Introduction: How to Make Your Own Battery Backup
Here is a easy way to build your own battery backup to power your computer tv or whatever
Step 1: The Parts
You will need
1 12V car battery or 2 6V car batterys
a car battery charger
a 400 Watt power inverter
some wire
and depending on your battery bolts
some wire
Step 2: The Assembley
if your battery has posts replace the bolts with posts
Screw the bolts to the battery and put the battery charger clamps on them
Then wrap the wires from the inverter on the bolts (be sure to check the polarity on all conections before turning anything on) plug the charger in and let it charge the battery
Then when the power goes out plug your stuff into the inverter and you can get several hours of use.
