a random lump of spring (say, a landrover leaf-spring) see what you can find on google, and if unsure, use oil (slowest quenchant). Like I said, tempering is the hardest part... most knife-makers have an electric oven with a thermostat, but it can be done with a blowtorch. Do your research on the steel if you know what it is, and ask around if you don't: britishblades is an online knifey-place, with very nice members, who know their stuff.
 feel free to pm me if want to know something - if I don't know, the people on britishblades do
absolutekold in reply to flamesamiMay 25, 2012. 9:21 AM
You can usually use propane torch (or for a machete you may need 2 and a buddy) to get the heat you need. the big thing is cutting a few small "slivers" (like 1/4" square and 2"long) off and practice heat treating with them making sure to write down exactly what you did.
1) heat them up to different temps (past magnetic) and dunk them in the oil then see if a file can remove anything. if it cuts like before try using brine (see below) else go to next step.
2) clean em off and throw them in the oven at about 350-400 F until they have a straw color (if you don't want to anger eveyone who cooks with that oven be sure to clean the metal with soap and water and dry thoroughly)
3) turn oven off and let sit until cold (usually overnight).
4)Do the file test it should just barely cut the metal
5)Wearing safety gear clamp them in a vise about 1/2 way put a pipe on it and bent until breaking. (remember to write everything down)
If you did a good job keeping notes and remembering colors you can recreate the properties on the real deal. Most spring steel is 5160 so quenching with cooking oil is probably your best bet. for mild steel (1018 ish) is to use brine which is water and salt (heat water then add salt until it doesn't dissolve any more) with maybe a touch of dish soap.
Sometimes i forge tools out of mystery steel and this is what i have to do to get the properties in steel that i want. all the precision gear in the world doesn't help you if you don't know what steel your working with (aka junkyard gold)
mbreukel says: May 20, 2012. 3:58 AM
nice machete!
i have 1 advice for you.
if you want your machete to stay sharper a lot longer, and less "bendy" you should consider heat treatment. by doing this(internet has all the information) you will strengthen your blade making it harder. this way it wont bend as much, wont get nicks in soon(unless smashing it on nails) and keeping it sharp longer.
you do need to make the bevel before hardening(not sharpen yet that can be done later on) otherwise the metal is way harder so it will take more time
SelkeyMoonbeam in reply to mbreukelMay 21, 2012. 11:26 AM
Not sure this is the best advice. The initial steel was likely cold-rolled to process initially, so many types of heat treatment would only remove the grain dislocations which strengthen the material- I made this mistake when forging knives.
A better idea might be to just cold-work it by hitting it hammer-on-anvil (or large rock, if you don't have an anvil). This will add to the tensile strength and hardness of the material.
lperkins in reply to SelkeyMoonbeamMay 25, 2012. 12:45 PM
If you are using mild steel for your blades, then when you heat treat it, you need to work it as it cools along the part you want to be the hardest. Generally the edge should be hard so it doesn't dull and the spine should be softer to absorb impacts without breaking. Working the steel as it cools reduces the grain size and makes it more capable of taking and holding a fine edge. The process is called edge packing, and you'll find a lot of debate about whether or not it works. The thing to keep in mind is that the technique was developed for working wrought iron and, to a slightly lesser extent, mild steel, and will have practically no effect on modern alloys unless you've overheated them and are trying to undo the damage. Modern tool steels use alloy additives to keep the grain size small so the process is unnecessary, although the additives make the metal slightly more brittle. I have a few knives, axes, chisels, and hammers that my grandfather made out of mild steel that take better edges and hold up to abuse better than anything I have found new.
The little bit of instruction I got regarding how to go about treating most mild steels in this manner was to heat it until it demagnetises, quench in water, heat to a dull cherry red and work it, keeping it at that colour as best as possible, and then quench in oil. Depending on the properties you want you might heat it a third time as well. Keep in mind, I was about six at the time so I may not be remembering the details correctly, but I'm sure you can find more information on the Internet. Of course, the technique takes quite a lot of practice since working the metal will change its shape, so you have to account for that with the shape of your starting piece. But if you're using mild steel, even a bad job of it will likely be better than nothing.
ViperSniper in reply to SelkeyMoonbeamMay 24, 2012. 3:13 PM
if you don't have an anvil use a sledge hammer im using 2 of those and it works way better than a rock:)
Deathcapt in reply to SelkeyMoonbeamMay 24, 2012. 10:52 AM
The grinding will mangle any kind of treatment the cold-rolled process will impart on it, unless you're the most patient person in the world, and you cool your piece every 10 seconds on the belt sander.
I've done a couple knives and swords like this, and they all came out with useless edges initially, If it's not heat treated, it can't even cut through paper without loosing it's sharpness. Even if I made them shave sharp, after a couple cardboard boxes, they're dull.
ViperSniper says: May 24, 2012. 3:20 PM
thanx dude im going to use this instructable but for making a knife.
menahunie says: May 24, 2012. 2:08 PM
I get my steel from truck salvage yards from the aping packs for the suspension.
way cheaper and you can make allot of knives from one
usleatherneck says: May 24, 2012. 1:17 PM
Before you apply the handle you might consider roughing out the edge, and then bring the blade to cherry red, or use the magnet method then quench it in used motor oil. Used motor oil is impregnated with carbon. When quenching the blade the carbon will enter the steel. It will not penetrate all the way through but you will have a tougher outer layer and it will hold an edge until you wear through the carbon enriched edge from use. As stated above you will need to temper in an oven to the desired hardness for the type of cutting edge you desire.
Grahamwithimps says: May 24, 2012. 7:31 AM
It must be sharp enough - there's a plaster on your thumb!
Much respect for building your own machete aged 15. Over here (UK) they're so paranoid about children and knives that even Boy Scouts don't carry penknives any more...
Trollinwater (author) in reply to GrahamwithimpsMay 24, 2012. 10:56 AM
haha! unfortunately, that wound was from picking lobster meat at work.... those hard shells are a pain to pick.
desertsniper says: May 22, 2012. 7:11 AM
this came out great! id like to see one out of tool steel now!
Trollinwater (author) in reply to desertsniperMay 22, 2012. 8:59 AM
tool steel? what do you mean by that?
desertsniper in reply to TrollinwaterMay 22, 2012. 12:56 PM
It is just a higher grade steel with a lot of carbon in it. this way you can heat treat it and it will maintain an edge better .
EmcySquare in reply to desertsniperMay 24, 2012. 7:57 AM
desertsniper in reply to EmcySquareMay 24, 2012. 9:15 AM
which is alot more then .2 content of the steel used in this instructable.
Trollinwater (author) in reply to desertsniperMay 22, 2012. 6:26 PM
Interesting...... i think i will have to pick some up!
Draxis in reply to TrollinwaterMay 24, 2012. 10:53 AM
I just started a little bladesmithing myself, and if you have the time I recommend picking up a copy of "The Complete Bladesmith" by Jim Hrisoulas, I found it to be extremely helpful if you find this is something you really enjoy!
desertsniper in reply to TrollinwaterMay 23, 2012. 6:44 AM
i suggest starting with A2 or getting some 1018 carbon steel. just remember this stuff has to be heated and quenched in oil., then baked at about 400 for a few hours and let to air cool. do your own research on this subject. i have no doubt you can accomplish it.
Splus says: May 24, 2012. 7:50 AM
I made one of these a year or two ago, but I used a salvaged butt end of an axe handle for a grip, and it came out beautifully in case anyone has one laying around.
Splus in reply to SplusMay 24, 2012. 7:55 AM
And also, well documented ible. Keep it up!
lopeznora says: May 21, 2012. 11:06 PM
Pretty good post. I just stumbled upon your post and wanted to say that I have really enjoyed reading your post. I hope you post again soon.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
